Question about SanDisk Sansa e250 MP3 Player
Sansa Bad Track Fix.....
Make sure you are leaving your player plugged into your computer long enough to write the track information to it. The first go round mine played fine....then later I was getting the bad track problem...then I thought...maybe I unplugged it too soon because a lot of the files said unknown. I put it in MSC mode and plugged it in....on the player it said Writing....even though i wasn't transferring and i stopped the updater....when it finished i played it and no more bad tracks and no more unknowns. May work for others as well.....
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
BAD TRACK FOR EVERY SONG
The database has been corrupted, click HERE for how to properly format and reload firmware if need be...
Sep 30, 2008 | SanDisk Sansa e250 MP3 Player
It says "bad track" and shuts off while connecting to my computer.
switch the cord into a different usb slot while it was loading
May 17, 2008 | SanDisk Sansa e250 MP3 Player
Mp3 is locked
dont touch your sansa for about 1hour and be sure to lock it then it will auto shut off then delete the track that is a "bad track"
May 04, 2008 | SanDisk Sansa e250 MP3 Player
Sansa bad track
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media1.gif, music and delete them from there.
Either under sync pane in windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
Hope this helps
If you still not able to delete it let me know so I can have you try something else...
P.S.Please rate accordingly...
Thank You
Computerrep
Mar 21, 2008 | SanDisk Sansa E280 MP3 Player
Connected - disconnected
i have had my Sansa e260 for about 6 months and while i was listening to a song it kept saying Bad track , Bad track , i got worried so i shut it off. Now its alsost like the power button is being held in it keeps showing the screen that comes on when you turn it on. When i plug it into my computer it doesnt even show up on the Monitor. i dont know what happened to it or how to fix it. Please HELP!!
Feb 22, 2008 | SanDisk Sansa e260 MP3 Player
I could listen to some songs
Prob need to format the player
1. put player in msc mode (settings menu under USB)
2. go to my computer and rightclick on sansa
3. format box: choose quick format
4. format complete, allow player to stay connected to computer for 10 mins
go to sandisk.com and under downloads, download the updater to keep this from happening again, put the updater on your computer so each time you plug it in, it will look for updates
make sure you do not put questionable files on the player such as itunes or mp4, as they will "bad track"
Jan 23, 2008 | SanDisk Sansa e250 MP3 Player
Bad Track and No Files Message
Yeah, I have that "Bad Track" problem for some my tracks or even for entire albums. The only thing I can think of that would cause that is if you skip over the track consistantly. Anyway, the best solution I've found for that is to go to Windows Media Player, delete the track, and then put it back on if you have it backed up on your computer. P.S.: MAKE SURE YOU HAVE THE SONG BACKED UP ON YOUR COMPUTER BEFORE YOU ATTEMPT THIS. If that doesn't work, you should find another way to get the song. Unfortunately, I can't help you with the "No Files" problem since I haven't experienced that.
Nov 01, 2007 | SanDisk Sansa e250 MP3 Player
"BAD TRACK"
You have a corrupt file - bad file...
Corrupt files for sansa -
Plug your player in, in MSC mode.
Right-click on it.
Click "properties"
Click "tools"
Click "Error Checking"
Check both the boxes on the error checking window that pops up, and click start.
After it finishes, check your player to make sure your player is normal.
If that don't work then format = http://www.sandisk.com/Retail/Default.as...
Sep 26, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
37 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
