Question about Microwave Ovens
AMANA MC23MPW2 "CALL FOR SERVICE"
CALL FOR SERVICE ON DISPLAY, CLEARED COMES RIGHT BACK. WORKS FINE. WENT THROUGH SERVICE TEST MODE CAN FIND NOTHING ABNORMAL.
  • centraltv May 20, 2009
    says CALL SEru. How do you clear it????
2 Suggested Answers
  • 36 Answers
SOURCE: Abnormal noise produce by Amana microwave RC17
Deart Customer
please undergo the following
Since 30 to 50 percent of the power into a microwave oven is dissipated as heat in the Magnetron, cooling is extremely important. Always inspect the cooling fan/motor for dust and dirt and lubricate if necessary. A couple of drops of electric motor oil or 3-in-One will go a long way. If there are any belts, inspect for deterioration and replace if necessary.
An oven that shuts off after a few minutes of operation could have a cooling problem, a defective overtemperature thermostat, a bad magnetron, or is being operated from very high AC line voltage increasing power to the oven. One interesting note: Since 30 to 50 percent of the power goes out the vents in the back as heat, a microwave oven is really only more efficient than conventional means such as a stovetop or gas or electric oven for heating small quantities of anything. With a normal oven or stovetop, wasted energy goes into heating the pot or oven, the air, and so on. However, this is relatively independent of the quantity of food and may be considered to be a fixed overhead. Therefore, there is a crossover point beyond which it is more efficient to use conventional heat than high tech microwaves
i think the information would help u if so rate me please,otherwise just give it as fixya,Thank u
Posted on Dec 17, 2008
Amana RC22S2 Cooks but not as well as before. Continually shows Call SERV
It is sensing the unit is not heating properly and telling you to call for service. Resetting will only delay it from showing the error alert again. It has a current sensor on the unit to tell if it is running properly, if not, it gives the error to let you know it is time for repair.
Oct 12, 2017 | Microwave Ovens
Amana MVH210W keeps blowing fuse
The magnetron is more than likely the problem, or the inverter board if oven is 7 years old or less. If you have a digital meter you can do a rough test on the magnetron, unplug microwave, set meter to ohms, disconnect one wire from magnetron and put the test leads across too points, if reading is .2ohms or less it is good, but if the test shows infinity or open the magnetron is bad, keep in mind it may have a short making the reading misleading.
Jun 04, 2012 | Amana Microwave Ovens
Amana arg7102w gas range broiler works fine but regular oven doesn't heat up, viewed igniter from the back while turned on and see igniter glow but no gas flowing, can't find service manual online...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 12, 2011 | Amana Microwave Ovens
Error flashing on display KHHS179LSS
If you pull off the top louver (it just pulls straight off) usually (mine does) there is a small technician manual (is a small black plastic bag) on the right side above the control panel. It shows all the error codes and what they mean. It shows how to enter test mode and exit which may clear the error. Hope this helps.
Jan 01, 2010 | KitchenAid KHHS179LSS Convection /...
OTR Amana microwave- No power, lights, clock or sounds.
Either your magnetron, cooling fan, or the magnetron thermostat is failing.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Amana / Whirlpool customer service is here.
Please contact them to find your nearest authorized service center.
Jun 06, 2009 | Amana Radarange Microwave Oven
Microwave oven ACO1860AS
just aquired one just like it for free. they said no heat. took the outer cover off. about 12 screws. pull the main fuse and test it with a continuity tester.thats probably not it if the lights work. its either the magnatron (toshiba 2m248j(gs) or replacement part amana 8205460. mine was a coroded magnatron connection.unplugged it and pluged it back in. heats fine now. if you left it on with nothing in it for any length of time you blew the magnetron. universal magnatron replacements on ebay are $25. 4 screws and a 2 prong connector.
Aug 11, 2008 | Amana ACO1860 Microwave Oven
My display reads -SE-
-SE- error means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jul 28, 2008 | Amana AMV5206 Microwave Oven
Repair an Amana microwave
My amana micro just went dead. No lights nothing ,almost like a fuse blew.Its an over the stove model . The outlet works fine.#mvh210w
Dec 21, 2007 | Amana AMC6158B 1000 Watts Convection /...
Microwave timer going too fast
I had the same problem and found that the "demo mode" had been enabled. Turned it off and everything worked fine.
Nov 10, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
Microwave Ovens Logo
233 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
