Where can I get the free manual for a Pelonis Oil Heater, model HO/02180605?
Glenn
SOURCE: pelonis model HO157C0110 will not turn on
Bypass the 3 way (hi, med, low) switch, unfortunately it'll always be in the high position when you do this. I have done this with one of my heaters and as long as the thermostat is working properly then it will work as it should on the high setting. I took the extra step of connecting the LED light to the bypass so I know when its on.
Just remember to turn it off you'll need to unplug it.
SOURCE: looking for manual FOR PELONIS HEATER MODEL#
You can find your manual here:
http://www.pelonis.com/oilfill.htm
And for electric type you can get it here:
http://homeappliance.manualsonline.com/manuals/mfg/pelonis/hb211.html
SOURCE: i need a switch for my heater,how do i order the
http://www.pelonis.com/service_first.htm go to this link and about the second paragraph down are the instructtions for ordering parts, getting ready to do the same thing myself.
SOURCE: What kind of oil do
Those units are factory sealed and cannot be filled/refilled...
Here is a tip that I wrote about that..
Oil Filled Radiator Heater Leaking
heatman101
