Question about Flat Panel Televisions
LCD Ghosting I have an unbranded 19" LCD TV/Monitor that has a serious ghosting problem. It seems to show two images. EG if I am viewing my PC through it , there are 2 images of the mouse moving around and anything else on the screen. I have been through every control possible.
SOURCE: Blue ghost image in middle of the tv
I am going through the same thing( only my cloud is red)generally a crappy picture and all hued in red and pink After waiting on the Sears Service tech for a week and a half, showed up this morning and said: " Yep, another Light Engine " He did something in the service menu: "memory reset" to make the TV somewhat watchable while the LE is on order. He was going to order the same(defective) light engine until I gave him the Upgraded Part number from Hitachi: UX22202DR for the 50V500. My tech seems very knowledgable and agreed right away to order the correct part and schedule me for service( He said he has done numerous light engine replacements on this model and it takes him about 2 hours to do this in my home. I am really glad I have a extended warranty as this repair would have cost well over $800. Hope this helps.
Posted on Oct 09, 2006
SOURCE: Problem w/blue "bleed" on LCD TV screen
Sony has acknowledged this problem as being a defect in the optical block and has extended the warranty replacement on this part till december 2008. I have the kdf50we655 and had the same problem. It was repaired for free, but would have cost me about $1500.
Posted on Mar 23, 2008
SOURCE: Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Posted on May 05, 2008
  • 109 Answers
SOURCE: Samsung Model: HP-R4262 42" Plasma Problem, pink pixelation/ghosting
Wow, I've been an installer and salesman in the consumer electronics industry since before the first plasma TV came out (Phillips 42" and Fujitsu 42" in 1996) and this is the first time I've ever seen that kind of an answer. "Take this to a repairman and he can add more plasma" what is the repairman a doctor. If it were that easy no one would ever have to upgrade or replace their screens. You can't add more plasma to a screen, if you don't believe me call Samsung and ask them for yourself like I did. I was actually so dumbfounded by your answer that I called a tech friend of mine at Samsung and asked him, his answer; "does this guy work for you?" I told him no and he said, "I was going to tell you to fire him because that's the dumbest thing I've ever heard anyone tell a customer".
What you need to do is take you plasma TV to an AUTHORIZED Samsung dealer/repair shop and inquire about the hazing/ghosting problem with them. Follow this link to find an authorized repair center near you:
Posted on Jun 19, 2008
  • 3 Answers
SOURCE: Magnavox 19mf337b 5 months various problems power off, ghosting, alarm noise
I am currently working on this model set and have discovered the same type of problems. Fix: 4 capacitors in the power supply section on the main board were defective (bulging out). Common problem with counterfeit parts that originate in China. See for details.
Posted on Jul 12, 2009
  • 28 Answers
SOURCE: Sony Bravia with really bad ghosting
The little board on top attached to panel.
Posted on Jul 05, 2010
0 characters
1 Points
Whats causeing ghost image on vizio e390i-a1
don't know this item but guessing its a tv and ghosting on tv is usually initially an antenna problem.
Sep 25, 2016 | Vizio L32 32 in. LCD HDTV
Ghosting lines on a samsung LN40A630M1F
The TCON Board or the LCD panel is faulty. Can confirm only by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
May 16, 2016 | Samsung Flat Panel Televisions
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Sony bravia 52 kdl xbr ghosting
Michael, does the ghosting go away of you tap the set? Or if you turn off the set and let it cool off and turn it back on, is the ghosting still here? One of the most common causes of ghosting or double image problem is due to a defective LCD panel tab. Sony's are known for this problem. I would recommend getting a diagnoses done on the set to be sure. If it turns out to be a LCD tab problem, the only true fix is to replace the panel.
Nov 24, 2012 | Sony BRAVIA Flat Panel Televisions
Ghosting image on samsung led tv in 3d mode
well i think i have got something for you...try the link samsung lcd tv ghosting
Oct 09, 2010 | Samsung Flat Panel Televisions
How do i get rid of ghosting effect?
Your time line setting should be the same as highest video clip frame rate. Ghosting is caused by using higher frame rate than time line, eg. 60frmps in a 29.97frmsps time line.
Jul 20, 2010 | Flat Panel Televisions
Jul 05, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
I bought a Sanyo 26 in lcd hdtv 7 months ago. No
Try explaining the problem to the manufacturer. They will help. They may change the software if needed. After the guarantee it will become a payable service.
May 24, 2010 | Sanyo DP46849 46 in. HDTV
FPD2185W Gateway Monitor
its still ur power chck for swollen fillter capacitors
Oct 17, 2008 | Gateway FPD2185W 21 in. LCD Television
Flat Panel Televisions Logo
151 people viewed this question
Top Flat Panel Televisions Experts
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
