My cp has no sound mixer thats why my pc has no
My cp has no sound mixer in it, it play video but it always requires sound mixers,but unfortunatlely, my pc have no sound mixer, thats my poroblem.
    Sergeant:
  • 157 Answers
Try downloading sound mixing software
http://www.mymusictools.com/free/sound-mixer-software.htm
Posted on May 19, 2009
I am hooking up a Behringer xenyx 1002B Mic/Line Mixer to my Toshiba Satellite c885-S5194 laptop to broadcast online via meridix. I'm using Audio technica BPHS1 Headset Microphones with XLS plugs and 1/4...
IF your Laptop has a stereo LINE 1/8" INPUT jack, you can take the Stereo ( Left & Right ) LINE outputs on your mixer and feed into this jack on your PC. You will need a 1/4" dual plug for the mixer end to a single 1/8" stereo plug on the PC end. I suspect the problem you are having is either related to your PC only have a MIC input jack or you have something set wrong in your PC's sound config. file. More information is needed to properly solve the problem.
Oct 18, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Mixer will only play through one speaker; this is same with organ, microphone and ipod connected. Swopping jacks results in speakers swopping proving that woring is good, but mixer will not play both...
Sounds to me like either an open wire or a blown speaker. I would highly recommend not operating it until it is fixed before you blow the amp. Tapping a 9V battery across the speaker (disconnected from amp) will cause a noise in the speaker, if not it is a broken wire or bad speaker. Good Luck
Jun 06, 2013 | Behringer XENYX X1832 USB Mixer
No start up music when opening media centre
A. As you have stated that "music plays just fine" and you also said that "there is absolutely no sound", so I am a little confused on this issue. Could you clarify whether you get any sound while playing a song/video on Windows Media Center or is it an issue only with the navigation sounds on Windows media Center? B. You may check the Volume mixer settings for the Windows Media Center.
Cross check the settings.
Here is how:
1. Right click on the Speaker icon on the task bar.
2. Click on "Open Volume mixer".
3. In the Windows Media Center mixer drag the slider down till you get the adequate sound.
Mar 26, 2013 | Audio Players & Recorders
My 800 watt powered mixer was working fine until a keyboardist plugged in his keys and amp. The sound would fade out. When it was unplugged, it worked fine. Later that even, another DJ with an 800-watt...
All sound equipment has to operate without overloads in any given place. The power source should always be examined at commercial gigs and worked out with other performers along with management. The only fix is to do these checks up front and make safe arrangements.
Mar 18, 2013 | Music
I have a mackie cfx 16 mixing board.My problem is that , the only way I can get a good signal to the led's for each channel (0 db) is to turn the gain up so high on the channel that it constantly...
No reason to worry about getting signal to the LED's... you set the trim gain so the loudess sound or signal that can happen barely clips or is slightly less. That is the starting point. Watch videos on mixer setup on YouTube. DOn't worry if their mixer is different as the principles are the same.
Mixer fadrs should be around 80% up when system is balanced. ALWAYS use BALANCED cables... eithrt XLR or TRS.
Aug 21, 2011 | Mackie CFX 16 mkII 16 Ch. Compact SR Mixer...
I am trying to record with my mxl 990 micrphone onto my laptop but when i try to record no sound is heard
you can't just plug and play with these high end mics. You require a +48v phantom power source from something such as a mixer. Then plug the mic into the mixer and the mixer into the LINE IN on the PC
Jan 07, 2011 | MXL 990s Professional Microphone
I have a behringer EP1500 amp, connected to a behringer mixer VMX100. i am getting a popping sound, the sound is random, it happens at various times, so i cannot say it always happens after i have...
hi,
check the power outlet socket to which the amp and mixer is connected. if there is any loose contact in that power socket, this problem can occur. try to use a good surge protector with emi filter for connecting the amp and mixer.
ok
Dec 29, 2010 | Behringer Audio Players & Recorders
Grinding sounds and slower mixer speeds
It sounds like you may have a broken worm gear inside your mixer which is a common problem.It is a wearable part which transfers the power from the motor to the main drive. It may be chipped or damaged right now, and running it will cause more damage. Part number for the worm gear is W10112253. This does however require some know how to replace. Hope this helps
Thanks
Nov 21, 2009 | KitchenAid K45SS Classic Stand Mixer
My KitchenAid mixer makes a sound like it needs oil or lubrication. Please advise.
Kitchenaid mixers are overpacked with oil to last the lifetime of the mixer, and do not require lubrication unless you have lost in excess of .25 cups of oil.
Please post any tell-tale signs that are indicating to you that a replenishment of oil is needed.
Jul 04, 2009 | Food Mixers
Computers & Internet Logo
223 people viewed this question
David Payne
David Payne
