Question about Nursery Pro Inc 75gph Statuary Pump
Pond pump trouble
I have a nph 1200 pond pump. I plugged it in. I hear it trying to spin. but nothing is happening. How do i fix it?
    Problem Solver:
  • 14 Answers
Take it apart and clean it with vinegar, then rinse with plain water. make sure to take the impeller and shaft it's on, out of the little cavity and give that a good wash too.
Posted on Jun 14, 2009
Starter just spins
The replacement starter may not be engaging the ring gear completely or at all. Sometimes it is necessary to shim the starter to fix this. Another possibility is that the starter attaching hardware is loose, allowing excessive play.
Nov 14, 2013 | Polaris ATV
I have a brand new hozelock easyclear 6000 pond pump. When I plugged it in.....nothing!. Outdoor electrical socket working ok. The pond is newly built so their are no leaves or sludge in the pond, in-fact...
Sorry to hear of your setback but hopefully we can get you back to worrying about your pond occupants rather than the equipment. First remove the filter cover and filter and give the impeller a gentle turn to feel if the bearing or motor is jammed. If it turns freely try powering the unit to check if the impeller turns, sometimes the impeller needs a little bump to get it moving at first. If nothing still happens return the pump for a replacement.
Mar 28, 2011 | Imperial Garden Products OSI Submersible...
How do you replace a broken power cord
due to the seals involved and the increadable possibility of leaks happening i dont recomend that you try replacing a power cord on a submurged pump, the risk of shock is just to great for the benefit !! the plug end now that can be replaceed however , contact any licened electrician they can handle that for you.
Jul 17, 2010 | Little Giant 5-MSP Water Wizard...
Pool pump only makes a buzzing noise when plugged in.
I think one of two things is going on ...
a) you spun the impeller. You say you have an air bubble in the strainer basket ... you probably also have air in the filter. When this condition exists ... and when you turn the motor off, the air, under pressure, wants out so it spins the motor in the reverse direction. If you turn the motor back on before the motor stops free turning backward, the the jolt spins the center out of the impeller. If you turn the motor off, you should always wait 15 seconds (maybe longer) before turning the motor back on. Listen to the motor. Also be mindful of the air in the filter, bleed it off when you find it ... seal the places where air can get in on the suction side.
The same thing can happen if you experience a quick power failure ... power off for a second and right back on. It is no-bodies fault ... just happens.
Remove the motor from the pump body. Remove the back cover on the motor. loosen the start capacitor so you can get a open end wrence on the flats of the armature. Remove the broken impeller with channel lock pliers or similar.
b) the start capacitor may have failed. To fix this, find the capacitor in the back of the motor. Replace with the same. Purchase from your pool supplier.
Thanks for your interest in FixYa.com
May 31, 2010 | Waterway Above Ground Hi Flo Pump
Why won't my washer won't spin or drain
If the water is not removed first, the spin will not occur. Do you hear the pump run when it starts the spin cycle? If nothing, the pump may be jammed with debris, or the motor itself may have failed. If the motor runs, but no water comes out of the drain, then look for a kinked drain hose (inside the cabinet) or possibly a stray sock lodged in the drain outlet under the outer tub. Sometimes the pump impeller will come loose from the motor shaft causing loss of pump action. Hope that some of this helps!
Apr 06, 2010 | Tecnik TKL9260 Front Load Washer
Sprinkler system, pump makes humming nose but never turns on
Make sure the water to the pump is turned on.  If it is then it sounds like the pump may have to be replaced.
May 19, 2009 | Garden
Nursery pro water pump nph 1200 i stopped it last autumn... i try to retart and and i ear the sound, but the pump dont start to spin... i unmount the pump and casing... do we have to put oil ou grease on...
First, the reason you are having this issue is that you let the pump dry out during to off season. I know it would not seem this simple but the seals in all underwater pumps must stay wet once they have been in water or the metal shaft parts rust and prevent the pump from spinning. So going forward, get a old 5 gallon bucket, put the pump in it, and fill with water over the off season. I too leaned this the hard way.
Now for the pumps you have. With some careful disassembly, you might be able to save them. Please make sure you have unplugged the pump! Turn the pump over and remove the 6 screws holding the bottom screen and impeller on. The cover is held on by a gasket so carefully pry the over off. If you are really lucky, you will find a rock binding the pump. I know, not that easy.
Next you will see 4 screws deeper in the housing. Remove them and seperate the bottom half of the housing from the motor. Now you can see and clearly work on the removing the impeller and berring seals off the shaft.
This is where you need to be very careful to remember how all the parts go back together. You will find metal washers, rubber seals and ceramic seals. They will all seperate if you are very careful. Pry very carefully on the rubber and ceramic seals. THEY WILL BREAK and then you are done. Also, there is a spring which is not under much tension but if you are not careful, some of the parts will spring off when you get them free. If this happens, you will ask yourself, why did I not look closer at how it went together.
Maybe try the CSI approach. Take digial pictures at each step so you can have a reference.
From here, you are on your own. Clean all the rust off the parts. 600 grit sand paper will be needed to clean the motor shaft - it will be rusty and pitted. Just be careful, just take the high spots off.
So finally, here is the disclosure. Of course there must be one. I have saved my pump twice before I figured out the water in the bucket trick. When I reassemble my pump parts, I coat them in a clear silicon grease used for bicycle parts. Non of this is anything official and probably not what the company would agree to. But before you throw away another pump, it is alwasy worth a try to fix it.
We all really need to find ways to fix things before throwing them away.
Good Luck!
Next remove
Apr 04, 2009 | Aquascape Designs Nurserypro - Pond...
Whirlpool Duet Washer won't spin
Sounds like the whirling noise is the pump, pumping. Does it drain at all? Check the drive belt and make sure that it is not broken. This system uses a drive belt with a clutch system to agitate back and forth. The clutch system could be bad as well.
This might not be a cheap fix, these are the main components of the system
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Nursery Pro Inc 75gph Statuary Pump Logo
180 people viewed this question
Top Nursery Pro Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Nursery Pro Garden Expert? Answer questions, earn points and help others
