Question about Microsoft Windows XP Professional for PC
My PC use Windows XP Professional. It automatically changes the date to 22 January 2004. I have replaced the CMos battery, but still the same. I manually adjust the date, but after a few minutes the date is back to 22 January 2004.  I have recently updated Windows and have also installed malcious Malware remover from microsoft. It detected nothing. I have copied a few music files from my PC to my notebook laptop via  my flash stick and now my laptop also changes the date to 22 january 2004. It causes problems with my mail being sent and received as being 3 years old and with security certificates when visiting web sites , etc. Please help me.
  • 84 Answers
Check your bios and set the correct date there also. If this does not solve your problem check for a virus by running a scan with your antivirus program. If you do not have an AV Software Program check out this one which is very good
Posted on Oct 16, 2007
0 characters
3 Points
Date & Time Problem
First, you need to have administrative rights to change date and time.
Check whether you are part of admin group or not. To check click on start and click on run, type "control userpasswords2" and hit enter. It will display user information, make sure you are part of administrators group. If not, try logging from administrator and run the same command
"control userpasswords2" and click on your user name and click on properties, go to to group membership tab and select others and then select administrators. This will make you part of administrators group. If this doesnt solves you problem try the CMOS Settings.
Try changing the date & time from CMOS settings. To go to CMOS Setup, restart the system and there will be options highlited to go to setup.. ( eg press F10 Steup ) and play around only date and time setup. Rest if not known to you, do not change anything.
May 15, 2010 | Microsoft Windows XP Professional
Date & Time Problem
your cmos battery may be going bad. If you pull the side cover off of the desktop it should look like a big watch battery. Usually when the battery starts to go dead the pc clock is the first thing to go.
Mar 30, 2010 | Microsoft Windows XP Professional
My computer date and time changes every time i log on. most times it reads 1 / 01 / 2003 what can i do ? thanks Jim
Change the CMOS battery Jim. It's located on the motherboard in a Desktop computer.
The battery is about the size between a US nickle, and a quarter. Has CR2032 on it.
You can go to stores that sell watch batteries, and ask for a CR2032 battery.
Unplug your computer from the surge protector before you do.
More info for identification of the battery,
Oct 17, 2009 | Microsoft Windows XP Home Edition
Bios problem
change the cmos battery. and then get an antivirus scanner like kaspersky and then download combofix and run it
Nov 28, 2008 | Microsoft Windows XP Professional With...
Date and time error
Hi ya, yeah, my first suggestion would have been to change the CMOS battery, and if you are sure that the one you replaced is new and well charged, then the next thing I would be checking is the time in the system BIOS (rather than using Windows). If you know how to access the BIOS then try changing the time there and then reboot. Power off your computer and turn it off at the wall for a minute or two and then turn everything on again. If your date and time are still correct then you've no more problem (hopefully!). If however, your date and time still change afterwards upon leaving Windows, it is -possible- that there is a 3rd party application on your system that is changing your time/date. If you want to count this possibility out, then take a look at any of the icons in the bottom right of your windows toolbar (beside the clock) to see if there are any new/weird applications running that have anything to do with time or date (some applications adjust your date and time based on your locale and a server on the internet to save you the trouble of ever wondering if your time is right etc.)
Hope this helps point you in the right direction.
Nov 16, 2008 | Microsoft Windows XP Professional With...
Date and time change
It appears that you have the wrong time zone setup. Right click on the time in the taskbar, select Adjust Date/Time.
Make sure the time zone is set for your location.
Sep 16, 2008 | Microsoft Windows XP Professional
Date time problam
your cmos battery on the motherboard (CR2302) needs replacing, it looks like a large flat watch battery, just flick it out replace with a new one, reset the time and date and it will be ok after that
Sep 08, 2008 | Microsoft Windows XP Professional With...
Time and Date Setting
There is a lithium battery in your computer that needs to be replaced. If you open up your coumputer, look for a round looking battery about the size of nickel.
Jun 30, 2008 | Microsoft Windows XP Professional With...
My windows xp keep rebooting after shutdown
You should be able to change this setting in the PC bios menu. Windows XP should interact with this and change it automatically, but it occasionally doesn't. If you have trouble finding the appropriate menu and changing it, please post back with details of your PC (ideally motherboard make and model) and we can hopefully talk you through it. When the computer starts up, there should be a screen before the windows XP screen which says something like "press f8 to enter BIOS setup", but all machines are a little different. If you can get into the BIOS setup, only change things which you are sure you know what they will do, or you can cause all sorts of problems. Hope this helps, post back with system details if you need more :)
Jul 02, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional for PC Logo
90 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
