If your Lorex LHV1000 HD DVR is not booting up, there are a few things you can try:
Check all cables and connections: Ensure that all cables are securely connected to the DVR and that there are no loose connections or damaged cables.
Restart the DVR: Disconnect the power cable from the DVR, wait for a few minutes, and then reconnect it. Try to power on the DVR again.
Reset the DVR: If restarting the DVR doesn't work, try resetting it to its default settings. This can be done by pressing and holding the reset button on the back of the DVR for about 10 seconds.
Check the hard drive: If the DVR is still not booting up, it could be due to a faulty hard drive. Try removing the hard drive and connecting it to a computer to check if it's still functioning properly.
If none of these steps resolve the issue, it may be necessary to contact Lorex technical support for further assistance.
You cannot connect the two directly. The IP address can be found in the setup page of the DVR, You then type that address into your browser to get into the DVR. The DVR must be connected to the internet using a port on the router.
Hi, In order to record from VCR to DVR You need to connect "VCR audio/video output RCA jacks " to" DVR 's Audio / Video Input RCA jacks.. .. use either "RCA analog (red/white+ yellow ) " or
"optic " cable.(any standard optical cable )..if exist .optic is the best way to
connect it..Remember your VCR 's "OUT" goes into" IN "of DVR .. pls also
remember,wherever you connect your VCR on your DVR ,you should switch
the source selector accordingly to correspond to the connection on the
back... Now you can record anything on DVR which played in VCR .. Hope this helps!..if more help requires pls let me know. Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Do you really have TV Audio OUT to a DVD (last sentence)?
Most DVR's have digital and analog audio outputs. Since every device they are intended to feed would have its own volume control a DVR output volume control might be redundant. Treat a DVR like any other audio device. Connect it to any available input on the receiver EXCEPT PHONO.
If you run the audio from the DVR (and EVERY video source) directly to the STA-795 you can bypass the TV and its questionable audio electronics (yuk). You can split the analog output of the DVR with y-cables and run it from the DVR to TO the TV for casual viewing and listening through the TV sound system (news, Oprah, etc).
See if your TV has an audio out socket at the back. If so connect this aodio out to the DVR to record the sound . If not buy a pair of ( one for Left channel and the other for Right channel ) one is to two Y connector and plug the jack to the DVR and connect the split ends to the TV and Motorola DVR. That way you will have sound going to TV & DVR
It depends on your DVR. In most cases, the answer is NO, unless you have a DVR that accepts an RJ45 (similar to the one used in your computer to connect to the internet). SOME DVRs can be connected to an ethernet hub, and if you connect your computer to the same hub, you MAY be able to access it. Once again, it depends on the specific DVR model you have.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Just connect the output of the DVD to the DVR and the DVR to the TV. Unfortunately, you'll have to have the DVR on to play the DVD but if you have the DVR why would you need to play on the DVD but just to use it as a source to the DVR.
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
