Question about Microtek 710S 17" Flat Panel LCD Monitor
Dialogue box in the middle of the screen
I have a Microtek 710S 17" flat panel LCD monitor that's great except for a purple box in the middle with the words "out of range" in it. What can I do to get that removed? This is a used monitor.
Thanks!
    Sergeant:
    Novelist:
  • 197 Answers
Out of range usually means that the computer is trying to use a resolution that is unsupported by the monitor. Try loading the PC in safe mode (for windows, press F8 before windows loads) and change the desktop resolution to 800x600, which is supported by pretty much any monitor. Restart the computer normally and you should get your video. Once inside windows you can experiment with different resolutions, and when it goes out of range, just wait 15 seconds for it to go back to 800x600.
Posted on May 15, 2009
My Microtek 710S Monitor screen goes black if left unattended for one minute. What do I do to keep this from happening?
Check the power setting of your PC.
  • If you are on windows;
  • Click on start button
  • If you have vista or windows 7, type "poweroptions" into the search bar.
If not, open control panel and find the power options inthere
  • In "power options" you can change when the displaygets turned off and when your PC will go to sleep, just change these settingsto the time you want, e.g. 2hours
I can offer support for other OS if required
Mar 02, 2011 | Microtek 710S 17" Flat Panel LCD Monitor
I want to quit using the Realtek speakers that I added to the computer and go back to my monitor speakers, but now I can't figure out how to get them to make a sound.
You just have to connect the audio input of the monitor to the audio line out of the PC using an shielded audio cable with mini-stereo phone plugs at bothbudmrtn_13.jpg ends.
Jan 04, 2011 | Microtek 710S 17" Flat Panel LCD Monitor
The colors are off
Red, or green, blue cast? Check all the pins of the VGA cable first, and also try it with another PC to make sure it is not video card problem.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 28, 2010 | Microtek 710S 17" Flat Panel LCD Monitor
I have a Microtek 17 in monitor and recently it has started to flicker badly when switch on after a couple of minutes it settles down to normal. Can you offer any comments re fixing this problem? Many...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 05, 2010 | Microtek 710S 17" Flat Panel LCD Monitor
How to repair monitor
What is the problem with monitors? Flashes on then goes black? See example of failed (most) monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 04, 2010 | Microtek 710S 17" Flat Panel LCD Monitor
I have a Microtek 710S which suddenly will not show anything other than a black, blank screen. When I turn on the button in the bottom center of the frame, it alternately changes color every second or...
Does it show any sign of life when you poweron the PC? With the PC powered on, remove the data cable of the monitor (yes the D plug) from the PC and insert it back. See if there are any signs of life. If there are any signs of life, reboot in safe mode by pressing F8 at bootup. If it boots in Safe Mode, then go to Control panel->Display->Settings->Advanced. Remove the Monitor and let windows detect the monitor. Same thing can also be done from Control Panel->System->Hardware->Device Manager-. Monitor. Remove the monitor and from Actions select Scan for New HW.
Oct 02, 2009 | Microtek C783GM 17" Flat Panel LCD Monitor
Microtek 710S 17" Flat Panel LCD Monitor Logo
183 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
Michael Deni
Level 1 Expert
ray gallant
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
