I own and have a working ENHWI-G3 Rev A3, but have lost the setting for re doing the settings. We are getting ready to travel and need to secure the settings with WEP. How can I go back to the default and start all over once again. Can not get pass the sign in screen with 192.168.1.1. Thanks Ann
    President:
  • 623 Answers
Look at page 6 of your router manual. (In case you don't have one, you can get it here.) Hold the reset button pressed for about 10 seconds, so all the little electronic units can reset. This will bring the router back to default. (The default username and password are “admin”.)
PS: why do you want to use WEP? Use WPA or WPA2 if you are concerned about security! Just google "hack WEP" and you will get more than 1 million results. It is really not secure anymore.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on May 15, 2009
How to set up enhwi-n3 w/o cd installer?
A router does not need a driver. The wireless card or NIC in the computer might need one to talk to the router though.
Dec 06, 2013 | Computers & Internet
Cod do radio audi a3 2001? serial no. 18998
IMPORTANT NOTE:
You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of programming for 2001 Audi A3 radio is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Apr 14, 2011 | 2007 Audi A3
I need the WEP security key code for my router in order to hook up a new wireless blue ray, and i dont have a manual
You can get the manual for free from D-link http://www.dlink.ca/products/?tab=3&pid=DI-524&rev=DI-524
Below are my router suggestions:
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue.
4. Check that your router is set to broadcast its' presence.
Nov 21, 2010 | D-Link AirPlus DI-524 Wireless Router
Create wireless security
1.Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the URL web address location.
2. When the following dialog box appears, enter the user name and password to login to the main configuration window, the default username and password is “admin”.
3.Setup wizard is provided as part of the web configuration utility. User can simply follow the step-by-step process to get the wireless Router configuration ready to run in 6 easy steps by clicking on` the “Wizard” button on the function menu. The following screen will appear. Please click “Next” to continue.
4.Set Wireless LAN connection
Click “Enable” to enable Wireless LAN. If user enables the Wireless LAN, type the SSID in the text box and select a communications channel. The SSID and channel must be the same as wireless devices attempting to connect to the WLAN Router.
(When in FCC domain, you could chose ch1~ch11; in ETSI domain, you could chose ch1~ch13)
4. Click on Security.
5.Security
This function enables user to set authentication type for secure wireless communications. Open System allows public access to the router via wireless communications. Shared Key requires the user to set a WEP key to exchange data with other wireless clients that have the same WEP key. This router also supports WPA, WPA2 and WPA-PSK, WPA2-PSK.
6.Set the Security key and save the settings.
7. The Wireless is secured now.
You can find more information in the User Guide.
Here is the link: refer page #26,27,33 to get all the info.
http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-N2_Manual_Cam.pdf
Jun 23, 2010 | Encore ENHWI-N2 802.11n Wireless Router...
How can i put a password on my Encore ENHWI-N2 802.11n Wireless Router?
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Jan 06, 2010 | Encore ENHWI-N2 802.11n Wireless Router...
Problem with Encore 802.11n Wireless Router ENHWI-N2
Well a router that supports 802.11n will also support g.
In any case I am under the impression that your DNS settings might be wrong.
A good router to look at are D-Links, I have been using the DIR-655 for my house see: http://www.dlink.com.sg/products/?idproduct=21&idCategory=175
Enjoy
Nov 30, 2009 | Encore ENHWI-N Router
Cannot fax out security question
the phone company had inadvertently dropped long distance on my fax line. Cannon support identified that as the problem and the phone company got my long distance back and every thing worked
Jun 11, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
HELP
We also have losted our manual and need to reset everything but can't rember how to do it.. Can someone please help me out on this problem. Very much appreciated!!
Jan 22, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Computers & Internet Logo
410 people viewed this question
David Payne
David Payne
