Question about Gateway M460 Notebook
Gateway m460 wont power up and battery wont charge!
    Problem Solver:
  • 17 Answers
From the information you provided it sounds like a bad DC jack, first check your power adapter with a volt meter if you have one accessible. If your power adapter is outputting the proper voltage, then within a 95% certainty its your dc jack. You can look at this website here for more info on dc jack repair, if you dont have the proper tools to fix it.
Posted on May 15, 2009
Push power button it lights up for 3second then shuts off what is wrong with it
Could be bad ac adapter or bad motherboard. Have seen lots of cases where the ac adapter was bad and the laptop no longer starts after the battery goes dead.
Jan 10, 2013 | Gateway M360 M460 M680 MA2 MA3 MA7 CD DVD...
Is the gateway 5412 the same as m460
No, they are different, but may share some components.
Dec 31, 2012 | Gateway M460 Notebook
Gateway m460 battery will not charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 24, 2012 | Dell Latitude C640 Notebook
Gateway m460 powers on but only posts up on occasion help
change its battery or change it parts that are not working and you have seen any problem before then you show it to mecanic
Jan 21, 2012 | Gateway M460 Notebook
Where is the CMOS battery located on a Gateway 460.
I'm afraid it's a part of your motherboard, so you cannot take it out.
Feb 05, 2011 | Gateway M460 Notebook
My gateway m460e wont charge or turn on there are no lights the mother board is dead.what cause this?
Assuming the charger is ok and the battery is ok, you may have a main motherboard fuse which has blown (would explain the lack of power), if the fuse is not the issue, then it looks like there are other damaged components on the board
Jan 10, 2011 | Gateway M460 Notebook
Laptop fluctuates charging/battery while on ac power
HI There,
Your problem is your DC Power Jack that you're plugging into. It's very common with this series. The Power Jack over time starts to pull away from the motherboard (the soldering that holds it fails). It can short out back and forth between only power, only charging, or doing both or doing nothing.
There are several companies on eBay that do the repair for around 60 to 80 dollars including the return shipping. You pay the shipping to them. Go to eBay and in the search box type in "DC Powerjack Repair Replace" and you can select the company of your choice. Check their "Feedback" rating to make sure their not just arrived as a vendor.
I have used several different ones (I'm a laptop repair specialist) and have never had a problem yet.
Good Luck
Jul 29, 2010 | Gateway M460 Notebook
Computer won't boot up
Make sure battery is fully charged.
Remove battery, wait a minute, reinsert battery. Reboot?
Nov 07, 2009 | Gateway M460 Notebook
Gateway 460 freezes or will not come on.
It's probably overheating that's why when you first turn it on it works fine up until a certain point. Does it feel hot on the bottom? Are the fans spinning?
Feb 19, 2009 | Gateway M460 Notebook
Gateway M460 Notebook Logo
422 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
