Question about Dell Inspiron E1405 Notebook
After fdisk and format of hdd install of os freezes after 2min. when it says windos is starting, tried differant versions of windows does the same thing!!!! Please help!!!!!!
After fdisk and format of hdd my dell e1405 will not install the os! it starts then freezes!
  • tommyjg3396 May 26, 2009
    Thanks for asking i have been all over the internet and read a billion forms! with no luck!! so hear is the story! on my dell E1405 i was running vista the laptop needed a clean re-install so i too my boot disc fdisk it, formated the hdd then went to reinstall vista at the very beginning of install windows loads files the in vista it goes to the boot screen and freezes! stays like that for ever! so i tried to install winXP pro, winXp home, win server 2003 and no luck! then i thought it might be the hard drive because i ran dell's disc diagnostic and everything was great no problems, i ran two other dianostic test and they say everything was great except one thing one of the keys was stuck! in the mean time i bought a new hard drive and swaped them out to make sure it was not the hard drive ya know! no matter what i do it's the same thing os just freezes! after load of windows files when windows should start up to configure there settings. so i also have boot order set rigjht and tried a bunch of differant combonation of things that did nothing!! the only hit i have is when i press F12 and boot from network the message says what the chip is then it says PXEmedia faliure, check cable no operating system but in disc and press anykey??? if anyone can help with this i would be forever indet to! thanks T-
  • Jubert Ledesma
    Jubert Ledesma May 11, 2010
    do you get any error message? what os are you trying to install?
  • 52 Answers
PXE media failure means the system is trying to boot via Network card not your hard drive. When you performed fdisk then formatted the disk, you might have not selected an active or logical partitioning to support the OS. Run the PSA diagnostics by holding the Fn button before turning on your computer. If it gives you an error, it means your HDD has gone bad and needs to be replaced. If it freezes during the the loading of files during the installation, it means that your RAMs are bad because the windows loader dumps all the information to the RAM chips. If it does hang during the installation of files, two points of failure are to be looked upon, the RAMs and the HDD. I recommend you reset the BIOS to the factory settings as to reset the boot priority so it does boot to HDD first, not to any of the bootable drives available on your computer.
Posted on Jun 14, 2009
MacBook Laptop Will not boot from CD and OS freezes during setup
Since you have an Intel Mac book you can boot to DOS 6.22 and use Fdisk to remove your partition at which point you can format it and install Mac OS.
Apr 12, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Need to load xp on gateway
Do you have a full installation disc or an Upgrade version of XP? The full install should give you an option for partitioning and formatting the new hard drive as part of the installation process. From Microsoft, read this page for details:
http://support.microsoft.com/kb/313348 . You may need some additional drivers if you have a SATA hard drive. More screen shots and details are here: http://www.theeldergeek.com/hard_drives_03.htm .
An alternative way of dealing with the problem may be to use a third-party Partition Manager software (Symantec's Partition Magic, Paragon's Partition Manager). Paragon's site is
http://www.partition-manager.com/ . This site has various levels of Partition Management software (with different features available in the more expensive versions). You'll need the bootable CD version of the software (recovery disc, .iso) to do the partitioning.
I hope this helps.
(I thought the upgrade version could also be done to a new hard disc including the partitioning; all you needed was a Win OS disc from an earlier version to prove qualifying ownership.)
Feb 20, 2010 | Gateway 700 X PC Desktop
IBM NetVista M41 PC Desktop Os Install Impossible
You probably need an OEM version of XP...not that IBM version. If you buy an OEM version, you can use it many computers. A real XP disc will partition, format, and delete partitions on any functioning Hard drive. Don't buy a recovery disc, please. That just sounds WRONG.
A cheaper solution might be a new Hard Drive...but I don't trust your IBM version of XP.
Apr 07, 2009 | IBM NetVista PC Desktop
Presario cq60 104tu
The master boot record maybe be corrupted or virus infected.
To fix the MBR, boot up with your DOS disk and type fdisk /mbr
Then install XP, and delete all partitions and then create a new partition, then do a full NTFS format on the new partition.
Feb 27, 2009 | Compaq Computers & Internet
HP NC6320 - drive not detected or found during OS install
That is a possibility that it has a data protection. Try this http://www.ptdd.com/manual2.htm download the super FDisk and burn the ISO to a DVD. then boot off of it and delete all partitons on your HDD that way it will be erased so you can start over new. You might be able to do this on HPs boot disk too. Unfortunately you cannot update the HDD firmware after the drive has no OS on it. In this case you need an outside tool to totally erase the HDD so the install can see it again.
Feb 03, 2009 | HP Compaq nc6320 Notebook
Freezing up when installing winxp pro.
MAY BE THIS COULD HELP. PUT YOUR LAPTOP IN FRONT OF A FAN, THEN TRY TO FORMAT IT AGAIN, IT SOUND FUNNY BUT I FACE THIS CASE MORE THEN 3 TIMES, THE LAPTOP JUST TOO HOT DURING THE INSTALLATION (PUT THE FAN WITH LEFT SIDE FACING THE FAN)
JUST SHARING=)
Jan 25, 2009 | IBM ThinkPad T21 Notebook
Hp laptop has failed to start windows
Hi , You need to run Format the drive before you install Windows.
Jan 05, 2009 | HP Pavilion ze4200 Notebook
I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate barracuda7200.9 80 gig.
Some of the following answer assumes a windows operating or possibly DOS based operating system. If your original OS was not Windows or DOS -- there may be different considerations.
1) Did you lose the contents of both partitions?
That depends were they soft or hard partitions.
Soft partitions are created as files inside of other partitions
If that is what you had allocated in the formatted partition
you have lost their data content.
Hard or physical partitions allocated using FDISK and some other utilities the second partition would still exist.
2) Where are/were your system files. Often but not always they appear as the first partition of the master drive on the primary IDE controller all assuming a PC (based on the master slave comments you have indicated.) (sometimes the second when diagnostics are loaded on the first partition)
a) if the partition on the drive you formated contained the system files yes they must be installed to access anything on the disk for the most part. A significant exception may be utilization of a DOS boot diskette might permit DOS access to the other partitions if they are formatted with the FAT file system.
NTFS partitions and possibly FAT32 partitions may not be accessible to all versions of DOS -- there may be some bootable CD's that would allow access to NTFS partitions without installing an operating system.
Question back from the DOS and older version of windows days and even some more modern operating systens in subsequent actions with the disk did you use FDISK or another utility to rewrite the boot blocks to point to a different partition?
Question this was not a dual boot machine was it?-- if so disregard anything that follows.
Question did the machine boot after formatting the partition and before you started moving the drives around? If so the operating system is probably on a drive you have removed from the machine. It needs to be replaced onto the same cable position it was originally located upon -- probably on the Primary IDE cable master position or jumper setting.
If not reinstallation of the operating to the formatted partition is probably the correct next step. Be careful in doing this because if you choose one of the other partitions that were not formatted it could wipe out the data in them based on the installation process chosen.
Dec 10, 2007 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
Dell Inspiron E1405 Notebook Logo
137 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
