Question about SAMTRON 55V 15" CRT Monitor
Monitor displays only horizontal line
Sir
 i have a computer and some days before my 15inch colour monitor showing some bright white line in the middle of monitor ocassionaly
also sometime its colour gets changed
plz reply
  • 1 more comment
  • subin Oct 16, 2007
    idont no the vertical section and color section
    can u tell the ic num or which region in board of both vertical and color section
    sir wat is purety ring plz
    sir can i get a pictural arrangement of monitor
    i mean block diagram or circuit diagram that represent all section vertical color and all
Colour changed ,problem is in crt neak card (dry soldring )it is solder proper then color problem solved
Posted on Apr 21, 2008
  • mustaq Apr 21, 2008
    dry sholdring of vertical ic stv9302h ckt or dry soldrin on vdc yock ckt.
Hey bro.
you try to re solder the vertical section and the color section.
Posted on Oct 16, 2007
  • almer Oct 16, 2007
    and also the purety ring.
My moniter screen go's dark with a bright horizontal white line in center ..it flickers
the driver board is bad in the monitor. Has it been in a place that is super hot like in a car? If the verticle driver chip disconnects from the matrix driver array, it will all squish into a single line in the middle of the screen like you are describing.. might try opening and blowing where the driver board connects to the LCD matrix (bunch of connectors on a plastic flat cable/bus connecting to the end of the LCD panel.. heating them could allow them to reconnect.. Its worth a try, right? It has worked for me about 60% time.
Feb 03, 2014 | Envision Computers & Internet
Monitor
Try getting anything that may have a magnetic field away from the LCD (speakers, phones, any electronic product), does the problem persist?
Jan 08, 2008 | Samsung SyncMaster 245BW Monitor
Down the left hand side of my monitor a column of mishapen small horizontal lines are slightly visible when the monitor show slight colours . they are harder to see when it displays white how can i fix...
Assuming that you have tried the monitor on a different computer and that the pins on the VGA lead show no damage or signs of looseness and that the vga lead is a good fit in the socket, the probable answer is that the monitor is starting to fail. Eventually, the lines will increase in size, or in number and will be more visible. Repairs are usually not worth the cost of buying a replacement monitor instead. My advise is that if you can live with it, thendo so until you decide to get a replacement.
Jul 15, 2011 | E-Machines E17T4 LCD Monitor
24" CRT HP A7217A Monitor stopped working
hello sir your vertical or horizal IC damaged.......... thats why its showing multi colour ...... just do one thing sir.......... fit your new IC
if your problem not solved..... type in comment
Apr 29, 2009 | HP A7217A (White) 24" CRT Monitor
HCL 17" monitor display problem
Hi there ,
It seems that you have a vertical section problem ,It might be possible some capacitor might have gone wrong
Jan 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Display
Maybe it's because the camera is overheated, let it cool off. Or maybe it's because the monitor is broken. If so, then replace it.
Mar 16, 2008 | Casio Exilim EX-S500 Digital Camera
Usercontrol automatically displayed when bootup
Please change the switch pannel  and check
Nov 19, 2007 | HP Compaq FS 7550 17" CRT Monitor
Monitor Screen Bright with horizontal white lines
I have an emachine 17" Flat Panel Monitor and I accidently touched the Standby Mode on my keyboard and now my menu won't work right. I can't adjust the color enough. If there is anything I can do to fix my problem it would be appreciated.
Thanks
Oct 08, 2006 | E-Machines 17F2 17" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
246 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
