Question about Cameras
Won't power up
My canon sd900 just quit coming on. It has been dropped in the past but not recently. The battery has a full charge but when you push power button down nothing happens. Thanking you in advance!!!
  • 3 Answers
Check the battery terminal and make sure there's a
good contact between battery and terminal.
Posted on May 15, 2009
Battery wont charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 04, 2012 | Canon PowerShot SD1000 Digital Camera
Computer just shuts off when i unplug even though shows full battery
POWER SUPPLY & BATTERY PROBLEM
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Jul 07, 2012 | Sony VAIO VPCF134FX/B F Series Notebook
Sd900 won't focus
hey if you hold it still or put it on a table does it still do the same thing? Sometimes it is the setting they are on.
Jun 28, 2012 | Canon Cameras
I have a problem in Samsung omnia B 7610.When I plug in the charger to power source it displayed the battery is full.When I plug out the battery is low and uncharged.Pl help
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 05, 2011 | Samsung Omnia Cell Phone
Can you help got a canon cp900 camera i drop it and it saying lens error restart camera what do i do
Sorry to tell you the the lens is out of alignment. This happens quite often (had the same happen to me). These end up in the repair shop or getting tossed in favor of an ebay or craigslist replacement due to the cost to repair. Good luck.
Feb 11, 2011 | Canon Digital SD900 / IXUS 900 Ti Digital...
No power canon sd900
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Apr 14, 2010 | Canon Digital SD900 / IXUS 900 Ti Digital...
Where to check for the abttery display option
When the battery is low or insufficient the message " Change the battery pack" displays.
You can then insert a fully charged battery into the camera or use the AC adapter Kit to charge the battery.
On long trips, it is recommended to keep an additional fully chaged battery along with you so that you are not caught without any charge!!
Mar 03, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Canon PowerShot, SD900, Using AutoFlash, pictures takes 8 seconds
It takes quite abit of power to charge the flash module. The older your batteries are, or the more drained they are = more time it's going take to charge the flash module.
It requires fresh batteries. If your batteries are not fresh, the camera will still work up to a point (that's why you can still take pictures), but it will take longer to charge the flash module.
You will be able to check this, if you have the A/C adapter. You will find that by using the adapter from a wall outlet, you'll have no problem with the flash time.
This will fix your problem, and you'll get better performance from your camera. Thanks for coming to FixYa, and don't forget to rate my solution.
Rob
Feb 24, 2009 | Canon Cameras
Lens error, restart camara issue in SD900
Hey GeorgiaPlum,
What is most likely happening is there is damage to the lens or the lens mechanism and you should have the camera looked at by an authorized service technician. I will say that digital camera repairs often exceed the value of the camera, but it can't hurt to get an estimate done. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 05, 2008 | Kodak EasyShare C613 Digital Camera
well **** that doesnt sound complicated or anything.
Feb 29, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
