Question about Sunpak 622 Super Pro TTL Flash
Sunpak 622 Recycle Time w/ Batteries vs AD-26
I own a Sunpak 622, and normally use rechargeable NiMH "C" batteries. I regularly have a recycle time of 5.5 sec. at full (1/1) power. Seeking faster recycle times, I purchased the Sunpak AD-26 AC Adapter. Using the adapter, I consistently have a recycle time of 18.4 sec. at full (1/1) power. I'm unable to understand why a constant power source, such as an ac adapter, seems to have less current/power/oomph/or whatever than a set of rechargeable "C" batteries.
That is my situation. I'd like to know if there is a way to "fix" this, and if this is common?
  • Anonymous Mar 20, 2014
    Need SunPak AC Adapter AD-27
  • 65 Answers
I have made Nimh pack which has 2900MAH cells and is very fast recycling.But beware that it will heat up Xenon(it needs cool down time before you fire full power repeatedly.Also its capacitor will be short life due to electrolytic(Same as fast battery chargers ruins the battery life).
And when its production is seized,I care it more.
Posted on Mar 30, 2010
I had the same problem - 10-11 secs on 240VAC. My solution was to get the Quantum Turbo SC for $450. It yields ~3sec recycle times. This pack for $150 should play nicely as well: http://www.adorama.com/JTMBPN.html?searchinfo=jtl+lancer+battery+pck It was out of stock at the time. The Sunpak TR2000 is $250, but it's Ni-Cd while the others are NiMH. There are other HV packs capable of powering the 622 w/ the fitting cable like Lumedyne IIRC. The AD-26 is still useful for non-action photography. The fastest time I saw posted is 1.5 secs, but it's a DIY job (search 'sunpak 622' on flickr). HTH,
Szilard
Posted on Jun 03, 2009
What size rechargeable batteries for the 6 AA's in the RL525? 1.2V? MA size?
From reading others that have fixed this, it is simple NiMH rechargeables at 1.2v, not lithium.
As long as you have a matched set of batteries, the MAh won't matter. Usually the higher the better, it will take longer to charge and discharge and they will last longer (years). I suggest around 1800MAh or better, they don't cost that much more than 1200MAh.
People have wired in battery holders in place of the battery pack, to make it easier to replace next time.
Be sure and recycle your old batteries.
Oct 03, 2016 | Reebok Rl525 Elliptical Resistance...
How long does it take charge the sunpack 510 batt using the qbc-5
Sunpak uses different power sources on their high-power handle mount (a.k.a. hammerhead) flash guns. The most common is the battery basket that holds 4 or 6 AA or C batteries depending on the type of the unit. One can insert Nickel-Cadmium or Nickel-Metal-Hydride rechargeable batteries instead of the primary cells, this way reducing the "consumables" costs at the expense of the smaller number of flashes per battery set. (Actually, NiCd or NiMH cells would probably give smaller number of flashes compared with the alkaline cells, but the recycle time between the flashes can be shorter. The reason is that at charging the flash capacitor inside the flash current counts more than voltage. Sunpak sells Ni-Cd battery packs named CL-2 for their flashes that utilize 6 AA-cells, and CL-3 for their 622 series (4 C-cells). The charger for these is the QBC-5. It recharges the exhausted batteries in 3 hours. As a solution assuring the shortest duration between flashes Sunpak offered the Powerpak, a shoulder holster that held a dry (non-rechargeable) battery of 510V, it charged the flash capacitor directly, omitting the transistor inverter in the flash body. As such battery became obsolete, the Poverpak has been superseded with the NC510 and later the TR-II PAK, which utilizes 10 Ni-Cd rechargeable batteries as a power source, and a powerful (more capable than the one in the flash) transistor inverter. NC510 and TR-II PAK use the same connection to the flash and the same outlook as the original Powerpak but, being rechargeable, are more economical. QBC-5 also serves a charger for the NC510 and TR-II PAK. You may ask, how the same charger can be used for 4, 6 and 10 cell NiCd packs. Well, the charger is specially designed for that, although charging time differs at the different battery packs. The NC510 and the TR-II PAK needs 10 hours to be recharged, when exhausted. The best way to avoid damages (overcharging degrades NiCd and NiMH cells) is to check temperature of the batteries. Charging must be cut off if the battery becomes hotter than 45 ?C (115 ?F). If after 10 hours of charge the NC510 does not power (the otherwise working) flash, then it must be serviced. Replacing the batteries is an easy job that can be done at home, with some soldering skills; NiMH cells with solder tabs are available at many web-based supplyers. Don't solder the cells directly, heat damages them. Avoid touching parts inside, when the pack is turned on: electrocuting is fully possible. Better find a professional, if you are not familiar with the electronics.
Dec 27, 2014 | Sunpak Cameras
How long do i charge a sunpak nc 510 rechargeable using a QBC-5 CHARGER
Jan 08, 2014 | Sunpak Cameras
Does this camera operate on regular AA bateries. Put 2 brand new ones in and it will not power up. The manual says Kodak does not "support" Alkaline batteries....
Probably this old chat may help you to resolve your problem.
From site:
http://www.digitalcamera-hq.com/products/kodak-easyshare-c663
Kodak EasyShare C663 Specifications
  • 6 megapixels
  • 3x optical zoom / 5x digital zoom
  • autofocus
  • auto exposure
  • JPEG file format
  • ISO 100-400
  • 2 AA batteries
  • movie mode w/sound
  • 2.5" LCD screen
  • Part Number:C663
  • Release Date:Jan 12, 2006
chrissy66 (12/10/2007)reply to this comment (by James DeRuvo - 12/12/2007)Sounds to me like your lens may have come out of alignment. Was it dropped recently? Since your camera is still under warranty, the best thing you can do is have Kodak should fix it. If your camera is out of warranty, or if Kodak refuses to repair it for free, the one thing you can try is to try resetting the camera.
Kodak is also of the opinion that lens errors also occur when you use batteries not recommended by Kodak.
I recently chatted with a kodak specialist about this issue and he recommends changing your batteries to NiMh rechargeable batteries. These are the batteries that the camera is designed to use and using other types - like alkalines, can often cause the lens error to occur. If that doesn't work, then the camera indeed does need repair.
Rechargeable Ni-MH Batteries (AA Size): These Ni-MH AA batteries last up to twice as long as alkaline batteries when used in your Digital Camera - and you can recharge them up to 1000 times in our rapid charger.
Oxy-Alkaline Digital Camera Battery (AA Size).
CRV3 Lithium Batteries: A non-rechargeable battery designed specifically for today's feature-rich cameras. This battery is the obvious choice for speed performance, and long life. It delivers faster flash recycle times and lasts up to 10% longer than our previous design!
Ni-MH Rechargeable Battery Pack: Provides exceptional capacity with its 2.5 hour fast charge cycle time; can be recharged up to 1000 times in the EasyShare Camera Dock or EasyShare Rapid Charger,
Jan 06, 2011 | Kodak EasyShare C663 Digital Camera
Canon Powershot A470 - asks to 'change battery' every time it is turned on, then turns off immediately. This is so even when new, fully charged batteries (different brands, rechargeable, non-rechargeable)...
This happened with my Canon Powershot A470. I sent it back to he manufacturer and they said I was using the wrong batteries. Even though the camera is supplied with two alkaline batteries, they recommend using AA NimH rechargable batteries.
Jan 08, 2010 | Canon PowerShot A470 Digital Camera
Goes through batteries very quickly....often reading "low battery".
run a pencil eraser over the battery contacts on the camera, it works most of the time
Sep 07, 2009 | Samsung Digimax 530 Digital Camera
Nikon Sb600 does not fire every time
More than likely it is the flasg tube . Be sure to clean the hot shoe assembly foot well .
Berrie Smith Camera Repair bbmw@bellsouth.net
Nov 17, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon coolpix 4600 long delay to recharge flash
Hey inkfeather,
This camera is notorious for long delays in flash recycle times. One solution would be to increase your iso to around 400. Any iso higher than 400 can result in increased digital noise. Another thing you could try is getting a good set of NiCad rechargeable batteries, because these batteries should shorten your recycle times but once the start to lose their charge they lose it fast so have backup batteries. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 16, 2008 | Cameras
What is the difference between the available AA battery chemistries?
AA batteries are available in four basic varieties: Alkaline Nickel-Metal Hydride (NiMH) Nickel-Cadmium (NiCad) Photo Lithium (Li-FeS2) Alkaline and photo lithium are non-rechargeable, while NiMH and NiCad are rechargeable. Each has advantages and disadvantages. Non-Rechargeable vs. Rechargeable: Rechargeable batteries are desirable from an environmental standpoint because they are reusable. Self-discharge refers to the fact that batteries lose energy when unused and even when not in a camera or other device. Rechargeable batteries tend to have relatively high self-discharge rates, approximately 1-2% per day for nickel-based batteries. Non-rechargeable batteries generally have very long shelf lives and extremely slow self-discharge rates. This makes non-rechargeable batteries a better choice for infrequent usage. Non-rechargeable batteries are available fully charged in stores all over the world, which makes them a convenient choice for travelers or customers who have dead rechargeable batteries and no time to recharge. Photo Lithium Batteries (Li-FeS2) (non-rechargeable): Photo lithium batteries will yield the longest battery life of any AA battery, surpassing NiMH by 50-100% and surpassing alkaline by 100-500%, depending on the load. While they are more expensive than alkaline batteries, their additional energy capacity makes the cost the same or less per shot than alkaline batteries. Nickel-Metal Hydride Batteries (NiMH) (rechargeable): NiMH batteries are the lowest cost overall solution for users that take a lot of pictures (more than the equivalent of a roll of film per month) or use a lot of high-power features. The largest disadvantage to NiMH batteries is their fast self-discharge rate of 1-2% per day whether the batteries are in a camera or not. NOTE: NiMH batteries need to be completely charged and discharged a few times when new to achieve their full capacity. Rechargeable batteries will eventually fail. If you have been getting acceptable battery life and then see a decrease in life, either quickly or slowly over time, a worn-out battery may be the cause. Storing or charging the batteries in high temperature conditions will accelerate this potential failure. Alkaline Batteries (non-rechargeable): Although the cheapest and easiest to find, alkaline batteries yield the worst performance of all the chemistries in a digital camera. They lose capacity at high power drains and at low temperatures. Skiers and other winter outdoor enthusiasts may find them unsatisfactory. Alkaline batteries are frequently available in two types: High drain (ultra, titanium, maximum etc.) Regular The high drain versions are a premium product designed to operate better under heavy loads than the standard product. However, there is a trend of major brands to increase the performance of their standard battery to b
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Sunpak 622 Super Pro TTL Flash Logo
855 people viewed this question
Top Sunpak Cameras Experts
Doberman
teddyboy
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
