Question about Gateway M-6843 Notebook
Will to bootup freezes after memory check
Replacing cmos battery on a m6843
I have an Emachines ET1161-07 which freezes at the E logo. the only way to even reach the BIOs is to remove and replace the CMOS battery; doing this only works once and then the computer freez
This might be a dodgy stick of memory or memory slot. If you have more than 1 stick of memory, see what happens if you just use variations of just 1. Maybe try disonnecting all drives except the one you boot from. And, not sure exactly what you mean by works once and how far it gets after removing the CMOS battery. But does it get far enough to boot from a cd? If it does, try getting hold of a AVG rescue disk this will run a pre-boot virus check which may clear the problem if you're lucky. Obviously you would have to use a friend's machine to burn the disk. Unlikely, but could be a failing powers supply. Borrow one and try it instead. Otherwise, it really sounds like a terminal motherboard issue to me. Godd luck.
Feb 06, 2015 | eMachines ET1161-07 Desktop PC
Keyboard failure message during bootup
There's a good chance that all you need to do is replace the battery which most likely is a cr2032
Jan 17, 2012 | Dell Dimension 8300 PC Desktop
What is the replacement battery model number? My P5LD2 Deluxe computer does not remember the date and time upon bootup.
you just need to get a new cmos battery and replace it.
its a small coin shape battery on your motherboard.
Jun 23, 2011 | ASUS P5LD2 Deluxe Motherboard
When i try to boot my tower it has a bios rom checksum error come up and it freezes. i have tried replacing the cmos battery but the same thing happens. it even freezes up in cmos. the motherboard is a...
Could be lots of things. First check you power supply, then memory. See if any of the components are getting very hot (be careful not to burn yourself). From there it will be kinda hit and miss till you find what is wrong. May be easier to look for a compatible motherboard on ebay.
Jim
May 01, 2011 | Computers & Internet
I have an Abit BD7 motherboard with a phoenix bios and an intel 845 chipset. I am running Windows XP Professional on it. As of now, the system does not complete the POST bootup. It stops at A7 and...
try with reseting the cmos battery and clear the cmos also .try with other power supply also.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 23, 2010 | Abit BD7 Motherboard
Verifying DMI pool data
Possible main memory fault; swap memory modules if you have more than one installed. Otherwise, clear the CMOS contents in the Bios and re-configure. ( remove the coin battery and short circuit the battery socket contacts then re-install the battery )
Jan 25, 2010 | Biostar Computers & Internet
Loaded two patches from HP. One to deal with a printer timeout issue and second to ???Screen went to geo pattern. Forced shutdown. Now tries to reboot, blue lights flash go out and flash again every 3 secs...
Remove the battery and disconnect from power source.
Disconnect any USB or external devices.
Remove the hard drive and memory. Disconnect the CMOS battery in the memory compartment.
Flip unit over and hold power button for 30 seconds.
Re-install memory and hard drive.
re-connect your CMOS battery.
Power up unit without battery installed.
Boot into safe mode.
Go to a command prompt.( start, programs . Acc. , dos prompt or command prompt.)
and type chkdsk /f
You will get a message that says can't run know but would you like to run a next bootup ? Say yes.and and type exit.
Next, reboot unit.
Hope this works for you.
Oct 05, 2009 | HP Pavilion dv9700t Notebook PC
MSI MS-7142 motherboard problem
try cleaning CMOS with cmos jumpers or just remove your battery of motherboard for 10 seconds (previously unplug power from PC.)
Jan 31, 2008 | MSI K8MM-V Motherboard
Ibm screen error
161 - Dead CMOS battery.
163 - Date and time are not set clock not updated.
Replace CMOS Batt: On the bottom of the laptop you will see a screw that holds the memory cover on. (Next to the main Batt) Remove the screw and cover. The CMOS is plugged into the motherboard it is yellow and round tucked in the side of the case. (note how the black cable is towards the center of the laptop and the positive red cable is towards the side of the laptop). Remove the cable connector from the motherboard and pull out the old battery. This can be done by either gently pulling on the cables or using an object like a toothpick and gently tugging at the old battery to free it. With the old battery removed plug in the new battery with the black ground cable towards the center of the laptop and the red towards the side of the laptop. Insert the new battery into the space the previous one set at. Reconnect the memory cover and turn on your laptop. You will have to set the time and date and may have to cycle the computer (reboot) a few times. You can get this battery (CMOS) on eBay or at a computer store they are only a few dollars. (5-8) Good luck in your repair!
you need a cr2025 to replace it you have to pull the tabs of the old one off and tape them to a new cr2025 battery.
then
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key. WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1"
This will get you into the bios "setup." You should check the date, bootup order, etc, and reset.
Jan 24, 2008 | IBM ThinkPad 600X Notebook
Gateway M-6843 Notebook Logo
91 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
