Question about GE GSS25SGMBS Side by Side Refrigerator
The freezer is warm (20) degrees and the fridge isn't cold. Replaced the mother board and cleaned the cois and nothing...
  • sheadlee May 15, 2009
    thanks for the info...i had it cleaned and blown and swept out about a month ago...didn't do anything. What type of refriderant does it take? can i do it myself and try that?? what about the relay?? could that we a problem too???
    Problem Solver:
  • 7 Answers
Hi Sheadlee, when is the last time that u had service on the unit? Has the condenser been cleaned recently in the last few years? Clogged air flow retards heat removal from the refrigerant, pressures rise and prevent or inhibit latent heat of fusion. If you have an air source. Blowout the condenser. It is the part near the compressor near the fan. It could be hard to get to and you will have to remove the back cover on the bottom to access. Sometimes paper even blocks the condenser to prevent air flow. If that is not it then you could have refrigerant shortage or even weak compressor valves.
Posted on May 15, 2009
  • jeff1013946 May 15, 2009
    As far as the refrigerant,it depends on the age of the refrigerator. Newer models use R-134A, older models use R-12. If it is low on charge then you will most likely need a serviceman to take care of it because the systems are usually sealed and if you don't have gauges and a self tapping valve, forget it. Also the charge is critical so you cannot afford to overcharge it. Did you blowout the condenser with CO2 or just clean the front of the condenser? the dirt gets trapped predominantly between the fins. You will need pressurized air or similar to push dirt out between fins... You could have several problems to this symtom that you explained. Weak compressor valves, low charge, bad evaporator fan. You get me? I will help you eliminate the causes one by one. First make sure that you thoroughly blow out the condenser with compressor vapor. You will see what I mean. Also make sure that the cover is completely on when you are completed and that minimal air is going around the condenser....
    Sorry, miss your descript in full. If the fridge is warm then it sounds like the fan is not working in the evaporator section. If could be a door switch or the motor is bad. If a tech just worked on it then the panel was off. Make sure that the fan blades are not obstructed.
GE Profile freezer won't maintain temperature
clean the dust from underneath and make sure fan in freezer is working.
Feb 06, 2014 | Refrigerators
Kenmore elite refrigerator freezer and fridge too cold
947f1e38-158a-4e1c-9e57-08343605a6a0.jpgKenmore uses a model number like this example=> 321.1234567 and can be found around the fresh food section door frame. I need that model number to see what parts may be causing the refrigerator to be too cold. Let me know and I will do my best to help solve this, Thanks Sea Breeze
May 03, 2013 | Refrigerators
I have a PFSS5PJXCSS French door with bottom freezer GE Profile refrigerator. Was making an awful noise and both fridge and freezer were warm. I opened back panel of freezer to find ice everywhere,...
Had similar problem, freezer was working fine, but fridge was warm, (68 degrees) It wasnt my damper, the mother board was fried, and so was the inverter board that told the compressor what to do, after having the inverter and two mother boards replaced.......I threw it out, biggest piece of ****, only three years old, and Sears would not stand behind it, even though I used their repairmen. I will never buy another GE product, or enter a Sears store again
Jun 03, 2011 | GE Profile PDS20SFS Bottom Freezer...
Frigidaire refrigerator model # frs6r5emb8 wont get cold and freezer wont freeze. I replaced the filter and cleaned any and all dust out from the rear bottom of the refrigerator. Freeze wont get cold...
first off the freezer is cold but not cold enough?if the freezer isn't working right then the fridge is gonna be warm too,all it does is get cold in the freezer and the evap fan blows cold air into the fridge,that's it.i need you to do a few checks for me,open the freezer door,do you hear the fan blowing around,if not you could have a bad evap fan motor,next from the bottom up remove the second bin from the bottom and touch the back wall,do you feel any ice or snow on the back wall.if so you have a defrost problem,possible computer board,defrost thermostat or heater.let me know what you find.one more thing did this happen after you cleaned it or did you clean it to try to see if it would help?
May 15, 2011 | Refrigerators
Freezer is cold, fridge is warm; replaced main board already
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 25, 2010 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
GE Profile Artica side by side stainless steel wont get cold
The Profile and Artica are good refrigerators. the problem may be the defrost element, defrost thermostat or the mother board. Let me know if you want help on this one. Thanks Sea Breeze
Jun 18, 2009 | GE Profile Arctica Stainless Steel Top...
My light works but the motor won't kick on, Frigidair top freezer
THE CURCUIT BOARD IS NOT SENDING A SIGNAL TO YOUR MOTOR WHICH ENABLES YOUR MOTOR TO KEEP THE VALUBLE CONTENTS IN YOUR FRIDGE COLD...(BEER) EVERY MANS FAVOURITE HOBBY...CHECK YOUR CIRCUIT BOARD FOR CORROSION OR DAMAGE...HOPE THIS HELPS...IF SO SEND ME A COLD ONE
Dec 13, 2008 | Frigidaire FRS3R5EMB Side by Side...
GE GSS25SGMBS Side by Side Refrigerator Logo
224 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
