Question about RCA HD52W140 52" Rear Projection Television
I have a rca hd52w140
My tv was working fine about 3 hours ago.. i left then came back to turn it on, nothing happens at all.. is there away to reset it, or can you think of anything else.. thanks
  • 1,030 Answers
Does the unit show a flashing led on front panel. make any sounds. reset this tv if it works invloves unpluging the set for 30 minites.
Posted on Feb 04, 2008
Rca tv vcr combo model #T 13072 when I press the power button the power light blinks 4 times, tv does not respond. I have tried unplugging it for a few hours to see if it would reset but didnt work..
There is no power button on the remote, you have TV and VCR only to turn on this set. I need to find out how to do a factory reset. I was using a roku TV device on it, and was working fine, and now nothing. I tested the TV by putting in a cassette, and hooking it up to my satellite service, works fine doing that. But now no roku, and the roku was also tested and works fine.
Mar 10, 2012 | RCA Televison & Video
Hey, i bought a DLP Toshiba HDTV off a guy on graigslist, when i went to go pick it up he turned it on by remote and everything worked fine as it should. When i got back to my place I tried turning it on...
These DLP tvs sometime u unplug suddenly and replug it back wright away,tv will go into protective mode and will not work wright away.Tries tv unplug,replug it back about an hour later,now the tv will reset itself back to the factory setting.The tv should work now.
Nov 17, 2010 | Toshiba 65H93 65" Rear Projection...
Where is the reset for the power on a hd52w140
This TV does not have any type of reset button
UED 1-800-648-6657
Encompass Parts 1-800-638-3328
replace Deflection board#
Oct 25, 2010 | RCA HD52W140 52" Rear Projection...
Lamp will not ignite
Two possible causes. First. The Color Wheel is going bad. Second. The Digital bd is going bad. Color Wheel part# is BP96-96-00674a and the Digital bd is a BP94-02065a.
Jul 09, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Blurry picture
Try to reset first if nothing happens we proceed another solution;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 6 order to dessipitate the charge current.
2. Unplug any connected devices (Satellite, DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Jan 08, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
HD52W140 No picture or sound
Possibly a solder connection, that model is famous for bad solder joints moving it could have caused it develope a bad solder joint. I would check the fuse then inspect the solder joints .
Jun 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Scenium HD52W140
I cannot think of anything easy that would cause the symtoms you are describing. Your power supply is working and the deflection bd is good because you have HV. The problem is signal related and all of this circuitry is on the SSB or small signal bd. The difficult thing is when replacing this bd. you must have RCA's chipper check to download all of the ssb eeprom settings so they can be uploaded to the new ssb. I'm affraid you will need a qualifier RCA service tech for this problem.
Feb 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Scenium HD52W140 Won't power
This has happened to me twice. We had the warranty and thank God we did. The problem is in a $7 transistor and you probably need to call a repair shop. They worked on ours and it took about 20 minutes to replace the transistor. They take out the bad one and soder in the new one on the circut board inside the back of the tv. The total cost was nothing for us because of the warranty, but it came to $385 for labor and stuff. Again, this happened twice, one year to the date from one another. The repair guy finally installed a different brand of transistors and it's been fine since. He said that RCA makes some terrible transistors and he will not use them again. Try and get the repair person to use a non-rca brand transistor, because it will more than likely happen again if he don't.
Dec 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
RCA HD52W140 52" Rear Projection Television Logo
107 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
