Question about Sony Playstation 3 (PS3) Console
Red light blinking
I power up my ps3. It beeps 3 times and then just it just flashes red. I have taken out the hard drive, powered it up and then put the hard drive back in and powered it back up but I still have the same problem.
  • 2 more comments
  • 594rky May 15, 2009
    PS3 turned itself off while i was selecting some music from a usb device. Now it wont turn back on and red light turns green then back to red and just blinks for a while. I cant even eject my game disc thats stuck inside.
  • jmcqueen May 16, 2009
    Tried to change characters on Tigers Woods 09 system turned off now will beep three times flash green and then right back to red can't even get my disk to come out
  • bobby_b89 May 16, 2009
    i just had the same problem, was on cod5 for 10 minutes online waiting to join game then it turned itself off. try to turn it on it fires up for about a second then bleeps 3 times then turns off with flashing red light. manuel says its due to over heating but cant see how an still doesnt turn on when i left it for a while and cant get disk out. any ideas?
  • lizhilt May 21, 2009
    playstation3 2years old has flashing red light. Sony will fix it for 149.00 because it's past the 1 year warranty (how convient) and the sales slip was not saved.
I don't know how to turn the system back on yet, but i can get your disk out. Turn the PS3 off by the switch on the back, hold down the eject button whilst the PS3 is still off, then (whilst still holding the eject button) turn the PS3 back on by the switch on the back. You should hear the fan start up and the disk pop out.
Posted on May 19, 2009
    Sniper:
  • 85 Answers
Sounds like a Heat Sync problem as well as the CPU and GPU not being properly seated. Email dwdpcrepair@gmail.com. This is fixable.
Posted on May 16, 2009
My playstation just shut off an the red light flashes
do you get a yellow light? i bet you do..
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work
Send your playstation back to Sony
May 09, 2010 | Sony Playstation 3 (PS3) Console
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red light stops...
this happens when the ps3 has overheated-try removing the hard drive and replacing then give the console a hoover out.....if this doesnt work try holding the power button on for 5 sec....if this doesnt work its back to sony im affraid
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
I downloaded playstation home, but when I try to log onto it, it goes onto the loading screen, then auto-shuts off my ps3 system. it beeps three times then my power lighting is the just blinking red...what...
take out the hard drive and then put it back into the ps3. Then turn the system back on and see if the red light goes away.
If the red light is still coming on then that means the hard drive is bad and would need to be replaced.
Nov 28, 2009 | Sony Playstation Home
PS3 has blinking red power light and nothing else
switch it off from the back,, hold down the eject button, and turn it on from the back,, it should spit the cd out,,
The ps3 needs to be sent back to be fixed it is YLOD..<--not good
it will take at least 4-6 weeks before you get your Console back. And also, if your warranty is expired, you have to pay a big fat $150,- to get the job done!
or go to youtube and look for a PS3 Ylod fix,,
Nov 28, 2009 | Sony PlayStation® 3 (60 GB) Console
The red power switch keeps flashing,, no picetc
The Red light is due to the HDD (hard drive).
There is one of 2 problems:
1. The connection is loose or
2. The HDD is just bad.
This was an issue that has been discussed over in the Playstation forums and it seems that re-seating
(removing & reinstalling) the HDD has solved the problem for many but some people have just
received bad hard drives period.
If you reinstall the HDD & it still beeps 3 times & gives you the red light, then you will have to replace
your HDD.
http://www.ps3guide.info/fix-common-problems/ps3-3-beep-blinking-red-light-fix
Oct 02, 2009 | Sony Playstation 3 (PS3) Console
Certain DVDs cause my PS3 to shut off and blinking red light
The yellow light is also know as the yellow light of death casued by a hardware failure. It can be casued ny over heating a bluray drive failure, a hard drive failure or even a powersupply failure. You know you have it when you power up the yellow light flashes then you hear some beeps then the red llight flashes. I would suggest returning it if you have that option or getting it fixed somewhere else as a last option.
If you think the **** player is causing the problem remove it and see if it turns on if not you could try another one and see if it works.
Sep 29, 2009 | Sony Playstation 3 (PS3) Console
Cant reboot after red blinking light
There isn't much you can do to easily fix this problem.
Try booting the PS3 with hard drive removed.
For more tips, suggestions, etc.
Check out my guide here:
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
Blinking red light
General hardware failure. Usually the red light means either bad power supply or bad hard drive.
You can start by pulling the hard drive out and then power on the system.
More than likely it's a power supply / motherboard issue, in which case you'll have to contact Sony for repair.
You can reach them @ 1-800-345-SONY
Feb 20, 2009 | Sony Playstation 3 (PS3) Console
How to fix blinking red light on my ps3?
You should open up the PS3 and use compressed air to dust it off. Take a look at the thermal paste to make sure it isn't dried up! PS3 Flashing Red Light The Ultimate Solution
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
PS 3 Won't turn on blinking light
Are you trying to turn the PS3 on via bluetooth controller? If so, attempted to turn PS3 on from console itself. Sometimes the controller will get out of sync with the system and not allow for turning on remotely.
Sep 14, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
544 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
