Question about Frigidaire FRS26H5AS Side by Side Refrigerator
There is a sour smell that comes out of the bottom front of my fridge. It is a side by side Frigidaire with an ice maker. It does not smell inside, only the exhaust air and it smells up my kitchen. I have cleaned it yet the foul odor continues. Any suggestions?
  • 4 Answers
There is drip tray underneath the unit. Depending on model, there are multiple ways to access. This tray needs cleaning regularly. Once clean, sprinkle in Baking Soda to keep odors down. Cleeaning this on a regular basis is the only way to beat this smell.
Posted on May 16, 2009
Ice keeps building up in bottom of freezer and on vent inside fridge and now fridge won't stay cold.
Clean the coil inside the rear access panel behind the unit with a spray air duster and check for this problem.
I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Jun 14, 2010 | Frigidaire 22.6 Cu. Ft. Counter Depth...
Water puddle on floor from inside refrigerator could it be defrost heateris bad? water accumulates in the bottom of freezer and freezes seems to come out of evaporator/fan location
unkink the drain hose...I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Jun 12, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
How to get to the drain line on my Frigidaire side by side refrigerator model number MRS22WNGW7. Water keeps coming out of the freezer side onto the floor (front left side). I was told it could be a...
May 14, 2010 | Refrigerators
Odor coming from bottom of fridge
sound like drain blocked clean out with clorine bleach (not to be used inside frige/freezer). are you trying to grow your own pennicillin.?
Feb 11, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Frigidaire fridge leaks where ice maker is on
Your leaking problem gives two possibilities. The water control valve for the ice maker side is defective and while shut off the water will continue to slowly flow and leak into the freezer compartment. The other possibility id the condensate defrost drain is blocked and frozen over behind the rear panel of the freezer and at the bottom of th coils. I believe your defrost condensate drain has a blockage of ice and will need to be defrosted and clean the condensate line from the freezer to the condensate collection plate below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Sep 23, 2009 | Frigidaire FRS26R4A Side by Side...
Hot plastic smell
For now I think it would be a good time for the ice maker to be unplugged from the inside wall of freezer. Sounds like the heating element under the ice maker is remaining on. Let me know if its hot under ice maker. Even so this is something we need to find now. Sea Breeze
May 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not working
what filter? drying filter? Water filter? Dust Filter?
Jun 24, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire Affinity Front Load Washer
You have to remove and clean the rubber around the front of door,
, Snap it back on.
disconnect AC to prevent any accidental shock.
open the bottom access panel
screws on bottom front , open the large filter and be ready for latent water to spill out , have rags ready.
clean the inside of the filter with clorox.
finally run a strong solution of clorox when you finish.
then rinse well.
leave the door open after loads finish
the door has a child lock
black dot next to lock on door , insert coin and rotate.
keeps them from closing the door.
Feb 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidare side by side Gallery fridge
sounds like you water is spilling out instead of going into ice maker... check the inlet spout for ice or other blockage
Oct 10, 2007 | Frigidaire GLRS237ZA Side by Side...
Frigidair frs22zrf side by side w/ front ice and water
From what you are describing, it sounds like you need a valve. Another common thing I run into is the cooling tank inside the fridge freezing. This will usually affect water through the door only. Remove the crispers and you should see a large coil of plastic water line attached to the back wall of fridge. You can check to see if it is frozen by blowing through it from the end of the line you removed from valve. BEWARE, if you blow through it, water will come out dispenser if line is not frozen. Have a towel at front of fridge.
Oct 03, 2007 | Frigidaire FSC23F7D Side by Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
618 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
