Question about Onkyo TX-DS575 Receiver
My Onkyo Receiver is no longer responding to my remote controller
My receiver isn't responding to my remote controller. I replaced my old remote controller with a new one because I thought the remote was broken. However, the receiver doesn't respond to the new one either.
Any suggestions?
  • 10,594 Answers
When remote does not work on its unit that means either remote or Infra Red Sensor (remote sensor) in unit is bad.
You can confirm remote with any digital camera, camcorder or mobile phone camera too.
Watch remote front through camera and press any button on remote, you will notice Front IR LED will blink, that shows remote is working and remote sensor is bad that requires check and replacement.
If you want to check / replace remote sensor in receiver by yourself, you should have fiar knowledge of electronics, tools to check and remove, install new sensor and related service manual that will provide you exploded view how to open receiver, schematics and part list info.
Thanks.
Posted on May 15, 2009
Onkyo receiver will not respond to Onkyo remote
Hi Thomas, I am not aware of your model but try pressing the receiver button in the remote mode section or RCV on top depending on your receiver model. Thank you, Onkyo USA
Dec 25, 2016 | Onkyo Audio Players & Recorders
Model DR-S2.0. Why doesn't it respond to remotes?
If your receiver does not respond to the original remote, the remote may have failed.
If your receiver does not respond to your Harmony remote, the remote may not have been programmed or may have "forgotten" what to do.
Another possibility is that the infrared receiver has failed
Feb 16, 2016 | Onkyo Audio Players & Recorders
Can you use an Onkyo RC-771M remote control to operate Onkyo receiver TX-SR502 ?
Unfortunately, the RC-771M remote doesn't control the TX-SR502. It will only work with these Onkyo models: TX-NR1008 and TX-NR808. The RC-567M is the one for the TX-SR502; replacement remotes that are exact replacements are still available from various places including Amazon.com .
Since the TX-SR502 was released in ~2004, that replacement remote probably won't control other devices that were released in 2004 or later. Onkyo changed its IR code programming before the TX-NR1008 was released in ~2010 and the RC-771M can't communicate with the older receiver. The manuals for the receivers listed above are still available from Onkyo on the product page under the Downloads tab.
I wish that I had better news for you.
Jan 31, 2016 | Onkyo TX-SR502 Receiver
Onkyo receiver txds787 doesn't respond to remote
Pull the batteries out from the remote control, and leave it out until step-4
Press and release each and every button, one at a time on the remote control, until every button has been pressed and released at least once.
If the remote control have slide switches; move the switch to each position, then repeat the button pushing as in step-2. {When you've done, be sure to put the slide switch in the correct position to operate the unit the remote came with.}
Put the batteries back.
Try the remote.
If it do not help you:
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Jul 10, 2015 | Onkyo TX-DS787 Receiver
Remote will no longer power on Onkyo HT-S3500. Once I turn it on manually, the rest of the functions work properly.
I just had this same issue. I tried to change the batteries for the factory remote that came with the Onkyo HT-S3500 (remote: RC-799M). Still no luck. It would not power on with the remote, despite the light flashing and the and all other remote function working. If I powered on the receiver manually, everything worked (except power on/off).
I just pushed a button on the remote labeled "REMOTE MODE RECEIVER" and viola, the remote now powers the device on and off and works just like usual. Not sure what the heck happened, but I would suggest pushing that button on your remote.
Dec 19, 2012 | Onkyo HT-S3500
Hi. my original remote for my onkyo tx ds575 all of a sudden is not working anymore. the red light on the remore still lights up when i press a button but the receiver is not picking it up. hopefully you...
The red light on the remote just means the battery is good and the remote is responding when you press a button. It doesn't mean the control is actually sending out a signal. Many retail stores have a tester that will tell you if the remote is transmitting. Another possibility is that the remote sensor in the receiver has gone bad, and that the remote is fine. A universal remote (One-4-All URC6131, for example) that can work home theater receivers can be used to test the receiver. It may not work all the functions, but if it turns the receiver on and off you'll know the remote is at fault and not the receiver. Then you'll be able to replace the remote or have the receiver serviced as needed.
Mar 21, 2011 | Onkyo TX-DS575 Receiver
The Onyko TX-DS595 receveiver won't respond to remote.
When unit is on hold down vcr button and press standy power button. display will read 'CLEAR". turn back on and see if remote works. note that this will erase any of your settings. Point the remote at any camera and look at the camera display. If you see a white light when you press buttos remote is working. Remove the top cover, remove front cover and resolder connections on remote receiver. If you intend to do this let me know and I can give you more details.
Mar 22, 2010 | Onkyo TX-DS595 Receiver
Unit does not respond to remote control
I had this same problem with the Onkyo TX-SR706 this evening, and finally found the solution in the "Controlling Other Components" section of the manual: Resetting the remote control did the trick. (P.S. This problem started after I spent many hours today trying to get my new Acer laptop equipped with a Hauppauge TV tuner stick to correctly display its image on my Samsung HDTV, with sound. I tried connecting the laptop via HDMI first to the Onkyo receiver and then directly to the TV, neither of which worked as it should. I assume that somehow, in all those hours of much plugging and unplugging and fiddling around, I screwed up the remote sensor -- thank goodness I eventually found the "Resetting the Remote Controller" solution a little while ago -- I was approaching the point of ripping everything apart and throwing it out the window!)
Jul 06, 2009 | Onkyo TX-DS575 Receiver
Receiver doesn't respond on remote signals
Low batteries can cause a symptom like this. Have you tried to replace them yet?...accordianman
Oct 04, 2007 | Onkyo TX-DS595 Receiver
Onkyo TX-DS575 Receiver Logo
365 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
