Question about Midland LXT410 (14 Channels) 2-Way Radio
Receveing problem my radio midland LXT410 will let me talk out on it,but it will not receive anything but stactic. what should i do to fix it.
  • Midland Master
  • 1,654 Answers
Check to see you have the interference eliminator (aka tone code, PL, private line, CTCSS) programmed correctly to match the other units you are talking with.
Posted on May 17, 2009
I Want To Add Talk Back Mod To CB Radio
there is what is known as the Quick and Dirty way, to add talkback to almost any CB radio. You will need a 130 Ohm 1/4 watt resistor. Open the radio and find the two mounting points for the external speaker jack and PA audio jack, you will want to solder the resistor across from the Positive connection of the PA jack to the Ground connection for the External speaker jack. This will give you talkback, and eliminate any feedback when the microphone is held at a normal operating distance away, Just remember, (This could potentially damage your radio if done improperly, I will not be held liable for anything that you do to your radio.) However, when done correctly this is a perfectly safe modification, and will allow you to monitor your output audio, as it is being transmitted. You can adjust the size of the resistor to your liking, however, I do not recommend anything lower than 100 Ohm, as there will be more potetial for squealing/feedback.
Feb 20, 2014 | Midland Radio Midland 9001Z Citizen Band...
Midland LXT410; one of the units makes a continuous noise when receiving if the volume is turned up louder than 3. It doesn't matter how close or far apart the two units are. We hadn't noticed...
It sounds like a damaged or dirty volume control. I have seen controls where the element inside the control snaps and this sounds like what has happened to your radio. You did not say if the squelch control was set open or closed. If what you are hearing is loud static, I would adjust the squelch control on the radio to see if it stops.
May 27, 2017 | Midland LXT410 (14 Channels) 2-Way Radio
I have a Midland 75-785 hand held, It was working fine then I went to use it and the squelch control is not working ( I get lots of static) radio still works. Sends and receives, but when I turn the...
what time of day are we talking here? usually skip is so heavy from 0800 until 1600 that no radio has a chance of transmitting or receiving.If you turn the squelch the other way what does it do?
Jun 22, 2011 | Midland 75-785 Handheld CB Radio
I have a set of two Midland LXT420, made in China. One of them have suddenly stop working, doesn't turn on. And about a month after, the second one went OFF. Both batteries are charging till 5.9 yo 6.1...
It is likely a fuse inside the radio that is open, or possibly some poor solder connections. I would call whoever you purchased them from and have them take a look.
Mar 18, 2017 | Midland LXT410 (14 Channels) 2-Way Radio
Lost my instructions for Midland X-Tra Talk LXT310
Here you can download the manual for your radios. http://www.midlandradio.com/Resource_/OwnerManual/53/LXT410.pdf Hope this helps.
Jun 08, 2009 | Midland LXT310 2-Way Radio
Im only able to hear out of one of my walkie talkies
Make sure you are using the same channel and privacy code as outlines in the manual for each radio.On the creen the large number is the channel and the smaller number is the privacy code.
Here is a link to the manual: http://www.midlandradio.com/comersus/store/catalog/LXT410%20Owners%20Manual%20RevH.pdf
May 06, 2009 | Midland LXT310 2-Way Radio
Can't figure out how to get a "channel" to lock on the handset
Here is a link to the owners manual for the LXT-330 420 Series radio:
http://www.hitechwireless.com/pdf/Midland/LXT-330-420 Owners Manual.pdf
I hope this helps.
HiTechWireless.com
Mar 27, 2009 | Midland LXT410 (14 Channels) 2-Way Radio
Midland GXT550VP4 communication problems
Did you use the sub-codes? Where they tested indoors or out?
Dec 23, 2007 | Midland GXT550VP4 (7 Channels) 2-Way Radio
Midland LXT410 (14 Channels) 2-Way Radio Logo
171 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
