Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Trouble with ice make
My Ice is hollow on the inside. can you help with this?
  • 473 Answers
You have too low of water pressure to the fridge.  Most common reason for this is wrong type of saddle valve on your water line.  Don't use a self-piercing saddle valve.  Also, reverse osmosis systems will cause this.  If you have an r.o. system it needs to be removed from the fridge.  Let me know if you have any questions before you rate the solution.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
My frigidaire gallery french door refrigerator is making ice very slowly. the water is coming out fine. It is only 4 weeks old. i got solutions from frigidaire from the valve to the water filter. Any...
The theory to making ice is temperature, water, and ice mold to function. What are the temperatures inside the freezer currently. It must be below 15 degrees to function and prefer the freezer to be at 0 degrees to product effectively. Are you ice cubes solid or hollow? If hollow you can jam the ice inside the ice maker causing slow production. Rare to have a water valve problem this young be is possible. I would look at temperatures first than cycle time to determine the next step. In a perfect world, your unit should drop ice every hour to and hour and a half.
Good Luck
Jul 23, 2011 | Refrigerators
My wide by side Maytag refrigerator MZD2768GEB ice maker is making hollow ice. It seems that it is not cycling properly as very little ice is in the bin and most of the time the hollow ice is stuck to the...
Hollow ice is a sign of not enough water going into tray. Replace the water inlet valve or the fill and shut-off valve for problems with both parts. Hollow ice cubes usually indicate a low water problem. This is generally the result of an excess buildup of calcium and other deposits.Replace the self-piercing shut-off valve with a drill-type shut-off valve.Drill a 1/4-inch hole into the pipe and installs the shut-off valve the same way you would have installed the self-piercing valve.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Apr 01, 2011 | Maytag MSD2651 HE Side by Side...
Ice cubes are hollow shells
Check around the hot gas valve for leaks/oil.
Aug 03, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Water is leaking inside the refrigerator and the ice cube aren't freezing completely (cube is a hollow shell of ice)
Possibly it is because fridge is not cooling correctly(Ice cubes hollow).. Suggest proper defrost. if it is cooling partially, it shows cooling is trying to take place (Make sure before you switch on after defrost, check for proper water drainage.Water must flow to the compressor once defrosted.Take note if the fan runs correctly.
Sep 20, 2009 | Whirlpool 18.9 cu. ft. Top Freezer...
Making hollow ice cubes
Hollow ice is a sign of not enough water going into tray . Replace the water inlet valve (piece that the wall water line connects to on refrig ) .
Aug 29, 2009 | Refrigerators
Maytag msd2356ae ice maker will only give me hollow ice any ideas.
Hollow ice cubes are most often cause by insufficient water supply. Icemakers fill for about 7.5 seconds, resulting in about 4.75 oz. (140 cc) of water into the ice cube mold. If there s not enough water pressure available at the fridge, cubes may end up hollow and/or the fill could continue to dribble, eventually causing the fill tube to freeze closed.
pls rate my suggestion.........
Jul 25, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ice cubes are hollow.
some fridges are designed to make hollow cubes where they always hollow or just recently
Apr 13, 2009 | Refrigerators
Freezer too cold and not much water. When it is empty of ice check the water level in the ice tray. Probably not even halfway up. Unplug fridge for 8 hours and plug it back in. Need more help please live chat. If this has helped, please rate as fixya.
Nov 19, 2008 | Whirlpool Gold Series GI15NDXT 15"...
Ice maker is not putting out ice GE
Low water pressure usually the cause of that, just like when you get hollow ice cubes as explained here: (
Jul 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
108 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
