Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker solobarrick...still not working...
I have a kicker L7 DVC 15inch trying to wire it up in my box and amp..i already have a woofer in there but i cannot get the woofer to work..i looked at the wiring that crutchfield had said, but it will not work...i have tried to wire it up in series and parallel.i have a MA audio 1000watt mono block amp.. when i wire it up the protect light comes on in my the sub just blown?
A previous post was up and i did try to wire up the sub in series but it still does the same thing...still going into protect mode..
  • Anonymous Dec 24, 2007
    Problem Solver:
  • 7 Answers
Check ur ohms you are probably running to low.....
Posted on Feb 12, 2008
Kicker aint kickin? warranty,warranty,warranty!!!
Posted on Oct 20, 2007
Best way to hook up a 15" solo baric L7 to a2400w cx 1200.1 kicker amp
The CX1200.1 amp is 2 ohm stable. Hopefully, you have the 4 ohm DVC version of the Solo-Baric L7. If so, connect the DVCs in parallel (both positives together, both negatives together) to the amp. This will maximize the output power of the amp. If you have the 2 ohm DVC version of the Solo-Baric L7, the best you can do is connect the DVCs in series to the amp. This will cut the output power in half, though.
Oct 30, 2015 | Kicker Car Audio & Video
Best amp for two l7 15inch speakers are 4 ohms
i personally like the audiobahn a.k.a. cheater amps ill go with the A2300hcx model
May 10, 2010 | Car Audio & Video
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide... that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Need to wire two dvc 15 in kicer l7 to 1 ohm
Hello goldy6569,
To wire the L72's at 1ohm, simply connect both +'s and -"s on each sub together. Then connect to your amp terminals.
With 2ohm DVC's, you can have either a 1ohm load or a 4ohm load. The diagrams are here (I know it's the website of a Kicker competitor, but their "wiring wizard" is simply the best).
Hope this helps.
Jul 16, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker L712 and rockford fosgate800a2 amp.weak prfmce
Is the box sealed air tight, leaking around speaker? plumbers putty works great. Amp may be good enough for the mtx but underpowered for the kicker. When kicker says 1000 watts that what it is (at a 14.4 volt input). Mtx is ok but may not tell the true watts. Check to see if the speakers are the same ohms also!
Jan 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
12" kicker l5
Series is +amp to +1, -1 to +2 , -2 to -amp . This way you have wired the two voice coils into one higher impedance voice coil.
Dec 11, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker solo-baric L7
ok here is a real pdf manual from kicker and please rate me
Jan 21, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Hi yeahonda,
Your Kicker L7 Ohms may be too low for the MA Audio Mono block amp. The MA Audio Amp is probably 2 Ohm Stable. The kicker will either be 2 ohm or 4 ohm Dual voice coil.   To eliminate the low ohms as a possible threat to causing the map to go into Protect, Wire the kicker Voice Coils in Series.  This adds the ohms, so that you either have 4 or 8 ohms.
I am using the following codes to show wiring. VC1+ stands for the Kicker  Subs Voice Coil #1 Postive post. AO+ is the MA audio Amp output positive.
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
This shopuld give you 4 or 8 ohm depending on the 15" L7 setup.  Crutchfield does not carry the Kicker  L7 in 15" They do  have the L5 in 15".
If you know how to read a Volt Ohm Meter, set it to OHMs 20 and measure across VC1+ to VC1- and you should see between 1.5 and 5 ohms..  Do the Same with VC2+ to VC2-.  you should see the same voltage. Also read from the Voice coil metal housing to VC1+ , VC1-, VC2+, and VC2-. and you should not read any ohmage to the case. The meter should say OL, or -1.
Good luck.
Oct 15, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
209 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
