My PDA is losing charge. I know this is normal with use. However, when I connect to any of 4 USB cables, the "green" charge light does not indicate there is a charge going to the battery. It was fine 2 days ago, and I noticed yesterday that the charge level would not rise above the 87% even though I was connected to active sync. IIt actually lost a %. The battery should not be in need of replacement, unless it is a faulty battery. This is my 3rd or 4th PDA, and I have never dealt with anything like this in the past. If you can "fix" this, I would be so happy! Thanks, Michele
  • 1 more comment
  • msbuege May 15, 2009
    It is not just the PC, I have a car charger, and 2 other usb connecters in the house. None of these give a charge. I did also run the "self test" and the indicator light does work.
    Thatr last comment was above my understanding. Perhaps there is something different going on. I pulled out hte cradle, plugged the device in, there was syncroniztion, but I have to turn the PDA off ON THE CRADLE to get a charge. I have gained 2% battery charge. Again, the PDA has to be OFF and it is only charging on the cradle. What is going on?
    Okay, I changed the battery setting from slow charge to fast charge. I am not sure why that is making a difference, but hey, I'll take it. Thanks for your input!
  • 3,230 Answers
Note when you connect a USB device to a USB post make sure your computer is properly pluged with green wire.
check that.
Good Luck
Posted on May 15, 2009
  • Mukesh Kumar May 15, 2009
    Its the same earthing problem with the usb drive. check the output power using a multimeter. (the output volts. is must be same as your pda charger)
    Thanks
Cobra Mirco Talk CXT 195
pls check usb cable , replace with new gud quality short length usb cable n try to connect the same in back side USB port not front side ..
Jan 15, 2014 | Cobra Radio Communications
TOSHIBA PORTEGE G910 POWER MANAGEMENT problems
try xdadevelopers for this solution,best site for xda pda problems
Mar 23, 2010 | Computers & Internet
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
How do i charge my sansa mp3?
  • Step 1:Plug the appropriate end of the USB link cable that came with your SanDisk MP3 player into the MP3 player itself. The port for this cable can be found on the right side of most models of SanDisk MP3 players.
  • Step 2:Plug the other end of the USB link cable into a free USB port on your computer. This will effectively connect your SanDisk MP3 player to your computer.
  • Step 3:Turn your computer on. This will cause your SanDisk MP3 player to automatically begin drawing power from the computer and charging its battery. On the screen, an indicator light will flash yellow while the player is charging.
  • Step 4:Disconnect the cable from both your MP3 player and your computer when the device has finished charging. You will be able to tell when the charge is complete when the indicator light that previously was flashing yellow appears as solid green.
  • Sep 17, 2009 | Audio Players & Recorders
    The PC is not switching on
    Without know exactly what already you tried to powered it on, I can only especulate on all the possible reasons, so let go one by one throuh them and their possible solutions:
    1. The RX3000 Ipaq family has a known mechanical issue on the switch that senses when the back cover lid is properly closed.
    When the switch is nor properly depressed, the PDA won't charge the battery if plugged on the cradle or to the USB sync cable, or won't turn on.
    Remove the back cover lid and the battery, put them back again. Check the cover lid is placed flush and that there is not any gap between the cover and the PDA body.
    Try again in power it on and/or charge the battery, confirming the orange LED light is turning on.
    2. Either the cradle/USB sync cable or the AC wall adapter are defective.
    The PDA won't power on if the battery is not charged to the minimum voltage for it. If the AC wall adapter or the cable/Cradle are defective, won't power on.
    Put to charge the battery and confirm the orange LED light is turning on. If so, the you can discard that the cradle/USB cable or AC wall adapter are defective.
    It the orange LED light won't turn on, it may be either one of these three parts that are defective, or that the back cover lid is not properly closed.
    3. The battery dried out. If the battery is defective or won't accept charge, the pda won't power on.
    To discard a defective battery, put the PDA to charge it, and it will power on when plugged to the USB cable or to the charger, and check in the settings screen, on the power icon, if the battery is charging.
    If the back cover lid is properly placed, and the PDA won't power on when plugged to the USB cable or AC wall adapter, then the battery is not the problem.
    4. Discarding that the battery or the USB cable or cradle or the back cover lid are the problem for this problem, the only option that is left is that the main board is defective.
    Such failure on the mainboard could be caused for several reasons (moisture or humidity or water damage, or a electronic component that is worn out, or a integrated circuit that is shorted, etc) but it can be only verified and confirmed by an electronics technician.
    You have the option of send it to be repaired, or try it yourself, which will require to buy a PDA with working mainboard (or the mainboard alone) and swap the parts. It requires a minimum of technical skills to do it.
    Best regards,
    Feb 02, 2009 | HP iPAQ RX3715 Pocket PC
    Cannot connect my PDA to PC
    Normally for when you connect any device to pc using USB port, windows detects it. Sometime it may take time.
    Few initial things you may check....
    1) You must have your PDA in ON condition
    2) If PDA is not getting connected on port, try connecting to other USB port (assuming that pc normally have more than one USB port)
    3) Make sure the cable that you are using between PDA to PC is working properly (normally you can check this by using other cable)
    4) If you have intalled some anti virus program on your pc then check the settings of same.
    5) last but not least check the settings of window's firewall (part of OS)
    If everything of above is fine then either USB ports of pc or of PDA might not be working.
    All the best!!
    Regards,
    Av
    Dec 10, 2008 | Computers & Internet
    Hp ipaq seems dead
    Best regards,
    Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
    Supertooth one user manual
    Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
    Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
    Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
    To pair with your mobile phone:
    1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
    To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
    To end a call: Press red button for 1 second
    To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
    To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
    Hope this helps.
    Nov 22, 2008 | Cell Phones
    Won't turn on
    Best regards,
    Oct 27, 2008 | HP iPAQ RX3715 Pocket PC
    Dead!
    Best regards,
    Apr 22, 2008 | HP iPAQ RX3715 Pocket PC
    Computers & Internet Logo
    David Payne
    David Payne
