Question about Kenmore Washing Machines
Took back panel off of kenmore 800 series washing machine but can not get it to go back on
jsrock516
  • 5911 Answers
SOURCE: Broken Machine-Kenmore 70 series Washing Machine
This is commonly caused by a lid switch malfunction. If your model number is correct, the lid switch for your washer is located under the right hand side of the washer casing along the wash tub rim. The switch is activated by a small plastic piece on the washer lid (called a "lid strike") through a small hole. The switch contacts close when you shut the lid. In many cases, the lid switch either comes loose, or the lid strike breaks off. In both cases, the washer will exhibit the symptoms you describe. Open and close the washer lid and listen for a distinctive "clicking" sound as the switch contacts close. If you cannot hear the switch, make sure the lid strike is intact and the mounting screws for the lid switch (located around the wash tub opening on the casing) are tight. Sometimes, all it takes is to tighten the lid switch screws to realign it with the lid strike. If the switch is defective, or the strike is missing, parts can be ordered on line at searspartsdirect.com. Just type in your COMPLETE model number, which can be found on a nameplate under the washer lid. The lid switch and lid strike will be listed under the "Top and Cabinet" heading. Other sites that offer competitive pricing are repairclinic.com and appliancepartspros.com. If you require instructions on how to replace the switch, you may use the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have questions, or if the diagnosis is incorrect, please let me know. I hope you find this information helpful.
Posted on Jan 14, 2009
SolutionGuy
  • 331 Answers
SOURCE: Need to remove the back panel off of the Kenmore series 80
Don't do that, Mike! Access is from the front...
SG
Posted on Apr 07, 2009
SOURCE: Not spinning all the water out
Here's the manual
http://c.sears.com/assets/own/29822e.pdf
It's direct drive, no belt.
Posted on May 28, 2009
  • 1937 Answers
SOURCE: My washing machine (Kenmore 70 Series) does not spin
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Jan 12, 2010
  • 1937 Answers
SOURCE: Slow agitator in Sears Kenmore 800 Series washing machine
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. .
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Jan 19, 2010
Testimonial: "I sincerely appreciate your responding and in such great detail too. I am going to try this. Thank you so very much. "
How do i get the back off my kenmore hd 90 series washing machine
YOU DONT!!! THE 90 SERIES COMES OFF OR OUT DIFFRENTLY. THE WHOLE BODY IS REMOVED BY PULLING IT FORWARD AFTER REMOVING FRONT SIDE PANELS THEN UNSCREWING 2 SCREWS. CAN THEN PULL OUT WHOLE BODY FORWARD
Oct 18, 2014 | Kenmore Washing Machines
How do you get the top off of a kenmore 800 series washer and also the back???
The top or the back does not come of //your post is a little old so if you still need help please ask and I will tell you how to take machine apart......
Feb 07, 2011 | Kenmore Washing Machines
Washer fills agitates and drains but wont spin kenmore 800 series
sounds like you need a drive coupling. tip the machine back and remove the motor and pump. the coupling is between the motor and gearcase.
Feb 07, 2010 | Kenmore 24032\24036 Top Load Washer
I need to replace the timer on a series 800 washer
Fix the timer on the washer so that it fills with the correct amount of water, and so there is the correct amount of time for each cycle. Make sure the washer is unplugged and take off the control knobs and the panel that lays over the knobs. The knobs could be either at the front or back of the machine. Check the wires that link the timer to other areas of the washer. If they are slack, push them further into place with pliers.
Change the timer by disconnecting the old one. Make sure the new timer is made for the brand of washer that you own. Unhook the wires to the old timer one at a time and connect each wire to the new timer.
Mar 02, 2009 | Kenmore 23822 Top Load Washer
Washing Machines Logo
102 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
