Question about Datamax DMX-I-4208 Label Printer
Datamax dmx-i-4208 (ribbon fault) - Datamax DMX-I-4208 Label Printer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Re-calibrate the printer. If still not working, take out the ribbon assembly by removing 3 screws and check the sensor ( "L" shaped plastic glass). If still not working, buy a new ribbon assembly.
Posted on Nov 07, 2009
  • 155 Answers
Verifica que la configuracion del software sea la misma de los materiales que estas utilizando (DIRECT THERMAL OR THERMAL TRANSFER). Tambien puedes hacer un reset presionando las teclas PAUSE, FEED y CANCEL cuando enciendes la impresora. Verify that the configuration software is the same for using these materials (DIRECT THERMAL THERMAL TRANSFER OR). You can also do a reset by pressing the keys PAUSE, FEED and CANCEL when you turn the printer.
Posted on Jun 10, 2009
2 Suggested Answers
SOURCE: datamax dmx-m-4208
press MENU then enter(cancel) then FWD(feed) appear sensor type then press ENTER(cancel)
then choose continuous >>>
Posted on Feb 12, 2009
Adjusting Datamax i class
If the ribbon is moving right on the I-4208 so far that you aren't getting print on the left of your label, the typical solution is to make sure that your ribbon roll is pushed all the way in, as far as it will go (at the top center of the printer on the black hub where the ribbon and it's cardboard core slide on). Similarly, make sure that the used ribbon that is winding on to the Rewind Hub at the top front is also in (to the left) as far as it will go).
Jun 26, 2014 | Datamax DMX-I-4208 Label Printer
Is there a specific ribbon that is recommended for this printer? We purchase ribbons from Heartland & it appears that the ribbons are wound the opposite direction according to the Data Max installation...
dkrueger105: The correct ribbon for this printer have ink inside, not outside. Change it because that cause a damage in springs in ribbon dispenser. Roberto Martinez
Sep 07, 2011 | Datamax DMX-I-4208 Label Printer
The ribbon is printing blank labels
Is this the correct ribbon for a Datamax? The ribbon (satndard setup) is for the ribbon to inside wound whereas most printers are outside wound.
You can check this by using the sticky side of a label it will pull off ink (turn black) if it is there.
If this is the wrong ribbon do not be tempted to put it in the other way or you could damage the ribbon supply spool.
Aug 19, 2011 | Datamax DMX-I-4208 Label Printer
Errors= head cleaning fault. position fault
head cleaning fault, you need to remove the option for head cleaning.
The position fault may be due to either a wrong label size, wrong detecting sensor selection or your printer sensors needs callibaration
Aug 15, 2011 | Datamax M-CLASS DMX-M-4208 Label Printer
Position fault
Position Fault is common on Datamax printers with the LCD Display. Press "FEED" one time and this should clear it out. If not, "PRESS AND HOLD FEED" for about 5 seconds and release. This is called a Quick Calibration. Make sure the label sensor is in the correct position as well.
Jan 13, 2010 | Datamax DMX-I-4208 Label Printer
Datamax I-4208 ribbon loading
Follow the arrow symbols stamped on the ribbon spool assy
Sep 24, 2009 | Datamax DMX-I-4212 Label Printer
Display reads ready, but when print is press the labels run but nothing is printed on the labels.
Is your label "direct thermal"? or using a ribbon to print.
If using ribbon, high probability that you install the ribbon the other way around.
Aug 20, 2009 | Datamax DMX-I-4208 Label Printer
Will not feed full length of label. display reads "ribbon fault" datamax i-4208
You may need to take out the whole ribbon assembly by removing 3 screws. The ribbon sensor looks like a L shaped clear plastic glass.
If still not working. buy the ribbon assembly.
Aug 12, 2009 | Datamax DMX-I-4208 Label Printer
Datamax dmx-m-4208
Feb 10, 2009 | Datamax M-4208 Thermal Label Printer
Datamax DMX-I-4208 Label Printer Logo
4,668 people viewed this question
Top Datamax Office Equipment & Supplies Experts
pkwc
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
