Question about Sunbeam Heating & Cooling
Sunbeam Electronic Heating Pad Control
The pressure sensitive switch/pad on the printed Circuit Bd is depressed and not returning to open position.
the controller is dark grey and blue and has a digital display to tell you the heat setting and the auto time set to turn off after 2,4,6,8 hours or stay on continuous.The heating Pad part# is 114857. I need another controller printed circuit Bd.
Email dodgedumptruck@yahoo.ca
yalmer
  • 552 Answers
SOURCE: mattress pad 1/2 not heating. (K85KQP)
It is sure to be a problem with the controller.
If you can open the controller up, you can compare the good controller on the side that operates to find the problem with the bad side.
If you have a multimeter, you can surely fix the problem.
Check for output where the wire comes out of the controller if you can get inside of the controller.
It may be that the cord is bad.
That is the most abused part, because it is continually being moved and bent.
Posted on Feb 11, 2008
SOURCE: Sunbeam Heating pad will not reset
Have the same problem. I have contacted Sunbeam support via email and they are very friendly and helpful so far. I will post when resolved.
Posted on Jul 30, 2008
SOURCE: malfunction heating pad
return it, get a cheap unpretty heating pad,  get relief
Posted on Oct 09, 2008
SOURCE: new heating pad not working
have same problem with heating pad . reset control by unplugging unit for 1 minute , while holding down power button plugged unit back in . sometimes this takes 3 or 4 tries.
Posted on Jan 10, 2009
SOURCE: The heating pad is complete dead. No lights come on.
I have contacted the company and they are going to replace my heating pad once it is back in stock.
Thank you
Posted on Jun 24, 2009
Depress heat heating pad flashing won't go on
Hello, Linda -
Do you perhaps mean an Xpress Heat heating pad? If so . . .
http://feelpainrelief.com/does-sunbeam-xpressheat-heating-pad-extra-large-deserve-its-best-seller-spot-on-amazon/
(Quote)
How to Use the Heating Pad
When you get your package, the cord and the heating pad are not connected. Before plugging the cord into the outlet, make sure that the cord and the heating pad are connected. Yes, the control/cord must be connected to the heating pad before plugging it in. If not done in this order, it might cause a blinking F in the display and the pad will not heat up.
(End quote)
More . . .
Flashing F
Some users experience a flashing F (meaning failure), in the display. Make sure that the cord with the display is connected to the heating pad BEFORE plugging it into the electric socket. The flashing F can be avoided by doing this. If you still get a Flashing F, disconnect from the electric socket, make sure the cord is tightly connected to the heating pad, wait 2 minutes and then plug it back in.
(End quote)
More . . .
Customer Support and Warranty
This heat pad comes with a 5-year limited warranty. This means that for 5 years it should be:
Free from defects in material and workmanship. If there is any problem with the above after normal use, they will repair or replace this product or any component of the product found to be defective during the warranty period.
What you need to do is keep the original sales receipt/order and call the following number:
  • In the U.S.A. - please call 1-800-435-1250
  • In Canada, -please call 1-800-667-8623
They will help you out if you run into problems.
(End quote)
Best wishes.
Mar 04, 2018 | Miscellaneous
I have a sunbeam two control mattress heated pad. One side works fine but the other will show a F error when put on preheat..
look for creeses in liquid lines. also check fualty wiring for voltage. switch power to pads if it heats look at power supply
Jan 03, 2018 | Sunbeam Heating & Cooling
KEYPAD BUTTONS STUCK
The touch pad sends a signal in sequential orientation that starts and stops various functions. When the controller sent a message to the heater coil to disconnect it failed to negotiate the command. The problem therefore is the electronic switch in the heater circuit. It could also be as simple as a temporary short due to moisture buildup on sensitive electronics and connections. Check all internal wiring for disruption or damaged insulation.
Mar 18, 2014 | Maytag Dishwashers
Sunbeam Heating Pad
You can try to order a replacement through the company you originally bought the set from. If it is fairly new, the warranty may still be in effect. My sister goes through http://www.pioneercomfort.com and has had good results, you could try there.
Jan 17, 2014 | Sunbeam Heating & Cooling
Get F2 error code on sunbeam heating pad model cat93, contrller sw404
Crimped the ends of the heating pad cord where it attaches to the pad a little then did the plug and unplug three times while holding down the on-off button and that did the trick
Jul 03, 2011 | Sunbeam 805810 HeatSense Heating Pad...
F1 error on heating pad
Unplug & then plug in... will help for a little while, but the F1 will return. Sorry.
Oct 07, 2009 | Sunbeam 722 Auto Shut-Off Heating Pad...
New heating pad not working
Apr 26, 2008 | Sunbeam 805810 HeatSense Heating Pad...
Malfunction heating pad
Same F2, quick off problem here. Then I noticed that the gray plug on the power cord was not completely flush with the connector on the pad. I shoved them together until there is no gap. The unit's worked perfectly since then.
Mar 24, 2008 | Sunbeam 805810 HeatSense Heating Pad...
I have a Sunbeam heating pad with the SW204 controller that the High light blinks when it is plugged in. I called Sunbeam and the first thing they said is it cannot be plugged into a surge protector. Next, to reset it unplug it from the wall, then unplug the controller from the heating pad. Wait 30 seconds, then plug the controller back into the heating pad and then into the wall. It did the trick. However, when I move it to the bedroom plug it does the same blinking. Sunbeam is sending me a replacement heating pad. They appear to be very good with Customer Service since it is more than a year old.
Mar 21, 2008 | Heating & Cooling
Heating pad
There are no repairs done on Sunbeam heating pads. If it is less than a year old either take it back where you purchased it or contact Sunbeam.
Feb 23, 2008 | Heating & Cooling
Heating & Cooling Logo
323 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
