Question about Dell Dimension 3100 PC Desktop
Boot issue dell deminsion 3100 strike f1 or f2 to run set up utiliyykey to continue how do I fix that so i press f1 and it boots xp kust fine it's annoying It started when I did a xp repair (not asr) R
    President:
  • 2,559 Answers
Start the computer and logon as normal,Once on the desktop,Click start,run,and type msconfig , Click OK, On the General tab,Choose Boot normally,Click apply,The computer will restart,click ok.
If this don't work,Post back
Posted on May 15, 2009
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Strike F1 to continue, F2 to run the setup utility
Got to BIOS by pressing F2,check or any floppy setting and disable it even in boot order setup.This will solve your problem otherwise replace the lithium CMOS battery.
As you have reset the BIOS setting to it's default setting.Floppy drive is enable by default whether your system have a physical floppy drive or not.
Dec 24, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell latitude 120l CD boot problem
Hmm,I've seen this before & unfortunately I think the cd drive went poop.
Jun 26, 2009 | Dell Latitude 120L Notebook
Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
Dell dimensions 3100
sounds like your floppy drive is failing, you could get it replaced or simply turn it off via the BIOS.
to turn it off simply hit the F2 key. On the first screen usually it will list your Hard Drives, CD ROMs', and the Floppy. scroll down to the floppy and hit enter ot the corresponding key form the bios's legend at the bottom or right hand side of the screen untill you see disable.
Next you can navigate to Save & exit or hit F10 to do the same. G/L.
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Dimension 3100 Won't Boot
Make sure your HD Cables are all firmly plugged in, and that all drives are starting when you turn on the computer. You can tell with harddrives as they will slightly whine, and have a small, steady vibration to them. If they are all starting, and all cables are fully seated, check in your Setup utility that the drives themselves are Auto-Detect. If none of this fixes your issue, you may have to refer your computer to a computer repair shop.
Hope this helps!
-Backu
Jan 16, 2008 | Dell Dimension 3100 PC Desktop
Dell Dimension 3100 PC Desktop Logo
220 people viewed this question
Alun Cox
