Question about BenQ FP731 17" LCD Monitor
BLUE LIGHT BLINKS BUT MONITOR SCREEN REMAINS BLANK
THIS STARTED AFTERI TEMPORARILILY WHILE IN USE PULLED THE MAIN PLUG AND THEN .THE MONITOR WWAS RECONNECCTED BUT NOT WORKIG WITH COMPUTER,PICTURELESS ANF A STESADT FLASHING OF THE PLUE MONITOR ON LIGHT IE BLINKING'IK SUSPECT THJE PROBLEM IS IN THE ANTI THET DEVICE BUTR CANNOT RERSTORE ORDER
PLEASE HELP
MODELfpd1975w
7010676r blue light blinks but monitor screen remains black
It's probably because your caps lock is on.
Posted on May 18, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Posted on Oct 04, 2014
Blue light blinking
Posted on May 23, 2009
Blue light on with blank screen dell SE198WFP monitor
It depends on what type of connection you are using. If you are using a VGA (analog) cable then you need to select that mode on your monitor menu. If you are using a DVI (digital) cable then you need to choose that mode on you monitor menu.
Nov 24, 2013 | Dell SE198WFP LCD Monitor
Samsung 906vw blank screen
if the power light indicator is just blinking with no display, you must checked the power supply the common cause bulging electrolytic capacitor. just replace with the same value and rating then the problem solved.
Jul 22, 2012 | Samsung Computers & Internet
Samsung Syncmaster 943b light blinking but screen remains blank, tested cables, message 'test good' flashes on screen then goes blank again.
try to connect monitor with other computer, this way u will confirm weather the fault is in monitor or in computer. if it is in monitor, check for bent pins in connectors which connecting computer & monitor, firmly connect both ends of connecter & tighten the screws. if problem not solves then u need to replace main board of monitor.
Aug 25, 2011 | Samsung SYNCMASTER 943B 19" LCD Monitor
The monitor doesn't power on properly
you can have bad capacitors on your power supply.
Jan 10, 2010 | Computers & Internet
Lg2234s monitor goes of blinking...cant turn monitor off (blue light remains off) then monitor turns on ..screen pic returns but is totally green, the OSD becomes garbled, if set to return to default then...
emale36, Could be problem with the "switch-mode-power-supply" inside the unit. If dc voltage rail is noisey or marginally on the low side of rated specification then strange things will start to occur on screen. Contact LG (Lucky-Goldstar) if unit is covered by warranty. The unit will need to be evaluated by technician. Visit YOUTUBE to see video clips of monitore being repaired by their owners. Read more of my profile responses to other LCD owners. 12fixlouie
Dec 06, 2009 | Computers & Internet
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Apr 13, 2009 | Gateway FPD1975W 19" LCD Monitor
HP L1706- screen is blank when I switch on
First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
Feb 06, 2009 | HP L1706 17" LCD Monitor
SVA Color TFT LCD is white on start up but goes blank.
when i turn the computer on the light on the monitor blinks green but i cant get it to turn on..i have a black screen.
Jan 16, 2009 | Computers & Internet
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
BenQ FP731 17" LCD Monitor Logo
2,663 people viewed this question
Top BenQ Computers & Internet Experts
Tony
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
