Question about Optoma / CTX EzPro 610H / 615H Replacement Projector Lamp - SP.81218.001 Projector Lamp
Image upside down
Question is about OPTOMA PROJECTOR MODEL 610H The bulb on my ceiling mounted projector went out. Luckily, I found the same kind of projector in a storage room that hasn't been used. Our custodian switched the old projector out for the newer one -- he put it in the same way, and all cords are in exactly the same place, but the image is UPSIDE DOWN! PLEASE HELP !
I'm on this site because my projector is down after swithcing out the bulb or I could jot down the exact steps for you. It's a very easy fix. When you push the menu button on your projector to get into settings, there is one that will allow you to flip the image. Sorry I can't be of more help
Posted on Aug 08, 2009
Runco picture upside down
Yes possibly because you have done a complete system reset and not a lamp hour reset so you will need to go into image or screen settings and select front view ceiling mount configuration
Apr 14, 2013 | Office Equipment & Supplies
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
The image projected is upside down
not sure where it is in that model as #I have 700x, however theres an option for whether it is ceiling mounted or not, turn that off.
Jun 09, 2011 | Optoma HD65 DLP Projector
I want to hang it on the ceiling face down, but the it projects upside down!
almost all projectors have a menu setting to allow the image to be flipped when ceiling mounted. Be careful not to confuse this with the rear projection setting which it is also likely to have...this makes a mirror image.
Just go in to the menu using the remote or the buttons on the projector and you will find a setting in there
Apr 05, 2011 | Optoma TS400 Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
The image of my optoma hd803 became inverted.
Go into menu settings, look for a menu item that has to do with screen size and orientation. You'll be looking for the option to rotate the image for mounting the projector upside down on a ceiling mount.
Feb 06, 2010 | Optoma HD803 DLP Projector
My projector is showing the picture upside down
there must be a switch that controls that so people can mount their projector upside down on the ceiling
Jan 02, 2010 | Optoma DX605 Multimedia Projector
Just mounted my Optoma EP732B projector on the ceiling. Can't figure out how to get the picture to not be upside down? Help!
go into the menu settings, and look for image. should say "front", you'll want to change it to "ceiling"
Nov 15, 2009 | Optoma EP732 - HDTV Compatible DLP...
Optoma H56 - turns off just after start up.
It's not a short, the blub is near the end of it's life ~ the optoma is designed to detect when the blub is about to blow and shuts itself down. Turning the projector upside down or right side up usually only gives you a brief reprieve (some have reported a modest amount of extra time gained) on the blub ~ but in the end it's on it's way out and the projector will shut down again.
Oct 14, 2007 | Optoma H56 Multimedia Projector
Upside down projection
Download the latest display driver for your video card. If you are using ATI vc's then download and install the Catalyst Application which will allow you to rotate the screen orientation .
Jun 20, 2007 | Optoma H56 Multimedia Projector
241 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
