Question about Toshiba Satellite 1805-S204 Notebook
THE SCREEN WILL NOT WORK
A REMOTE MONITOR WORKS
  • Toshiba Master
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 16, 2009
My LG tv model number M2762DL will not show a picture. On the screen shows a code V3.14.0. What is the problem?
Somehow, you have gotten to a firmware information screen. Try pressing OK and Exit simultaneously on the LG remote. (Note: this doesn't work if you use a generic or other universal remote.) If you don't have the remote, you can try pressing Menu and OK on the TV. (These are the second and third buttons from the left.) I've only seen the remote method work.
If that works, you'll probably need to open the input list and change the current input. Press Input on the remote or on the TV (the leftmost button).
I hope this helps.
Jan 16, 2015 | LG Electronics M2262D 22" LCD Monitor
Hello i have a 19 inch LG M197 WDP monitor/tv, when i switch it on the screen is white with a little gray bock that flashes and slowly moves across the top of the screen reading v3.02.0 which i presume is...
I also had an LG M197WDP tv/Monitor with the same problem. It comes straight on when plugged in, but with the blank screen and scrolling version number across the top.
The solution:
1. Use the remote control (check batteries first)
2. Point at the working TV and press either MENU or EXIT
3. Static should be seen on the screen.
4. Switch to standby using the remote, by preesing POWER button.
5. Switch back on using the POWER button.
All should then be working normally
Jun 20, 2011 | LG M197WD-PZ 18 inch LCD Monitor
Rca remote control CRK76TA1 has problem w/ sending signal to tv. if i wiggle the eye, it will work for a while. now, no amount of wiggling will work. i have tried removing batteries and pushing every...
Remote is broken.Replace it.
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 06, 2017 | RCA Televison & Video
I have a T220 Hd monitor/tv bought 2 years ago. From 2 days the remote control (nearly never used) doesn't work and every 2/3 minutes appares on the screen the menu to select the brightness the colurs...
the batteries of remote control may exhausted , replace it
the remote control working you may check through your mobile camera by following step
1. point the camera in front of your remote control's eye that is the LED
2. now press the remote control's any button and see in the mobile camera that LED is glowing or not
3. you may check other working remote of any other product which you have by this way i.e. through mobile camera
Aug 22, 2010 | Samsung T220HD LCD Monitor
I see a black screen when I turn thw computer on
The first thing to do is to check the lead from the monitor to the computer is correctly plugged in at both ends.
If this is OK then perhaps you try another monitor, if an other monitor works OK then yours may be broken.
If another monitor does not work then you will need to check your computer hardware and software.
Oct 30, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Same problem- SyncMaster goes on/off, bad TV image, needs reset
try to update the monitor driver tehn check the same with the cables from cpu detached if no signal comes for long then the monitor is fine also try to check the monitor on bios screen
Sep 15, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Screen display is hard to see, it was working fine and the all of a sudden I can hardly see what is on the screen. Remote login to the laptop everything is working great.
Remote login? Are you saying you see everything the computer is doing from a different machine?You have a defective inverter , which will result in no back light for your LCD screen. This is something a repair shop will have to repair or if under warranty the manufacturer should repair it.
Sep 10, 2009 | Compal EL81 Notebook
Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
Jul 21, 2009 | Sylvania LC420SS8 LCD TV
No picture
A blue screen suggests no input signal, or a signal that the electronics in the screen can't handle. I don't think you need the remote, but, it may help. I suggest you try the dvd on a working monitor and check that it's a compatible output. The LM-S6001 is a multi-system monitor both NTSC(US) and PAL(Europe/Aisa). The monitor has a composite video (usually yellow) and RCA(phono) input and DIN, the manufacturer is unclear if both plugs are present. You can assume it's auto-switching, but that may not be the case. More information is needed to fully understand your problem. 1. make/model of DVD. 2. description of external plugs on monitor.
Apr 24, 2007 | Savv LM-S6001 Car Monitor
Toshiba Satellite 1805-S204 Notebook Logo
125 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
