Question about HP LaserJet 3330MFP All-In-One Printer
The scanner bulb goes back and forth about an inch in hp 3330 prt
IThe scanner bulb goes back and forth about an inch or so and does not stop. Keeps doing this and will not allow any printing or anything. Have to shut off, then will work for a few minutes and then same.
  • 21 Answers
The scanner blub mirror needs to be cleaned and possibly the underneath side of the scanner glass. The scanner is not finding the marks to make it function correctly.
Posted on May 26, 2009
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
HP Laserjet 3330 Multifunction monochrome printer,copier,scan and fax. This machine will warm up, and after it reads "scanner lamp warming", the scanner lite lights up, the carriage moves back and forth,...
This type of problem is usually caused by dirty mirrors in the scanner. After a few years of use the mirrors and lenses in the unit will get a fine coating of dust particles on them. The dust interferes with the scanner initializing the optics. When this happens the unit displays the Scanner warming up message on the screen and keeps trying to move the scanner assembly to get a good reading from the pickup. To solve the problem you will need to disassemble the scanner portion and clean all of the mirrors with window cleaner and a soft cloth or q-tip. To get dis-assembly guides just do a google search for the 'scanner warming up' error.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 04, 2010 | HP LaserJet 3330 All-In-One Printer
HP laserjet 3330 keeps flashing scanner error power off. I unplug and start again. It will print and then goes back to this same thing.
Remove and replace the power cord from the unit.
Wait approximately for 35 seconds for the scanning assembly to "walk out"(move to ready position)and then quickly remove the plug again.
Repeat step 1 and 2,three or four times until the head (scanner lamps)moves approximately 1 inch away from its normal resting place.
Replace the plug and let the product fully finish the boot cycle.
If it does not resolve the issue or the issue returns,upgrade the product firmware may help.Visit this url http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=72628&lang=en&cc=us&prodTypeId=18972&prodSeriesId=66359&taskId=135
and then upgrade the firmware.
Feb 10, 2010 | HP LaserJet 3330 All-In-One Printer
Hp 3330 scanner does not work
You do need the scanner for all functions. When this scanner error come up, it is talking about the thing under the glass that has bulbs in it and moves back and forth. The error can sometime be cleared by cleaning the scanner real good. But you will most likely need a technician to do this.
Jun 16, 2009 | HP LaserJet 3330MFP All-In-One Printer
How Do Stop Scanner Bulb From Warming Up?
There are 3 possible causes to this problem.
First dirty scanner optics this causes scanner to unable to get to the home position. This step should be done first. You will need to remove the ADF assy, left, right covers, remove control panel, remove control panel base cover, remove 8 screws 4 on top and 4 under scanner assy ( One screw on each side of scannerie front, left, right, back) Then carefully remove the glass. You should now be able to see the scanner assy, you will need a small flat screwdriver to disengage the tabs holding the scanner cover in place. Clean all mirrors with DRY q-tip. Reassemble and test.
2nd After cleaning scanner optics still doesn't resolve problem next step is to replace scanner formatter. You will need to open left cover, and remove the 2 screws and remove the smaller left cover. The scanner formatter can now be seen.
If above steps do not resolve problem, replace the scanner assy.
Nov 13, 2008 | HP LaserJet 3330 All-In-One Printer
the cables connected internally to the scanner unit had gone short some where in between you have to check it manually by opening the device .and then remove the cables and replace them with a same length cable.you can get the cables from any electronic shop who keeps printer assessories.
Sep 29, 2008 | HP LaserJet 3330 All-In-One Printer
Scanner error message hp laserjet 3030
This problem has to do with the scanner mirror. You may hear a grinding sound, also. The reason it does this is because the scanner bulb cannot find 'home', so it keeps trying to find it. Well, it uses the mirrors to reflect on another object inside the scanner to tell it when to stop. The mirror on top of the right next to the scanner bulb may need to be cleaned. This works every time for me, except the same problem always comes back sooner or later.
how to clean-
1.unplug your scanner
2.notice the glass covering on the left side, it can be removed with a Phillips screwdriver. Unscrew the plastic surrounding the glass and then remove the glass covering.
3.Plug the scanner back in and wait for the scanner to move left and then unplug it before it starts moving to the right. Repeat this until scanner bulb is all the way on the left of the machine.
-an alternative method-
with the glass covering removed, use a pair of pliers to move the small belt that moves the scanner bulb. keep moving it until the scanner bulb is all the way on the left of the machine.
4.With the scanner bulb assembly in reach, grab a Q-tip and gently clean the mirror that is just to the right of the bulb. You might want a flashlight to see the dirt and dust.
5. Put the glass covering back on.
6. Plug in the scanner.
At first to me it seemed like it wouldn't work, but it does.
Hope it helps. Reply back if it does.
Jul 14, 2008 | HP LaserJet 3330 All-In-One Printer
Scan head/carriage not parking in one spot -- keeps moving.
The scanner is having trouble getting its "white reference" usually due to dusty mirrors, but can also be the bulb losing brightness. These are not a easy machine to pull apart if your not used to it.
Good colour laser MFP, depends on volume of prints and remember colour dont come cheap, but dont use refill cartridges, Kyocera and Oki both have good Models
Dec 01, 2007 | HP LaserJet 3320mfp All-In-One Printer
HP LaserJet 3330MFP All-In-One Printer Logo
103 people viewed this question
Seeker5211
Seeker5211
