Question about HP Officejet 5610 All-In-One InkJet Printer
Ink absorber counter
After cleaning the ink absorber counter pads, how do you reset the counter?
  • 21 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd28
Posted on Sep 06, 2009
Ink absorber is full.. how will i be able to reset it?
Follow the steps below.
1.With the printer powered off but connected to a power source, press the Power
button while pressing and holding the Stop/ Reset button.
2.When the Power is lit, press the Stop/Reset button two times while pressing and
holding the Power button.
3.When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4.When the on/off lights in green, press the Stop/Reset button the specified number
of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
5.Turn off the printer.( it must be turn off) then turn it on again
Good Luck !!!!!!
( In short )
In service mode.
Put Stop/reset 4 times orange => reset waste ink.
Put stop/reset 8 times orange => set level ink.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 13, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Tip
The Ink absorber is for waste ink when the printer cleans the printheads. All...
This error is common in all the newer variants of canon printers.. Canon charges 50-80$ to fix it! But it can be fixed by following the steps below:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with o
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
on May 01, 2008 | Canon PIXMA iP90 Mobile Printer
How can I change the foam pad that absorbes ink? What part is that called?
Hello
Its better to just remove them clean them up and replace it in the printer, because usually some printers require a reset code to re-set the waste ink counter. If the counter is not re-set there will come a time when then printer will refuse to print.
Here is how to clean your waste ink absorber;
Open the printer and locate the waste ink absorber near the ink cartridge.
Remove the absorber pad and hold it in cold water while squeezing the ink out. It would be wise to wear gloves while doing this, because the ink in the pad will leave stains.
Use paper towels to dry the waste ink absorber pad. Let it dry completely before installing it back in the printer.
Reinstall the ink pad into the printer and run a test page to make sure it works.
Apr 20, 2011 | Epson Stylus Photo R300 InkJet Printer
E8 Waste ink absorber full, or platen waste ink absorber full WHAT MUST DO?
I am told that this will reset your counter and eliminate the full absorber warning that you are getting.
Cleaning the pads is messy, sending the printer to Canon is expensive,
I used a simular reset code for my MP470 and haven't had any problems.
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Jan 14, 2011 | Canon PIXMA MP190 All-In-One InkJet...
The waste ink absorber is full
Press OK.
Press Copy.
Press OK.
Press Stop/Reset.
Jan 04, 2011 | Canon PIXMA iP90 Mobile Printer
"The ink absorber is almost full. Press printer's Start button to continue printing. Contact the service center." What does this mean?
This means that the counter related to the amount of ink these pads absorb during print head cleaning cycles and from edge to edge printing is nearly at the programmed limit. You can still print by pressing the Start button.
However, you can expect the printer to stop working soon. You can clean out the waste ink pads yourself. This is a bit messy so have plenty of newspaper around. Disassemble the printer from the top. The pads (rubber of some type) are below the cartridge carrier on the side. Pull them out and blot most of the ink off them. Then run under water until the water comes out clear. Allow to dry (you can speed up the drying process with a hair dryer).
Finally reset the waste ink counter in the service mode:
With the printer off but connected to power, Press and hold Set/Reset and then press the Power button. When the power light is lit, continue to hold the Power button and press Set/Reset twice. The light should be green.
Now press Set/Reset 4 times (the light will switch between orange and green at each press). Turn off the printer. The counter should be reset.
Do not reset the counter without cleaning or replacing the pads. You will get ink spreading all over the printer. Additionally, the waste ink counter is set to a value that should be reached near the printer's end of life with normal usage. Other parts may fail soon.
I hope this helps.
Oct 03, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber full
There are two possible reasons for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads
. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error.
Reset the Printer using an MP Tool
Mp Tools are utilities designed to clear errors that will appear in an MP160 printer. Download this MP Tools here.
while the printer is on Run this software
1. Click Reset Main (main) to reset the waste ink counter and
2.
Click Reset Platen button (E27).
If errors still persist.
Press and Hold down Reset button and wait until the printer restart.
Release the Reset button and wait until it fully initialize.
Happy printing.
Please comeback and rate this answer.
Thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber is full cannot print
Mp Tools are utilities designed to clear errors that will appear in an MP150 printer. Download this MP Tools here.
2.
Happy printing.
Aug 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber (sponge part)
2.
Happy printing.
Waste ink absorber is full and need to be replace unable to print
The waste ink absorber is a pair of pads at the bottom of the printer paper path (one on each side). You can order replacement pads from a service center. Alternatively, you can resuse them. First, you need to pull the old pads (have plenty of paper towels handy). This can take nearly disassembling the printer. Then rinse the pads with running water until they are clean and then let them dry, if you want to reuse them. Once dry, reinsert them and reassemble the printer.
Next you need to reset the counter for the waste ink absorber. With the printer plugged in but off. Press and hold the Stop/Reset button then press the power button. Once the Power light is lit, press the Stop/Reset button twice while holding the Power button. Release the buttons in any order and the printer is in a service mode. With the lights Green, press and release the Stop/Reset button four times (the light will go orange and green alternately and will be green at this command). Set the counter to zero. Press the Power button to save the setting. Then turn on the printer normally.
Do not reset the counter until the waste ink absorber is cleaned/replaced, you will get ink everywhere.
Please note that the printer was designed to fail about the same time that the waste ink absorber counter hits the point that locks the unit. (ie the waste absorber doesn't get full while the unit is under warranty), the printer may have additional failures soon.
I hope this helps.
May 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
473 people viewed this question
Seeker5211
Seeker5211
