Question about Air Tools & Compressors
Part needed i have a 25ltr draper compressor and need a new condensor part 28433. i live in telford, shropshire. can you tell me where i can locally get a part from. please reply asap. thanks mike smith the.smithys@blueyonder.co.uk
  • 58 Answers
Hi yellow pages electric motor rewinds any good rewind shop will have them just take the old one with you hope this helps merlin v12
i am a retired blacksmith and have loads of gear to sell /intrested chrisdoughty@sky.com
nr runcorn cheshire
Posted on Aug 19, 2009
02 Lancer air conditioner
The compressor must be the problem based on the price of the repair.
Oct 18, 2012 | 2002 Mitsubishi Lancer
How does the Draper stud detector work
It produces a tuned magnetic field of it's own, and when a live wire or a nail enter that field it changes the loading in the detector's circuitry throwing it off tune, and depending how it is thrown off determines ifit is a nail, a wire or a live wire.
It is the same basic principle of a metal detector you would use onthe beach to find metal things.
Feb 03, 2012 | Draper Measuring Tools & Sensors
I'm located in the UK (Telford, Shropshire - 35 miles from Birmingham), How do I align my telescope accurately? Is there a way of entering my Postcode?
Follow the 2 star alignment procedure as outlined in the manual.If you don't have one, it can be downloaded from Meade.com. Also, contact the Royal Astronomical Society to see it there is a local club that can help you.
May 20, 2010 | Meade ETX-125AT (500 x 138mm) Telescope
My comprsser dont start just the fan runs cap to corroded to tell what uf it is it is a 3 ton duncane condensor
If you get the compressor brand and model number, You can call your local parts store and they should be able to tell you.
Feb 18, 2010 | Heating & Cooling
Have a draper compressor. not used much keeps blowing fuse
Compressors blow fuses/breakers for only a few reasons. The most common cause by using an extension cord. It is most often recommended to use more air line instead of a extension cord or at least one that is sufficient to handle the current draw of the compressor.
The next problem is too many items being used on the same circuit that you are using the compressor on. Ideally a compressor should be isolated from all other electrical devices own it's own dedicated circuit.
The last issue is an incorrect rating on the fuse/breaker or one that is worn out.
I hope one of these items takes care of your problem if not please let me know.
Nov 23, 2009 | Draper Air Tools & Compressors
Replace belt
Sourced the part no and stock number on the Draper site, then sourced the Manual on the Draper site too
Nov 17, 2009 | Drills
Smoking a little. Maybe new rings?
Where is it "smoking" from? If it is out of the crankcase breather, you are on the right track looking at rings. Otherwise, it could be the valves.
Oct 18, 2009 | Draper Air Tools & Compressors
Replacing AC compressor
its not easy, you have to recover freon, then braze in new comp if old one burned out you need to not only replace liquid line drier but also suction line. if it is a burn out that means you had a brown out or it is grounded. you can tell because the smell is very potent. if its not a burn out make sure to replace liquid line drier and pull into good vacuum. just make sure it is worth it also if the unit is over ten years old replace condensor.
one problem i do not know where you live but if the system is R-22 you may have trouble getting new compressor good luck if you have any question let me know
Sep 15, 2009 | Heating & Cooling
Wiring Question York Diamond 90 Condensor Unit - New Capacitor
the wire diagram should tell you how. it all depends where wires lead to. be very carefull, capacitors can be dangerous. brown usaully go to fan black usaully goes to common red usaully goes to herm or compressor. it all depends where wires come from
Aug 27, 2009 | Heating & Cooling
I need help selecting the best Amana 5 ton furnace/ac.
I believe you are asking which furnace to go with?
Just some clarification first.
The "condensor" is the outdoor unit.
A "Compressor" is the device inside the outdoor unit that pumps and "compresses" the refridgerant.
An evaporator is the indoor coil, it has refridgerant running through it.
The furnace is completely seperat from the condensor and evaporator.
I "THINK" you are saying that you are looking to buy an AMANA system with a 5 ton 14 to 16 SEER condensor, and a furnace, but you need suggestions on the furnace.
typically when you purchace a condensor, the evaporator coil is simply matched by the manufacturer to the specific condensor you purchace, there is no choosing to deal with. All condensors ofcourse come with a compressor already installed.
If my assumption about your request is correct, maybe this will help.
Amana's 90+ furnaces are great units. I would recomend them to anyone. The 80+ uses a somewhat inferior heat exchanger, and is ofcourse less efficient.
Anything higher than a 90+ can take quite a while to recoup the costs of the enitial purchace through your efficiency savings.
If it were my home, I would go with the 90+ furnace, and the 16 SEER Condensor/evaporator system. But ultimatly, its up to you, your efficiency standards and your wallets potential.
If you live in a northern state where AC is little needed, I'd go with the 14 SEER AC.
Again, an initial cost verses long term savings issue.
Dec 09, 2008 | Amana Heating & Cooling
Air Tools & Compressors Logo
71 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
