Question about D-Link AirPlus DI-524 Wireless Router
Wireless access howdy! i have an iBook g4 with with a wireless card built in.to connect to the net can i use any router or do i have to spend big on an airport?
  • 3 Answers
Your iBook is compliant with any 802.11b/g gear. Just follow the instructions in the router or access point's manual for setting up. Usually, wireless routers and access points include their own proprietry software for the initial setup. This helps in locating the device on the network but it is not necessary and will probably not have a mac version for you. Every wireless AP and router I've seen has a platform independent web interface for configuration.
Posted on Oct 16, 2007
I can't get my macbook to coonect to hughes net
Hi. Is it your MacBook or your router that won't connect? the first point of contasct is the router, it connects to the net and provides the links to whatever is attached to it. The macbook talks to the router and the router delivers.
Mar 22, 2012 | Apple iBook G4 Mac Notebook
Can my apple ibook g4 work without an airport extreme card
If you mean 'work as a computer' then the answer is yes.If you mean 'work on the internet' the answer is yesIf you mean 'work wirelessly on the internet' then the answer is no.
You can use an ethernet cable to connect to your Router and that will give you the internet.
Feb 18, 2012 | Apple iBook 12 iBook G4 1.33GHz,...
My powerbook g4 no longer recognize my builted in airport, have no airport now. The only way to make my g4 work in hook an either net cable to my g4 into my router. Makes my laptop very stationary, what...
What I would suggest is reseating the airport card as it may be the card has come loose or the cable is not connected properly. The following support page on the apple website will tell you how to do it.
support.apple.com/kb/HT2617
Failing that you will probably have to buy an new airport card or a wireless usb adaptor. You should be able to pick one up from ebay fairly cheaply.
Hope this helps.
Apr 17, 2011 | Apple PowerBook G4 Mac Notebook
Can not get on internet with note book don't know what code to enter
1. Yes, but you have either have to have access on the router or if it is a free connection you will have to scan for that router to gain access and click on the router that is open to you if you have a wireless card in the Sylvania G net book which should have a wireless card built into the mother board. It will take you to set up your net book for wireless connectivity.
2. If you are trying to get connection through wireless router via a home network the administrator will have to allow your net book to have access, that is he will have to give you permission to connect with either a MAC address or an IP ( internet Protocol address).
Sep 17, 2010 | Sylvania G-Netbook
Mac ibook g4 connect to an existing wireless network?
Usual problems are making sure that you select the correct security options at both ends and then DHCP problems. I would disable DHCP on the mac and select your own IP address above the existing ones to start with
Oct 11, 2009 | D-Link DIR-625 (790069292637) Wireless...
My iBook wont connect to my Linksys wireless G router
try removing the passkey and security on the linksys
then enable reverse authenication, by allowing only specific MAC addresses to access the router. ( MAC FILTERING ) ONLY ALLOW
then add the MAC addresses of your IBOOK and what ever else you have..
simple and secure :)
Aug 21, 2009 | Linksys Wireless-G Broadband Router
Ibook g3
First of all, you need an Airport card for the iBook G3, chech for example this link; http://popular.ebay.com/ns/Computers-Networking/Original-Airport-Card.html (you should buy one like this: 9deeeda.jpg
, there is a G4 card too, but your iBook doesn't support this one).
Next, install it;
Then, buy a wireless router that uses 802.11b/g or 802.11b. This is very important because your airport card doesn't support 802.11g, and install it, but don't protect your network with a WAP password, your iBook doesn't support this, but use WEP.
Then start your iBook, and click on the Airport icon in the right corner, select your network, type in the password and it will work!
Jul 01, 2009 | Apple iBook G3 Mac Notebook
AirPort Password
This article provides instruction on the installation of the AirPort Wireless Networking card into a Power Mac G4 (AGP Graphics) computer. Similar instructions, with graphics, are included with the AirPort card.
1. Shut down the computer (choose Shut Down from the Special menu) and unplug all cables except the power cord.
2. Touch the metal PCI access cover on the back of the computer to discharge static electricity. Avoid walking around until you have finished installing the card. Unplug the power cord then lift the latch on the side of the computer.
3. Gently lower the side panel onto a clean, flat surface. Lower it onto a soft cloth to avoid scratching the case.
4. Connect the antenna cable to the connector on the end of the AirPort card. The cable is usually stowed on the side of the PCI card guide.
5. Remove the metal clip and pull the AirPort card from the adapter card, shown below. The adapter card and clip are not used with your Power Mac G4.
6. Insert the AirPort card (serial number side up) through the opening in the PCI card guide, and into the connector on the main logic board as shown below.
7. Raise the side panel and press it against the case until it snaps into place.
Instructions for using the AirPort software are in Mac Help, available in the Help menu.
Wireless Internet access requires an Internet service provider (fees may apply) and AirPort (or AirPort-compatible) wireless Ethernet card and base station. Some ISPs are not compatible with AirPort. For more information, see technical document 106590: "AirPort: Requirements for Wireless Internet Access"
try the above link to get more detail.
Thank You
Sep 11, 2008 | Apple (APP M7600LL/D) Wireless Adapter
SMC 11n Router: wireless set-up
Hi there!
Do you know how to check the wireless IP address at your iBook?
May 04, 2008 | Computers & Internet
D-Link AirPlus DI-524 Wireless Router Logo
53 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
