Question about Casio Exilim Pro EX-P505 Digital Camera
Camera won't work if the memory card is inserted
My camera doesn't work if the memory card is inserted but if you remove it the camera is perfectly fine. hours before it was working properly. there is a green light that blinks once in a while.
Don't know if that works for you.
I just use another memory card.
I have 1 card my P505 doesn't work with.
Others are fine.
Hope this helps.
Rosi
Posted on Mar 31, 2009
Pictures show up on memory card in camera, but computer won't recognize the card - either inserted directly or by USB
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 11, 2012 | Nikon D40 Digital Camera with 18-135mm...
My vivicam x024 won't turn on. how do i remove the memory card? will the photos still be on the card if I remove it?
The SD memory card slot in located on the side og your camera. Push the SD card and it will pop out.
The photos are stored on the SD memory and removing it from the camera will not lose the photos stored on this SD memory card.
Remove the memory card from the camera and insert it into anUSB memory card reader. Connect this USB memory card reader and memory cardinto the USB port of your working computer. Your computer will see this as anUSB Mass Storage Device or an external storage device; you can then open thefolder on the memory card and copy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 28, 2012 | Vivitar ViviCam 5100 Digital Camera
Does the camera have an internal memory?
The 500D doesn't have any internal memory for picture taking. It won't store any pictures unless you insert an SD card in the slot just above the battery on the right side of the camera (when you are looking at the screen)
Dec 04, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
What is memory stick error C:13:1
It is caused by the camera not reading the memory card properly. Try removing the memory card, then insert it again, wiggle it a bit. Of it still won't work, try cleaning the gold parts of the memory stick, using an ordinary pencil eraser.
Sep 18, 2011 | Sony Cameras
Why won't my Olympus sp-600UZ accept my memory card. It' keeps tell me error can't read card
Ok try this for you to determine if your memory card is defective or not, try to insert your card to a device that support the type of memory card you have. Then if it still doesn't work i assume your memory card is defective. But if the memory will work try to insert other memory card on your camera for you to determine if your camera memory slot has a problem. Reply to this post post if this helpful or not and dont forget to vote Tnx for using Fixya
Jul 24, 2011 | Olympus SP600UZ Digital Camera
Sony Cyber-shot DSC-W370 says reinsert memory card. We have reinsert the card correctly but it continues to say that. Is the camera beyond repair?
you'll make sure that you camera is not the problem is when you insert other memory card that is working on other cameras. if that doesn't work at all try to look for any foreign object that block memory card insertion contacts or you can buy a contact cleaner spray for electronic parts and spray it on the memory card holder part of the camera.
May 28, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
No disk installer and memory card wont work
The 8025 doesn't have much internal memory. Without a memory card you can take a test photo but it will disappear when you turn off the camera. You REALLY do need to insert a memory card (SD or SDHC, up to 8GB in size) and format it in the camera.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
May 30, 2010 | Vivitar ViviCam 8025 Digital Camera
Fuji FinePix F470 works perfectly unless a memory card is present
Some cameras are very sensitive when it comes to memory cards for some odd reason. I would try a different make of sd card.
Oct 13, 2009 | Fuji FinePix F470 Digital Camera
Camera will not read memory card
Make sure you format your memory card before you try to use it other wise it will save the pics to ur internal memory instead of the mem card.
May 01, 2007 | Casio EXILIM ZOOM EX-Z10 Digital Camera
Casio Exilim Pro EX-P505 Digital Camera Logo
135 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Starnley Johnwells
Starnley Johnwells
Are you a Casio Camera Expert? Answer questions, earn points and help others
