Question about RCA Scenium D40W20 40" Rear Projection HDTV
D40W20 SET WORKED BUT HAD 3 ONE INCH DIAG. LINES ACROSS PIX. PIX. ALSO HAD RAGGED EDGE ON RIGHT SIDE. WHEN CHANNEL WAS CHANGED MOMENTARY LOSE OF HORZ. SYNC. ALMOST AS IF HORZ. HOLD WAS JUST OFF FREQ. LIKE OLD SETS. I PULLED HORZ. MOD. AND CHECKED FOR COLD AND/OR CRYSTALIZED SODLER JOINTS. NOW SET WON'T COME ON AT ALL AND NO I DID NOT BLOW THE FUSE OR SHORT ANY CONNECTIONS.
  • 979 Answers
Part of your feedback voltages are now incorrect. Find the solder bridge and remove it then see if you at least get back where you were...accordianman
Posted on Jun 25, 2008
How do I fix my Sharp tv from right side to center there's a half inch black line 9 inches down from top on screen and it changes color depending on background and UNDER the line the image is blurry a
If this is done with every input of your tv and also with tv channels this means a bad circuitboard .You can find on ebay one and mod it yourself. Its not such a difficult thing.
Nov 26, 2014 | Sharp LC40E67UN TV
LG 50" the pitcher is off the screen each side by
Ok, first make sure you or someone in family didn't hit the "HD Zoom" on your cable remote or whatever kind of remote you have. On ours - Cable- if you hit it once it is in "Normal" picture which on ours has black around edges on a non Hd channel. Then if you hit it again it Zooms once makes pix very large and if you hit button a third time brings it into a wide screen Zoom that fills the Tv screen. If we are viewing HD channels I put it on Normal which will fill the screen and give you the best HD pix. If we are viewing a NON HD channel, then normal will have black on sides, so I hit the Zoom a couple times to fill in the screen. My brother in law had this problem and couldn't figure out why his Sports channel Scores were always half cut off the screen! it was zoomed in too much for that channel. His sports channel was in HD so needed to be on normal instead of zoomed in.
if it is not the Cable remote then this is a second possible cause:
The other thing that happened to me was - we hardly ever use our original TV remote that came with the TV. but one day our picture looked weird and the cable remote didn't adjust it. One of us had hit the "P SIZE" button on the TV remote. this changes your pix from - 4:3 ratio to 16:9 ratio and vice versa. I put clicked that button and on the TV it shows whether it is at 4:3 or 16:9. For newer wide screen TVs you want that set at 16:9 ratio.
All cable company remotes probably are a bit different so check with your company ... to find out where the zoom control is on their remote.
Feb 27, 2011 | LG Televison & Video
I have a dark line on the right side of the screen
If there is a dark line with two sources such as a dvd player, and a game system, or a cable box, then the tv will need to be repaired. If not from two sources then the issue is with the only source causing the black line.
May 05, 2010 | RCA Scenium D40W20 40" Rear Projection...
My monitor goes black with a horz white line across the center. It is a Lacie on a g4 mac . It is about 6 years. old.
The lcd is bad usually the lines start very small and rapidly over time become about an inch or so thick.
Oct 07, 2009 | Computers & Internet
Horizontal Lines when Viewing HD TV
Would you please change the picture mode 4:3 or scan fit to 16:9?
Nov 19, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Blue on the left and right sides of my rca scenium, 65 inch hi def rear projection tv
Well what may have happened is a bad thing, See if you can find some way of displaying a totaly white pix, and have this full size filling the entire screen. If the side bars are still there this means the CRT's are burned and this is a perminate thing, The fix would be to change the CRT's mabe just the green and the red but they still run about $285.00 each. This was cause by having the set run in a format that DOES NOT fill the entire screen
Jan 12, 2008 | RCA Scenium D40W20 40" Rear Projection...
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
RCA Scenium D40W20 40" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
