Question about Canon PC-735 Copier
My Canon PC735 copier turns off after it grabs the paper.
Even tried manual feed and that also turns off the machine.
  • 328 Answers
Main lamp is most likely burned out or is shorting.
You can google it and find a replacement bulb. Not too difficult to replace. Remove the top cover and glass. Make sure your hands are very clean or use a clean cloth to handle the new bulb.
Posted on May 15, 2009
We have a Cannon PC 735. What does error message E2 40 mean??
Posted on Sep 15, 2011
Why won't labels feed?
Labels are a tough feed for any printer because the surface tends to be slippery. Yes you should replace your pickup roller or at least clean it with a damp cloth so that the surface is grippy and not coated with paper dust.
Aug 06, 2015 | Canon imageCLASS MF4890dw Wireless...
Constant paper jam on Canon PC735 copier. Tried all the usual steps to removing or preventing as paper jam, and they are not helping. The problem started after the cartridge was removed and rocked back...
If the machine did not show a paper jam until the toner cartridge was removed and then reinstalled, I would remove the cartridge and check the paper path for the paper switch, it normally is a small black lever. Make sure it isn't stuck in the down position. If the switch is OK, check the cartridge to be sure there isn't any damage that may cause the paper switch to be actuated when the cartridge is installed into the machine. Sometimes there is a protective cover on the cartridge that moves when installed, this cover can be knocked out of place.
Jul 19, 2017 | Canon Office Equipment & Supplies
Printer feed will just not grab paper
Rollers need replacing. They are supposed to have tread like tires, if not, Replace.
Apr 06, 2010 | Canon Office Equipment & Supplies
Canon PC735 copier, paper jam light keeps coming on but there isnt any paper or anything blocking the machine. Tried resetting but nothing has worked. What can I do?
My canon copier pc735 says we have a paper jam- but it does not. We just replaced the cartridge and it wont work. I had them send me a new cartridge, but its the same thing- paper jam. Help!
Oct 10, 2009 | Office Equipment & Supplies
Grab paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 27, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
CANON PC735 COPIER, PAPER JAM LIGHT KEEPS COMING ON BUT THERE ISNT ANY PAPER OR ANYTHING BLOCKING THE MACHINE, TRIED RESETTING IT NOTHING WORKS PLEASE HELP.
For the problem with the personal copier pc735 paper jam, I had the same problem. I was told the problem might be fixed by downloading the drivers and reload them. The PC735 I have does not have drivers nor a scan. My problem was a spring fell off on the idler gear and had to be reattached. I then cleaned the interior and this fixed the copier. You might look to see if a spring came loose on the back side of the bottom frame. I'm no machanic so I had a canon rep fix it for me. This fixed my problem. No more paper jam light.
Bob At DottyW4658@aol.com
Jul 16, 2008 | Office Equipment & Supplies
Sharp AL-800 Paper Feed
Is this something that has been getting worse or just happen at once? If it just appeared it good be something in the paper tray stopping it from liftting or something behind the paper tray or in the paper path of the copier. If it has been slowly happen try to clean the paper pickup rollers with WD-40 and a rag and clean the rubber only. If that works you done, but if it say's to add paper you may have a broken paper present sensor. The jams could also be the paper feed clutch is worn out. Worse case use the bypass tray. Good Luck!!
Feb 07, 2008 | Sharp AL 800 Copier
Paper Feed Error
Your saying the printer grabs the paper on the one side more than the other?
Nov 13, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Canon PC-735 Copier Logo
320 people viewed this question
old marine
old marine
