Question about Samsung CLX-3175FN Printer
Paper is stuck in the top back of the printer and I can't get to it to remove it
I have a Samsung CLX-3175FN and the paper is stuck in the top part of the computer and I can't get to it to remove it
    Scholar:
  • Samsung Expert
  • 113 Answers
by removing the top paper. you got to open up your scanner. on the side there is a latch with a small black cover on the middle. use your finger go to the back of the small cover ans push towards you it shall have came off. remove it and use the press and pull techic your scanner top shall be able to go 90 degrees. there you will be able to see if there is any paper stuck. next open the back door ands flip up the fuser green latch on both end this is to free any paper that got stuck
Posted on Apr 19, 2010
Clx-3175 laser printer always results in a paper jam -why? how to fix it? Help help please
first remove the power and remove the cartridge cover and inspect for tiny piece of paper remove the piece of paper or you can use an mild air blower to flush it out for that first remove the toner and use the air blower and clean the inside of the printer if there is any tiny piece of paper the paper get jammed often
Oct 26, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung CLX3170 printer makes loud clanging noise when printing and smudges some lines. Started after a paper jam. Have turned off/on several times
there is a rest of the paper jamed still inside the printer you need to remove all the jamed paper then it will work, to find out where the paper stuck's open the front and rear cover, maby you have to remove the toner cardriges as well.
May 17, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Paper Jam 1
there is most probly a pease of paper in side the fuser unit.See if you lift the top cover just under the scanner, the hole top lifts up!!!!!!.in the back you wil be able to see the fuser.Be carefull IT IS HOT!!!!!!!see if you can get eny papers in there.And try to take it out carefully.Otherwise will have to strip it to take the fuser apart to clean it up
Jun 03, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
I can'r find the paper jam in the printer. screen
If not picking up the paper then it the Pick-up Roller just above where the paper tray is. Remove the paper Tray and Tip Printer back so you can see under the Printer. Take some rubbing alcohol and clean off the rubber roller
Service Manual found here Free...
http://hotfile.com/dl/28988134/55113fe/CLX-3170-3175.zip.html
Feb 09, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Paper keeps jamming when printer warms up on my samsung CFX 3175FN
Hi. can you try to lift the printer and turn it upside down. it is mainly caused by paper clips.
Jan 26, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
How to remove covers and fuser unit?
Ive got the same problem :( and because i used compatible cartridges, it apparantly voides the warrantly, so staples will not fix it :( so im now stuck with a £260 uselss printer :( good luck getting it fixed.
Sep 28, 2009 | Samsung CLX-3175FN Printer
Constant Paper jams on CLX-3175FN
The fact that there appears to be no actual jam tells me that it is not picking up paper out of the tray. Try some alcohol on the pickup rollers, rubbing well. If that helps, replace these rollers.
Aug 12, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
My printer is 5 weeks old. My Samsung CLX 3175FN color laser printer has a paper jam. I have removed as much of the paper as possible, but it is still jammed ( where I cannot get at it ) in the upper rear...
Have you turned the printer off then tiurn it back on. If you have a paper jam, after you remove the paper, you must restart it for it to clear.
Otherwise, if there is paper still in the printer, turn off the printer remove all 4 toner cartridges and the waste cartridge. Once you do that you may be able to see the paper. You may be able to take one more thing out to where you can see the paper better, I am not sure.
Kevin
Jul 19, 2009 | Samsung CLX-3175FW Multifunction Laser...
Samsung CLX-3175FN Printer Logo
212 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
