Question about Hifonics Titan TX 8805 Multi-Channel Amp Car Audio Amplifier
Lost caps I have lost one of the (turret?) caps on the rifle scope and I was wondering is there any way I can buy one. It is the one for changing windage the one one the side of the scope.I'm also from Canada and your site doesn't reconize my postal code.If there is some one local or if I have to import it I like the scope and love to keep using it.
  • 631 Answers
I'm not sure how this got posted in the car audio section...
If the scope was manufactured by a well established company, you should be able to get a new cap from them.
If you cannot locate the manufacturer, you can move the other cap to the windage adjustment to set the windage. Then when you're finished, move the cap back to the elevation adjustment.
Even if you use it for a shooting discipline that requires constant adjustment, it's unlikely that you'll need to use the windage adjustment for anything other than setting the zero.
Posted on Oct 16, 2007
How to change my battery on a 4x16x40 centerpoint scope
remove the battery cap, replace the battery, reinstall the cap.
Nov 27, 2013 | Centerpoint Technologies CenterPoint...
I have a tasco 3x9x50 world class rifle scope. The scope caps are stuck to the adjustment screws in top and side of scope. I am unable to unscrew the caps without unscrewing the adjustments as well. The...
Try some PB Blaster. Wet a q tip and apply to the area at the base of the turret caps. Wait a few minutes and reapply. Then using a small pair of vice grips attempt to twist the turret covers off. A cotton cloth will help keep the gripping surfaces of the pliers from scratching too bad. Hope this helps.
Jan 20, 2011 | Tasco 3-9x40 World Class Riflescope 30/30...
Elevation turret stripped out. Entire turrent turns with no adjustment . Turret came off when reinstalling cover. Was not forcing cover tight and had just started to tighten.
ok,,,you have strong fingers then????
try a drop of supper glue on the striped out turret thred,,,as the scope is a right off anyhow you have nothing to loose do you?
Sep 05, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
I can get the elevation adjustment cap off. Is there some secret to elevation adjustment?
if the scope is out the best way to set it up is to clamp the rifle in a jig or hold it hard done on a sand bag,,,firs off the first shot at the bull and see were the shot hit the card,,,now without moving the rifle turn the scope turrets till the cross is over the bullet hole from the last shot,,,now again aim at the bull and shoot again,,,the shot should hit the bull,,if not reajust the scope as before,,,
Aug 31, 2010 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
Windage adjustment will not adjust to the right - clicks but does not move the shot groups to the right.
if you have forsed the scope turrets you may have broken your scope,,,if the turret turns to the left set it to the center and change the scope mounts or pack out the scope mount with some strips of 35mm camera film 3 strips should do you,
pack out the eye end mount on the left side of the scope
Aug 28, 2010 | Pentax 4-12x40 Gameseeker Rifle Scope...
Is there a way to lower my turret after i've found my zero? my zero is at the 4th vertical tic mark on the 0.
No. The turret is what it is. If you want to re-set the turret to zero so that it is easy to return to for a specific distance, there should be a setscrew you can loosen, adjust the turret to zero, then re-tighten to lock it in place. If you are simply trying to lower the turret, you need to purchase a scope without target turrets.
May 24, 2010 | Leupold Long Range/Tactical M1 Mark 4...
On the adjustment turrets, after loosening the set screws, how do you get it to go down so the yardage lines up?
after you sight the rifle in at say 100 yd. lift the turret and line up the 100 yard mark on the turret to the mark, then push the turret down onto the scope and set the screw. some times the turret takes a lot of pressure to push back on.
Mar 29, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Adjustment Issue
the scope should all ways be fitted with the wind adjustment on the right as you look down the rifle, therefor the top ajuster is for up/down,
right ajuster is wind,,left/right, the easy way to set it up is to aim at some sand with the rifle on a stand or in a jig, shoot one round see were it hits and without moving the rifle, turn the turrets till the cross is over the point were the bullet landed, having a pall to move the turrets for you helps a lot here, the main point is dont move the rifle till the turrets have been moved first,, its that or bore sight it,,, jig the rifle up pointing at a target at say 200yds look down the bore aim the bore at the target lock down the rifle check it by looking down the bore again then set the cross up in the scope on what you see down the bore
you will need to tweek the scope a bit as you havent taken the bullet drop into the ajustment that way,,
Dec 17, 2009 | Zeiss 3-9x40mm Conquest Rifle Scope...
How do you sight it true for the rifles prior to using the windage and elevation turrets. All other scopes I,ve seen with range compensators have the ability to be sighted in. I can't figure out how to...
You can get a base line by bore sighting the scope. Bore sight kits are a bit pricy, might be best to take it to a gun range an start at 15 yards shoot a few move out to 25 the 50 then 100. Yes your scope should be sighted for one gun one round, with a cold barrel. Let it cool between shots.
Oct 14, 2009 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
I have a model D-4 weaver rifle scope with missing adjustment par
Pretty much all rifle scopes have great warranties. Send it into weaver and i'm sure they will fix it plus replace any parts. I'm sure they will charge for missing parts but it would be best for them to look at it and check it out. TP
Apr 07, 2009 | Weaver Optics
Car Audio & Video Logo
188 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Marvin
Marvin
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
