Question about Canon PowerShot SD850 IS / IXUS 950 IS Digital Camera
Canon ixus 950 shutter stuck half open . when turn on screen says lens error restart camera . tried leaving battery out for 1 hour but still same problem . any suggestions !!!!
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
Turned on ixus 75 and i have a black screen
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Pay particular attention to Fix #5A of the link.
Dec 23, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
What makes the screen stay black when camera is
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't help...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 14, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Mar 20, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
"lens error, restart camera" for canon powershot SD1200IS
problem in canon digital camera ixus 95 is
Do not open Power has never changed the battery and another also does not start
Oct 11, 2009 | Canon PowerShot SD1200 IS / Digital IXUS...
Lens will not go out
the lens is damaged.you want to change it.
Aug 26, 2009 | Canon PowerShot SD850 IS / IXUS 950 IS...
Canon PowerShot SD780 IS camera lens error. :(...
I did the same thing and it works only be restarting it now but it works lol. I threw it agianst my bed . SO BEAT THE **** OUT OF YOUR CAMERA..then restart and it should work..*** made **** what can you say
Jul 28, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
Camera not working
i have the same camera as you do and from what expert told me, i have to ship it to Canon or it's authorized dealer for repair. The repair costs about $100 dollars.
In my opinion, it's a rip off!!! :S
Jul 14, 2009 | Canon PowerShot SD850 IS / IXUS 950 IS...
How to fix canon ixus 7o lens error restart camera?
Do you mean its taking black pictures? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 05, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon PowerShot SD850 IS / IXUS 950 IS Digital Camera Logo
448 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
