Question about Homelite Mighty Lite Lawn Trimmer
My mighty lite will start but it runs on full choke but it stops
It will not run on run thank you. doug
  • Anonymous May 19, 2009
    Homelite trimmer stats and runs for about 6 minutes. Then, it tries to start and runs about one second and dies. Won't work again until ithe next day. Cleaned the air filter, changed the plug, and shot some carb coeaner into the butterfly. No change, Any tips?
  • ronr980 May 20, 2009
    Homelite trimlite trimmer starts and runs for about 6 minutes. then it
    tries ti restart but only for one second then dies. Changed plug,
    cleaned air filter, shot some carb cleaner into the butterfly. No
    change. Any tips?
  • 86 Answers
Your carburetor needs cleaned you had old gas in it this cloggedup your jets and made the diaprams hard witch will not move enough to pump enough gas to keep engine running off choke.
Posted on May 16, 2009
Hi my 12volt 7amp 60psi pump motor runs but dosnt pump it is not blocked Thank you Doug.
pump gears have failed --stripped teeth or loose on shaft
common problem if run with out fuel
May 05, 2017 | Cars & Trucks
Car had been sputtering and stalling while stopped in "drive". Mechanic mentioned to change the thermostat so I did it myself. The problem still exists and now the blower for the heat and A/c doesn't
  • Doug Warne Your kia here is what i would do to help diagnosisMar 19, 2014
  • Doug Warne First of all i would do these steps"
    Mar 19, 2014
  • Doug Warne how does it run when cold how does it run when hot
    Mar 19, 2014
  • Doug Warne i would look for Vacuum Leaks
    Mar 19, 2014
  • Doug Warne i would remove the spark plugs check engine compression hope to see about 180 psi on each cylinder
    Mar 19, 2014
  • Doug Warne i would exam each spark plugs to see if fowled with Gasoline or carbon keep spark plug with each cylinder because low compression will cause this
    Mar 19, 2014
  • Doug Warne low compression i would exam cooling systemicon1.pngfor airbubles or coolant in engine oil
    Mar 19, 2014
  • Doug Warne if oil looks milky white in color its coolant do not operate vehicle
    Mar 19, 2014
  • Doug Warne change head gasket get head kit with valve cover and take head to machine shop to have shaved straight and checked for cracks Replace head with Remanufactured if warrpiage to great or stress cracks
    Mar 19, 2014
  • Doug Warne check air filter and breather to insure the intake is getting air before you do compression test
    Mar 19, 2014
  • Doug Warne if engine dies when hot lets look at the fuel pump pressure
    Mar 19, 2014
  • Doug Warne lets take and look at the fuel cap where you put your fuel in make sure the vent is open which allow outside air pressure becuase you can have a 100 billion gallon second pump but if there is no air coming into take the pump will pump 0
    Mar 19, 2014
  • Doug Warne Check your OBD 2 codes First this will give you ideas of what happening ie bad oxgen sensor telling me look for vacuum leak or poor spark ignition or poor engine compression, possible injector leaking
    Mar 19, 2014
  • Doug Warne poor compression tell me the engine maybe out of timing and or valves or worn or burnt exspecially when engine is hot and it dies
    Mar 19, 2014
  • Doug Warne a cylinder leak down test would be revealing for valves or piston rings
    Mar 19, 2014
  • Doug Warne if engine has good Intake of Air and gas mixture and then good compression of air and gas mixture and good spark from the Ignition and good flowing exhaust the engine will operated smoothly
    Mar 19, 2014
  • Doug Warne if engine looses power or stalls when hot take a look at the catyalitic converters to see if glowing red or hot one side and cooler on rear side also check the exahust pessure at tail pipe to see if cats are plugged if you have little exhaust pressure and no exhaust leaks
    Mar 19, 2014
  • Doug Warne i hope this helps and i always kiss the job.............
    Mar 19, 2014
  • Doug Warne Keep IT Simple Stupid
    Mar 19, 2014
    Mar 19, 2014
  • Doug Warne as far as the thermostat is the engine running hot..????
    Mar 19, 2014
  • Doug Warne CHECK FOR AIR BUBBLES IN COOLANT as piston compress air if it leaking pass the headgasket seal into the coolant jacket this will cause air bubbles and you may loose heat out of the heater core...i have seen this with cracked heads also so if this is the case have head checked at machine shop
    Mar 19, 2014
  • Doug Warne check the oil from the dip stick smell it see if you smell gasoline this is telling me thin oil, possible injector leaking gasoline
    Mar 19, 2014
  • Doug Warne Low engine Compression with satuerate oil the oil ring on the piston will have hard time to create seal to cylinder wall there fore low compression exspecially when engine is hot
    Mar 19, 2014
  • Doug Warne get a spray bottle fill with water and with engine runing spray water in coil packs and spark plugs wires to see if there cracked or frayed Electricty is lazy it will use the water as a ciricut and go to ground through the water this is telling me cracked coil pack or plug wires engine will began to miss and fumble while running
    Mar 19, 2014
  • Doug Warne these are some tricks i use to help diagnosis problems....hope this helps
    Mar 19, 2014
  • Doug Warne As far as the A/c Heater Blower i would first check the Fuse in the box with a test light, and i would check all the fuses remember you have a battery side and ignition side of the fuse box if the fuse is blow replace with manufacture Amp Fuse and if new fuse shorts then i would look at blower motor draw
    Mar 20, 2014
  • Doug Warne Check your battery Cold Crank Amps with a load test meter most parts store will do for free hoping you will buy a battery and if batter test not good if you choose to not to replace your alternator will be charging constentently and the trio diode board in your regulator located inside the alternator in most applications these days will short then this will cause a battery high amp draw so your battery wont start in the am when your late for work..
    Mar 20, 2014
  • Doug Warne If your battery is loosing charge overnight or anytime you can simply take your negaitive Cable from your batter and put a test light from the negiative cable then touch your neg. terminal and if test light illuminates you have a draw and bad draw so take amp meter and test to see the draw in amps if high amp draw i would first look at the regulator and remove the 12volt singe wire and see if draw disappear if draw is no longer then 99 percent your regulator has shorted
Mar 19, 2014 | 2001 Kia Sportage
Just had remanufactured engine installed in my 04 lincoln Aviator - due to a broken timing chain by Pro-Teck auto in lakeville, MN. Egine light went on. Told by Pro tech auto that I needed to replace my #7...
Hey Doug. I would change the cam sensor and see it that takes your light on. The misfire may errase with a new cam sensor. I would hold off on the crank, until I changed the cam sensor. If it still runs rough, then maybe try the crank sensor. It is possible they didn't gap the #8 plug right or it was a bad plug. I would try the cam Doug. I would hold off on the crank.
Feb 25, 2011 | 2004 Lincoln Navigator
MY 2005 WARRIOR 1700CC STREET BIKE WILL START FINE AND WHEN WARMED UP I JUMP ON IT AND IT WILL START CUTTING OUT, AND AT TIMES IT FINDS A LITTLE BIT OF AIR OR FUEL AND THE FRONT WHEEL POP'S UP. THIS IS A...
Hey Doug,
I would first suspect a clogged fuel filter, then ignition components and air pathway obstructions from filter to exhaust.
Sounds like the bike wants to run and does run...when it gets what it needs.
If it has a carb, check the float bowl for crud that can clog the jets. You may need to replace fuel line, but not likely.
Oct 12, 2009 | 2005 Yamaha Road Star Warrior
I have a carrier heatpump model 38Q130300 when I turn the thetmostat to run the fan the heat comes on and stays on until I turn the fan off. Any Ideas. Thanks Doug
suggest starting with thermostat replacement only because it sounds as if the fan/heating control has constant power.
good luck
Dave
Jul 16, 2009 | Heating & Cooling
Need motor for craftsman table saw model rm871
Go to midlandhardware.com.For about $4.00 more than just price ofthe motor,you get the complete saw 15amp.motor with a laser guide!The table saw has a 3yr. warranty,3 extension wings,and a sturdy stand.Shipping to your door $24.00,$198.58 total.
Jul 03, 2009 | Craftsman Saws
84 GMC V-6 starts right up 10sec. later dies
Not very technical at the moment, but I can tell it's in the fuel sensor system, not fuel delivery. Check the Mass Airflow Sensor, and related sensors.
Apr 28, 2009 | 1999 Dodge Intrepid
The top lid has a plastic round piece that connects to a rubber
Doug; Type in Bravetti in the search bar and you can find resources to find the gasket. good luck
Jan 24, 2009 | Bravetti Quad Blade Food Processor
DOUG WONG
Thanks for that. It's always helpful to have more experts around. So few people will give free advice these days. It's nice to know that Doug is willing to put some time aside.
Mark
Oct 25, 2008 | Casio Parts Cash Register PC Desktop
I perchased a wall oven 7/16/08 from menards,it is missing one rubber oven door bumper on the right side They do not carry parts, where can I get one, I do not want to damage the door by use without the...
Thank you for the rapid response, I will try a local apliance repair service it is only a little about one half inch sq. x 1/4 inch thick insert on a mod#CWE4800ACB Matag wall oven
Thank You
Doug
Jul 20, 2008 | Maytag Kitchen Ranges
Homelite Mighty Lite Lawn Trimmer  Logo
562 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
