Question about Panasonic PT-61LCX70 61" HDTV
I need to know how to replace the lamp unit. How
I need to know how to replace the lamp unit. How do I access the housing in the television?
  • jpalyo May 15, 2009
    Thanks for the quick reply. I really appreciate it!
  • 11,896 Answers
Remove rear panel, you will see a box with door on it. You can open the door and have access to the bulb.
Posted on May 15, 2009
Our TV just stopped and went black all of a sudden tonight. The cable is still on at the house, but this TV just stopped. How can we tell if it needs a new bulb? Or - what is wrong with it? The LED...
If the lamp is damaged you will see that the lamp is either shattered in the lamp housing or the filament looks charred. If you know how to access the lamp housing please check it and let me know. If you do not know how to do this , let me know and I will give you detailed instructions.
Jun 29, 2011 | LG RU-52SZ51D 52" Rear Projection...
Tv nt coming on red light is on next to power light 50 inch lcd projection sony tv
hello. it sound's like you need to replace the lamp in your set. and here is how to do it the right way. rember to all ways unplug your set.. # 1 first. .Remove the outside lamp cover. The lamp cover is located on the right side of the Sony television. To remove the lamp cover, simply pull down. You will now have access to the lamp housing. # 2 Open the lamp housing door by turning the locking handle counterclockwise while pulling the door toward you # 3 Pull the lamp unit straight out of the television unit. Be sure not to touch the bulb, as it may still be hot. # 4 Slide the replacement bulb into the lamp housing. # 5 The lamp will slide securely into place.!!! "Do not" touch the new bulb as it will cause damage to the bulb and result in malfunction. # 6 Push the lamp door back into place. Turn the locking knob clockwise to secure the door in place.# 7 Slide the outside lamp housing cover back into place on the television.!!! plug your set back in to the wall & The television is now ready for use. thank you
Oct 21, 2010 | Sony KDFE50A10 50" HDTV
Where is the lamp housing for the Panasonic
The lamp housing is located behind the front cover panel.When you open the front panel you can access the lamp unit screw.
thanx
Jul 21, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Removal of the lamp unit from the tv
sometimes lamp is replaced in the front of tv.If so the panel under picture pulls out revealing lamp housing which is held in with a couple screws.replace lamp housing assembly
Feb 22, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Where is bulb located
The lamp assembly is usually housed in a metal holder which can be located behind a removable cover at the rear of your set. The lamp assembly is a high intensity halide lamp with integral parabolic reflector unit. Some later models permit user access to lamp holder via an access cover, earlier units required access to the set's internals by qualified personel.
Jan 01, 2010 | Televison & Video
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    Lamp
    Did you reset you lamp hours when you reinstalled you new lamp?
    Sep 05, 2008 | Office Equipment & Supplies
    Lamp out ...
    remove front panel under screen, rove screws from lamp access panel cover. then remove the screws from the lamp assembly housing pull lamp housing straight out. install new lamp in the housing and slide the cartridge back into set replace screws and access panel cover.
    Apr 09, 2008 | Mitsubishi WD-62327 62" Rear Projection...
    Panssonic PT50DL54 DLP Lamp Replacement
    Webman,
    I own the same television, however, I am not a technician. The lamp housing unit is in the front of the television. Pop off the plastic grill and remove the screw on left side. Access to the bulb is there. Replacing the bulb is quite simple.
    David
    Jan 05, 2008 | Panasonic PT-50DL54 50" Rear Projection...
    Panasonic PT-61LCX70 61" HDTV Logo
    362 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Jaime Hernandez
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
