Question about Dell Dimension 3000 PC Desktop
Every time i start the pc there is a thermal error message the sound of three beeps then shut down unless pc is left off 48 hours error message.
  • 433 Answers
Thermal event are serious, (too hot) make certain of your fan/fans are working. Clean out the dust that has accumulated. Use you computer in a cool environment if possible. If the error continues, purchase some Arctic 5 ceramic paste take off your heat sync apply a very thin coat to the bottom of the heat sync (after you clean it of course) replace the heat sync.
Also pull out the ram (memory) and reseat it.
This should take care of it. If not please ask again.
Please leave a rating...
Posted on May 15, 2009
  • John Viguers
    John Viguers May 15, 2009
No display problem for intel D865GSA board
What are you formatting ? Have you changed the RAM. Does tour system work in its original configuration ? You do not say what the pattern of the beeps is. Before the display disappears, is there a message sent to the screen ?
From the manual
http://download.intel.com/support/motherboards/desktop/d865gsa/sb/d5600601us.pdf
Whenever a recoverable error occurs during POST, the BIOS displays an error message
describing the problem (see Table 53). The BIOS also issues a beep code (one long
tone followed by two short tones) during POST if the video configuration fails (a faulty
video card or no card installed) or if an external ROM module does not properly
checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors,
usually consisting of one long tone followed by a series of short tones. For more
information on the beep codes issued, check the documentation for that external
device.
There are several POST routines that issue a POST terminal error and shut down the
system if they fail. Before shutting down the system, the terminal-error handler issues
a beep code signifying the test point error, writes the error to I/O port 80h, attempts
to initialize the video and writes the error in the upper left corner of the screen (using
both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to
the operating system.
18.April.2014
18.April.2014
Apr 18, 2014 | Intel 865G Motherboard
Dell xps 410 was in use, it beeped and shut down. Then it started powering up and off repeatedly. I pulled the plug to stop the sequence. When I repowered it, it now comes on, fan runs, dvd drives
It sounds as if you have a virus of some kind. I have just dealt with a similar problem. Even after the virus(s) were removed the service was still unable to start. The Operating System had been corrupted and required a re-install to get the system working again. System repair and restore failed. If the only problem is the fan running at full speed then you may need to apply a new layer of thermal paste. This stuff can go dry if you use the cheap stuff or it is old.
Jan 25, 2013 | Dell XPS 410 PC Desktop
Emachines t5212 overheat message then shuts down
Three causes of ovheating:
1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed air and clean the dust out of the computer.
2) A Fan not working. Make sure the fan inside the Power Supply where you plug the power cord in works. Also there is a fan that sits on top of the CPU and Heat Sink. Make sure it works. Normally the system will give you an error message if the fan is not working.
3) Thermal Paste - The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste on the CPU and Heat Sink.
May 09, 2012 | E-Machines W Computers & Internet
Fixed Disk Parameter Table or BIOS Error Okay, so I was browsing around the web the other day. My notebook completely locked up, and I had to hold in the power button for 10 seconds to do a hard shut down....
Remove the hard drive and see if you get the same symptom. It should boot, then go into the BIOS and see if it recognizes the RAMs. Re-seat the RAMs if it doesn't boot - if you have two circuit boards - try one at a time. The motherboard can also be your problem.
Jan 21, 2011 | HP Compaq Smartbuy 5102 166 GHz Intel Atom...
My dell gx280 error, when i start it, it takes too much time to start approximately one to two hour and strange type of sound also heard from speakers. can u solve my problem
You likely have registry errors that are slowing down the computer.
You can go to glaryutilites.com and download the free registry clean,optimizer,booster and fix all your pc's problems.
Jan 16, 2010 | Computers & Internet
Pc beeps.
Uninstall the audio driver and install it again.
Otherwise tick the mute box on the sound volume or turn the sound volume right down.
Apr 14, 2009 | Dell Latitude CPX Notebook
Black screen with error codes
I think the msg you are seeing is just the default monitor message when there is no video to display. Here is a list of common beep codes: Are you getting the one long beep at each restart?
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Dec 16, 2008 | Computers & Internet
Dell Dimension 3000 PC Desktop Logo
159 people viewed this question
Alun Cox
