Question about Kenmore Refrigerators
Kenmore refrigerator Ice maker overfills - intermittently. (Side-by-side Model KM23CFSXS,WOW). 3 Yrs. old; Problem began after I replaced water filter, but I don't see how that could be the problem. 2 or 3 'batches' of ice O.K. then ice trays will attempt to fill twice causing an overflow. Once, I heard the ice falling into collection bin and immediately went to take a look. "Pusher' fingers were in 2nd rotation (assuming it takes a complete 1st rotation to empty ice tray and hear the ice fall) some water was already in tray and when rotation completed water fill cycle overflowed the tray. Then, while cleaning previous overflow, unit cycled again within 5/6 minutes causing a 2nd overflow. Other times I hear the ice fall, the fingers complete the cycle and then water fills the tray. All is well. Thanks in advance,
  • opm4me May 15, 2009
    I cannot understand how a failing solder connection would cause the ice maker to refill prematurely. Wouldn't it be more likely that some mechanical part (Lever?) is sticking in the refill position?
    Rylee, Kenmore Model 253.44352400. How do I identify + test the WATER FILL VALVE, or do I need to follow the previous recommendation of replacing the entire module?
    Note: unit is level. Tray has no flaking. Have observed 2nd water refill a few minutes after first. Timer problem?
    Brigadier General:
  • 8,619 Answers
Hi
Please make sure the icemaker is level, some of the plastic liner will move and allows the icemaker to tilt over and leak. Also check the fill valve, it might be staying on and over filling the icemaker. The finish sometimes comes off the icemaker body and all the ice cubes don't come out. This will allow the new water to fill on top of an icemaker that still has a ice cube or two left inside the body, if you have had trouble with black specs in your ice cubes, this may have been the beginning of your finish problem on the icemaker body.
Please tell me the model number of your refrigertor(it would be of form 110.XXXXXX or 665.XXXXXX) so that i can provide you with model specific information.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 15, 2009
    Brigadier General:
  • 3,917 Answers
What I find that usually causes this is that the ice maker module circuit soldering starts wearing down and causing the overflow.
A new module should fix it, here is the one for your model:
Kenmore refrigerator Ice maker overfills - - 00219740.jpgManufacturer Part#626653
Also you would find a detailed explaination in the bellow link:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Thanks
Kenmore side by side model #515541 01--replaced water filter -water dispenser works great but no water coming into ice maker - what could be problem? we purchased this used-is there something we have to do...
I had the same problem. Sometimes the tray overfills and freezes in the little line that fills the ice cube tray.
I solved the problem by taking an ice pick and clearing the ice from the end of that little waterline until the water started flowing again.
Feb 10, 2011 | Kenmore 57029 Side by Side Refrigerator
GE Profile Refrig model PSC23SGRC ice maker stopped making ice. Water is ok, just stopped? Is this common? Its only 4 yrs old
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes aand then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
Jan 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Have Amana side-by-side about 14 yrs old. The icemaker overfills ice tray by about 8oz of water? Please help!
Unless someone has made a water level adjustment there is,
Only one repair. Replace the ice maker.
If someone has made a water level adjustment you can try this.
Remove the ice maker plastic cover. Locate the water level screw adjust it to a minimum setting and try it there.
If that does not correct the problem, replace the ice maker.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Ice maker stopped working
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
KENMORE REFRIGERATOR 106.57024601
the problem is most likely the water valve behind the machine. it is closing too slow and letting too much water flow into the icemaker. c30b276.jpg
Jul 16, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Ice Maker
Pressure difference between the two water supply systems is the cause of the overfill condition. You may have to install a water pressure regulator in line to the ice maker water supply. Or you can try to control the flow by throttling the supply valve to the refrigerator.
Jun 12, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore side by side refrigerator
Check the water valve in back of refrig.. u have a double valve... one side for water the other side for your ice maker.. make sure ice maker valve is working.
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
244 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
