Question about Kobe CH7936SQ Kitchen Hood
Control Panel Breaks Down
The control panel on my Kobe CH7936SQ has broken twice in 3 years, and is now out of warranty. I had a great deal of difficulty with the repair, as they took several weeks to contact me and then the person who came to do the repair was very rude. When I contacted Kobe to get a new control panel with a different repair service, they did not return my call.
Can this repair be done with minimal work, or do I have to get another kitchen hood?
  • Anonymous Apr 09, 2008
    Ac panel repair
  • 93 Answers
Is your control panel is under the hood? if so, every time you use your stove turn the hood on, the reason is, the heat from the stove burner is melting it, but if you have your hood on, it will pull away some of the heat. you can try to put your hand at the control panel with the front burners on, then you will feel the heat from the stove.
Posted on Mar 02, 2010
Panasonic 1250w genius senor inverter less then a year old. Control panel lights up, works.microwave itself does not, control panel shuts off in a few seconds
When a Panasonic Inverter Microwave shuts off after a feew seconds, it is either a bad inverter which is the quite expensive circuit board that powers the magnetron that puts out the microwave energy, or a bad magnetron, Or BOTH typically this would be a costly repair, But since it is still under warranty. You need to find a Panasonic warranty service provider in your area. If it is a counter top unit, you may have to take it to them for repair.
Jul 05, 2017 | Panasonic Microwave Ovens
We have replaced our control panel PN 99003139, THREE times. Each time same thing happens. The lights and buttons gradually and intermittently go out. The dish washer will still run, so long as the st
Whirlpool parts come with a one year warranty WP owns Jenn Air take it back I have replaced this panel then had to go back and change again in 3 days it failed yes could be a bad batch of panels the panel is powered by the control is the control taking out the panel can't say it is a computer maybe sending to high a voltage to panel no way to test that
Jan 30, 2015 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Miele G2830 control panel locks out, unplug and let set would reset it but now it does not. is there a way to reset
I have a Miele G2830sci dish washer since brand new, used twice a week in a domestic environment. I am very dissatisfied with this dishwasher because the front control panel (touch screen, no buttons) became unresponsive after six years, outside the warranty. I had the panel replaced (part was AUD$290 and labour/callout fee $210) and the dishwasher was working properly again for another 3 years. Now the same issue is appearing again. I believe that these control panels only have a relatively short lifespan relative to the other parts of the machine. The touch pane becomes unresponsive, or erratic to respond to your touch when the panel is warm, typically towards the middle or end of the cycle when the hot wash or drying is occurring. The panel would be OK when cold. But give it enough time and even when cold, it would no longer work properly. It looks like this panel only has a short useful working life relative to the rest of the machine, based on my direct first hand experience. Not good.
Nov 27, 2011 | Miele G 2830 SCi Stainless Steel Built-in...
Sky remote code ????
Hello
Check these codes.
065 244 405 318 037 398 191 459 245 389 060 275
742
743
726
508
584
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4* Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5*
Point the Sky+ remote control at the TV and try the volume button.
OK.
Jul 04, 2011 | LG 47LC7DF 47 in. LCD HDTV
I have a gw395leps00 Whirlpool gas range. Touch pad has been erratic for about a year or so - up til now it would 'come back to life.' Now about 1/3 of the buttons don't work at all - no beep/change on...
I have replaced the touch pad on our stove twice now. The original lasted just beyond the warranty period. The 2nd one lasted about 18 months. I am on the 3rd touch pad and it is still working however this time I ordered an extra one as a backup. If you do it yourself it is not that expensive. The pad is about $60.00 at an appliance parts store. It is not too difficult to replace. Make sure the gas is shut off and the stove is unplugged! Remove the screws from the control panel and pull in out just enough to access the control board, If the burner controls are on the panel remove the knobs and the screws that connect the burner controls to the panel and leave them in place. Do not tug or pull on the burner controls! Carefully unplug the pad from the control board and unpeel the stick pad from the panel Clean the contact surface with alcohol, Carefully stick the new pad on and plug it into the control board. Screw the panel back in and you are good for about another year or so.
Jan 30, 2011 | Whirlpool Kitchen Ranges
Machine won't do anything and showing error 23
Sorry to read about your problem, I hope this helps you out.
An E23 error code on your Frigidaire washer indicates a failure of the drain pump relay.
Depending upon the model, your washer may be under warranty for up to 25 years, so check your warranty's status before attempting any repairs yourself.
    Try to Clear the Code
  1. A power outage can cause error codes to display on the screen, even if there's no problem. Hold down the "Cancel" button for three seconds, or unplug the machine briefly to see if the code goes away. If it returns, the problem is real.
  2. Check the Pump
  3. Unplug the machine and remove the service panel. Locate the pump on the floor of the machine, to the left of the tub, towards the front. Inspect the wiring for burns, breaks or loose connections, and replace as necessary. Use only appliance-grade wire.
  4. Replace the Control Panel
  5. If the wiring is fine, the problem is a severed relay on the control panel. Unfortunately, this cannot be repaired and must be replaced. Remove the control panel from the upper portion of the back of the machine, and replace with an identical part from Frigidaire.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 30, 2010 | Frigidaire ATF6000ES Front Load Washer
Bosch washing machine error code F61 was does it mean
An F61 error code on your Frigidaire washer indicates a failure of the drain pump relay. Depending upon the model, your washer may be under warranty for up to 6-15 years above , so check your warranty's status before attempting any repairs yourself.
To solve the error code problem apply the below step one after the othe
  • A power outage can cause error codes to display on the screen, even if there's no problem. Hold down the "Cancel" button for three seconds, or unplug the machine briefly to see if the code goes away. If it returns, the problem is real.
  • The pump can also be the problem
  • Unplug the machine and remove the service panel. Locate the pump on the floor of the machine, to the left of the tub, towards the front. Inspect the wiring for burns, breaks or loose connections, and replace as necessary. Use only appliance-grade wire.
  • TO REPLACE THE CONTROL PANEL.
  • If the wiring is fine, the problem is a severed relay on the control panel. Unfortunately, this cannot be repaired and must be replaced. Remove the control panel from the upper portion of the back of the machine, and replace with an identical part from Frigidaire. Generic parts can cause additional damage
  • Hope this help?
    Thanks.
    Nov 19, 2010 | Washing Machines
    Fridge side is warm at 60 degrees, ice build up at very bottom shelf next to vegies control, freezer temp. switch springs back when attempt to increase to level 3 or higher.
    EASY FIX .TAKE ALL FOOD OUT.
    UNPLUG FRIDGE FOR 24HOURS WITH DOORS OPEN .
    CLEAN UP ALL THE WATER IT WILL LEAK ON YOUR FLOOR.
    IT WILL WORK FOR ABOUT A YEAR OR TWO BUT WILL HAPPEN AGAIN.
    A MORE PERMENANT FIX WILL TAKE SOME TIME. TRY THIS FIRST.
    May 01, 2009 | Refrigerators
    FLOOR HEAT INOP DOOR BROKEN
    Simple solution even the dealers could'nt find, The white plastic pivot bushing which links servo motor to plenum door has a stop cast into it, which was broken off. Ridiculous that it took three dis-assemblys to discover. Thank- you for your interest.
    Jan 29, 2009 | 2004 Dodge Ram 1500
    Sony Rear Projection TV - Red tube too strong
    remove the front speaker assembly and the small access panel behind it and you will see a small square control assembly with 6 dials on it 3 control the color guns and 3 control the 3 gun focus. Try turning down the red control slightly they will be set up just like the CRTs red green and blue.
    May 16, 2008 | Sony KP-57WS500 57" Rear Projection...
    Kobe CH7936SQ Kitchen Hood Logo
    320 people viewed this question
    Top Kobe Kitchen Ranges Experts
    Oloyede Monsuru
    Marvin
    Marvin
    Paul Carew
    Are you a Kobe Kitchen Range Expert? Answer questions, earn points and help others
