Question about GE WSKS2060WWH Top Load Washer
Ge washer how large in cu ft wsks2060w1wh - GE WSKS2060WWH Top Load Washer
4 Suggested Answers
SOURCE:
SOURCE: GE front Loader Washer Door
the following link might help you out.Please do post your comments.
http://www.repairclinic.com/Parts?s=t-WBVH6240FWW+-%3d%3dc226&n=1&z=10
Posted on Dec 23, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: GE® 3.5 Cu. Ft. King-size Capacity Washer will not spin/adgitate
I would check the lid switch. On many machines there is no motion at all if the lid is up. If the switch is bad it may not realize the lid is down and nothing will happen after the machine fills. You can try a web search for how to test or replace the lid switch for your specific model. There are also several appliance repair sites with how-to procedures as well as parts. It's not too difficult to change the switch yourself on most washers.
Posted on Jun 10, 2009
  • 4 Answers
SOURCE: How do I remove the
Anyone with loud scraping/clanging- we had that problem and saw that the large wheel the belt goes around is only an inch above the metal bottom.When we moved the washer with a 2wheeler it pushed the bottom up into the metal wheel. The racket it made was horrible. It left metal shavings ,too. You'll need to pull the bottom of the washer back out.Pull fromt panal off with putty knife.You'll need to lean or lay washer to one side.Put a pillow or cushion inside between the tub and housing side you'll be leaning towards. What I did was drill two little holes-one near the back center and one near the front center. I took a long piece of heavy string,put one end in one hole and the other end in the other hole-outside to inside.Tie the ends around each end of a 1x2,18inch board .Get the board to the back without damaging stuff inbetween-pulling on your back string for help. Make sure the board is against the bottom, get to where you can now pull your string 'handle' w/both hands,yanking and popping the bottom back out.Our washer now works beautifully and quietly.
Posted on Nov 08, 2011
My GE stackable washer is pouring out water while filling up, when spinning makes horrible noise and tub goes crazy
The issue is that a shock or spring that balances the tub has come loose and pulled a hose off when it broke. So the shocks or the springs are bad. The hose might be able to just be put back on.
Feb 23, 2015 | General Electric GE 5.4 cu. ft. Large...
How do I set water temperature for the rinse cycle?
I suppose you have looked at the owners manual, on the page below, it seems to indicate knob B. but it is unclear
GTWN4250DWS GE 3 9 DOE cu ft stainless steel capacity washer GE Appliances
Dec 24, 2014 | GE GTWN4250DWS 3.9 cu. ft. capacity top...
Washer will not fill on large load
are u saying water level will not fill to high but will for lower level? If so check ur water level pressure switch with a multimeter
Dec 23, 2014 | GE WSLP1500JWW Space-Saving 3.1 IEC Cu....
GE Super Plus 3.2 Cu. Ft. Capacity Washer WBSE3120BWW
Go to partselect.com or repairclinic.com. Put in your model number the select symptoms or repair help according to site you are on.
Feb 08, 2014 | GE 3.2 cu. ft. Washer
Capacity of model washer
your capacity is 4.1 cu ft this is a pretty large capacity machine cheers-Denny
Oct 15, 2013 | GE WWSR3090TWW
Where do i find the cu ft capacity for my washing machine? VLXR1020T
It should be shown on the inside of the door, or on the back of the electrical control panel (back of the machine).
Alternately, you can google the make and model. A small washing machine should be around 2cu.ft, a large one will run around 4 cu.ft
Nov 17, 2009 | GE Washing Machines
Size of washer
Size varies between manufactures, the biggest I have seen is the GE which is 3.5 cu ft, base your machine on your standard size load, ours is about 8lbs however I dont overload, I take large items quilts, comforters etc to a laundromat, its not worth breaking my machine over a comforter wash for $3.50 American.
Go to Sears.com and look @ the washers available
Jun 06, 2008 | Kenmore 22422 Top Load Washer
GE WSKS2060WWH Top Load Washer Logo
48 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
