Question about Vacuums
Can't open Cannister Vacuum to get to motor
Hi, I have a kenmore 116 20712007 canister vacuum cleaner. The motor fried last week and I just got a replacement motor. I cannot for the life of me open up the canister. I took off the two screws under the hood, but there appears to be two screws under the bottom by the wheels holding the top and bottom together. The screws are in two deep, thin holes and I called Sears parts who said the screws are flat heads. I just went out and bought two thin flatheads and cant find the groove. any suggestions before the unit goes out the front window? Thanks in advance, Mike
Pop the cover that operates the cord return you will find two phillips head screws under it; take them out and the covers comes right off.
Posted on Dec 20, 2009
It's 5 years old and I vacuum twice a week about 900 sq ft. It is starting to smoke and the belt sounds like it's working overtime. The hose is fine. The bag is continuing to fill up. The floor...
Make sure that the dirt bag is empty and that the motor bearings are good. Also check for any debris that may be gumming up motor bearings and forcing it to run slow.
You also can check out the motor brushes and replace them.
Mar 22, 2017 | Kenmore 25512/ 25513 Progressive Canister...
I NEEDED TO FIND OUT HOW TO INSTALL A POWER CORD ON A KENMORE CANNISTER VACUUM (WHISPERTONE) NOT A KITCHEN STOVE.
Hi emery1950,
I have provided you instruction on how to remove the motor canopy to get to the reel cord area and how to replace the reel cord. Kindly click on this link.
Hope it helps.
Thank you for using Fixya.
Apr 13, 2011 | Kenmore Whispertone 23312 Bagged Canister...
How do i reset a sears cannister vacum cleaner
Hello, you can not reset the canister only the power head, if y ou picked up something and it got caught in the roller, it will shut the motor off, on top off the head is a red botton take a pen or something small to push the botton, and that will rest the powert head, if the canister is not running the cords go bad, and will need to be replaced. If I can help, feel free to call 1561-848-3387 Thank you, Teresa.
Clean Sweep Vacuums
Aug 10, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
Model 116 Kenmore vacuum cleaner. 20+ years old,
Greetings,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Mar 21, 2010 | Vacuums
I need the owners manual for kenmore cannister 24212
If you type in the model number on your searchbar, the website will be listed "after" all the sponored sites. Use the site that has YOUR manufacturers name in the url. Under the "support" section choose manuals and especially the term pdf. Thank you, Dana
Feb 13, 2010 | Kenmore 24212 Whispertone Bagged Canister...
Cannister
with an ohms meter you have to test for voltage at the motor if power is there, motor is bad if no power go to on switch check and try by passing it this will let you know where your problem is.
Feb 07, 2010 | Kenmore Canister Vacuum Vacuum
No suction
If the motor is running and is not full of dirt, and the hose is not plugged, the canister must be cracked or open somehow.
May 08, 2009 | Kenmore 22812 Bagged Canister Vacuum
Canister motor not on - power to power mate is on
if its a long plastic tube with snaps on it that is where the fuse is.open it up and you will find the fuse
Apr 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Jan 04, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Vacuums Logo
182 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
