Question about Bosch 10.8V Pocket Driver
Drill locked up
My drill won't turn.  It is locked.
  • Anonymous Aug 26, 2008
    drill not turn and no power
  • 313 Answers
Gear possible stripped inside.gear are made of plastic & metal combination gear.
Posted on May 29, 2008
Bosch 11241EVS won't hammer
Not all bits for hammer drills are the same as the slots in the sides of the shanks are different between makes . There is a standard between hilti and ramset drill bits but other makers have different ideas Check out the shanks of your drill bits and look for the slot that holds in the bit.
May 26, 2013 | Bosch 11241EVS SDS-Max Rotary Hammer
Dcd985 reverse switch won't work
The switch (PN: N089938) for your drill costs between $75 & $80, so:
If by "brand new, just out of the box" you mean you just bought it, bring it back to where you got it and exchange it or get your money back.
If by "brand new, just out of the box" you mean you bought it, it sat somewhere for some time and you're just now using it, check to see if it's still under warranty so you can get it fixed through that.
If it's out of warranty, you'll have to buy a switch to fix it. They're available on sites like
Feb 21, 2013 | Dewalt DC925 Cordless Drill
1997 taurus key won't turn in the ignition, gear selector won't go into gears
Usually a sign the tumblers in the lock cylinder have worn out or jammed.
You may have to get the lock cylinder drilled out and replaced.
Jan 13, 2013 | 1997 Ford Taurus
Remove the chuck dc970
I'm assuming you have a DCD970 as DeWalt doesn't have a DC970 and the DW970 is an impact driver. The chuck on your drill is a new design that doesn't have a lock screw inside the chuck, they are put on very tight with lock-tite to hold them on. They are made to be taken off with a special chuck holder and vice jig that only service centers have. The allen wrench method used on older chucks won't work as the chuck will just loosen when you hit the allen wrench. I have on occasion removed one by doing the following: Turn the chuck fully open then secure it in a vice with the drill straight up. Holding the drill body and using the handle for leverage, turn the drill counterclockwise, as you are looking down on it, with steady, strong pressure. If the chuck breaks free it will spin off easily. If you are at all afraid you may break the handle you may have to take or send it to a service center to have it removed.
Mar 07, 2012 | Dewalt Drills
Black decker drill keyless chuck won.t open !
hold the back of the chuck with channel locks or a vice and use the same channel locks on the front and open the chuck manually it should work and you can get to the screw to replace it or the hand chuck. this can be a little frustrating but hang in there and you'll be a pro shortly.
Sep 02, 2009 | Makita Usa Inc No.8390DWPE 18V Crdls...
Drill press
Release the belts and check if you can turn the chuck by habd, if the chuck won;t turn, two things could be wrong, 1) the quill bearings are bad or 2) the shaft that runs down thru the quill could ve rusted causing a restriction, if that's the case, WD 40 should loosen it.
Oct 24, 2008 | Delta 15 331 15" 115/230V Variable Speed...
Bosch 10.8V Pocket Driver Logo
227 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
Are you a Bosch Drill Expert? Answer questions, earn points and help others
